Hello, I want to setup my Jetson TX2 with Jetpack 4.6.3 I already flash Jetson OS and download SDK Components. I will flash SDK Components to my Jetson from host but it want ethernet ipv4 adress. I add a static ip addres to my jetson eth0. When I ping or ssh in normal mode, everyting is OK but when I return it to recovery mode there is no ssh and ping. Overall I couldnt process SDK Components part because of disconnection. I’m sure ip adress is correct. How can I acces ssh when I was in recovery mode? How can I install SDK Components? (I dont want to use usb or sudo apt ways for solution, I will use ethernet)
You cannot ssh in recovery mode. Recovery mode is just for flashing the board.
Recovery mode has nothing to do with sdk components either.
