Jetson TX2 Screen Blank after I changed IP Address
Hi my name is Silvi. I have Jetson TX2 which I changed the DHCP IP Address to a specific one recently. After that, the Jetson started to blank and could’t display anything. I have tried every solutions in the forum from reset the Jetson from Jetpack to serial console, but it still didn’t work. I also got this notification when I turn on the Jetpack from minicom:
Aux Info = 0x0, Reason = 0x1c
[0�[0000.172] C> ERROR: Highest Layer Module = 0x1d, Lowest Layer Module = 0x15,
Can you please help me about this matter? Thank you very much
silvirianti,
Please try to share the full boot log.
Hi Wayne, thank you very much for your reply
This is the full boot log
Welcome to minicom 2.7
OPTIONS: I18n
Compiled on Feb 7 2016, 13:37:27.
Port /dev/ttyUSB0, 16:03:24
Press CTRL-A Z for help on special keys
[0000.174] C> ERROR: Highest Layer Module = 0x1d, Lowest Layer Module = 0x15,
[0[0000.172] C> ERROR: Highest Layer Module = 0x1d, Lowest Layer Module = 0x15,
[0�[0000.182] C> ERROR: Highest Layer Module = 0x1d, Lowest Layer Module = 0x15,
[0�[0000.179] C> ERROR: Highest Layer Module = 0x1d, Lowest Layer Module = 0x15,
[0[0000.185] C> ERROR: Highest Layer Module = 0x1d, Lowest Layer Module = 0x15,
[0[0000.193] C> ERROR: Highest Layer Module = 0x1d, Lowest Layer Module = 0x15,
[0[0000.192] C> ERROR: Highest Layer Module = 0x1d, Lowest Layer Module = 0x15,
[0[0000.190] C> ERROR: Highest Layer Module = 0x1d, Lowest Layer Module = 0x15,
[0�[0000.193] C> ERROR: Highest Layer Module = 0x1d, Lowest Layer Module = 0x15,
[0[0000.191] C> ERROR: Highest Layer Module = 0x1d, Lowest Layer Module = 0x15,
[0[0000.182] C> ERROR: Highest Layer Module = 0x1d, Lowest Layer Module = 0x15,
[0[0000.173] C> ERROR: Highest Layer Module = 0x1d, Lowest Layer Module = 0x15,
[0[0000.187] C> ERROR: Highest Layer Module = 0x1d, Lowest Layer Module = 0x15,
[0[0000.186] C> ERROR: Highest Layer Module = 0x1d, Lowest Layer Module = 0x15,
[0�[0000.178] C> ERROR: Highest Layer Module = 0x1d, Lowest Layer Module = 0x15,
[0�[0000.186] C> ERROR: Highest Layer Module = 0x1d, Lowest Layer Module = 0x15,
[0�[0000.192] C> ERROR: Highest Layer Module = 0x1d, Lowest Layer Module = 0x15,
[0�[0000.191] C> ERROR: Highest Layer Module = 0x1d, Lowest Layer Module = 0x15,
Could you reflash your device?
No I cannot, I already tried it by flash with Jetpack and even clone procedure but nothing worked out.
silvirianti,
Could you share the log from jetpack when flashed failed?
I attached the link of log screenshot here. Thank you
https://drive.google.com/file/d/1mZeY2LZSm0Z_e9tRsc8mwj4Atm5a15yw/view?usp=sharing
What is your host environment? Please share.
I use Ubuntu 16.04 with Jetpack 3.2
silvirianti,
Do you have only one tx2 device that can verify your Jetpack3.2? Just want to check if anything is missing in your jetpack.
Yes I have another Jetson TX2. Can you please help and guide me how to do it? Thank you very much
You could just go into below folder under your Jetpack installation path and flash your another device.
JetPack3.2/64_TX2/Linux_for_Tegra
sudo ./flash jetson-tx2 mmcblk0p1
Can you help me more to get to know where is the folder located because I couldn’t found it
Could you go to the folder where you install jetpack? Could you share what is inside of it?
Do you mean in the host PC or in another TX2?
Host pc
I already tried to flash as your recommendation but it’s appeared to be like this
sudo: ./flash: command not found
Recently I tried to flash it again through Jetpack and there is an issue in the flash_os_tx2_log
L4T BSP Information:
R28 (release), REVISION: 2.1, GCID: 11272647, BOARD: t186ref, EABI: aarch64,
DATE: Thu May 17 07:29:06 UTC 2018
Target Board Information:
Name: jetson-tx2, Board Family: t186ref, SoC: Tegra 186,
OpMode: production, Boot Authentication: ,
./tegraflash.py --chip 0x18 --applet “/home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin” --cmd “dump eeprom boardinfo cvm.bin” --skipuid
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0018 ] Generating RCM messages
[ 0.0025 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 --download rcm /home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
[ 0.0030 ] RCM 0 is saved as rcm_0.rcm
[ 0.0033 ] RCM 1 is saved as rcm_1.rcm
[ 0.0033 ] List of rcm files are saved in rcm_list.xml
[ 0.0033 ]
[ 0.0034 ] Signing RCM messages
[ 0.0040 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0045 ] Assuming zero filled SBK key
[ 0.0075 ]
[ 0.0075 ] Copying signature to RCM mesages
[ 0.0081 ] tegrarcm_v2 --chip 0x18 --updatesig rcm_list_signed.xml
[ 0.0089 ]
[ 0.0089 ] Boot Rom communication
[ 0.0095 ] tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml --skipuid
[ 0.0099 ] RCM version 0X180001
[ 0.0107 ] Boot Rom communication completed
[ 1.0172 ]
[ 1.0189 ] tegrarcm_v2 --isapplet
[ 1.0204 ] Applet version 01.00.0000
[ 1.0412 ]
[ 1.0435 ] Retrieving EEPROM data
[ 1.0437 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/bootloader/cvm.bin
[ 1.0458 ] Applet version 01.00.0000
[ 1.0776 ] Saved platform info in /home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/bootloader/cvm.bin
[ 1.1549 ]
Board ID(3310) version(B02)
copying bctfile(/home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg)… done.
copying misc_config(/home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-misc-si-l4t.cfg)… done.
copying pinmux_config(/home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg)… done.
copying pmic_config(/home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg)… done.
copying pmc_config(/home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg)… done.
copying prod_config(/home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg)… done.
copying scr_config(/home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/minimal_scr.cfg)… done.
copying scr_cold_boot_config(/home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/mobile_scr.cfg)… done.
copying bootrom_config(/home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg)… done.
copying dev_params(/home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/bootloader/t186ref/BCT/emmc.cfg)… done.
Existing bootloader(/home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
populating kernel to rootfs… done.
populating initrd to rootfs… done.
populating extlinux.conf.emmc to rootfs… done.
populating /home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb to rootfs… done.
done.
Making Boot image… done.
Existing sosfile(/home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin) reused.
copying tegraboot(/home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/bootloader/t186ref/nvtboot.bin)… done.
Existing mb2blfile(/home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
Existing mtspreboot(/home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/bootloader/preboot_d15_prod_cr.bin) reused.
Existing mts(/home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/bootloader/mce_mts_d15_prod_cr.bin) reused.
Existing mb1file(/home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/bootloader/mb1_prod.bin) reused.
Existing bpffile(/home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/bootloader/bpmp.bin) reused.
copying bpfdtbfile(/home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/bootloader/t186ref/tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb)… done.
Existing scefile(/home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/bootloader/camera-rtcpu-sce.bin) reused.
Existing spefile(/home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/bootloader/spe.bin) reused.
copying wb0boot(/home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/bootloader/t186ref/warmboot.bin)… done.
Existing tosfile(/home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/bootloader/tos.img) reused.
Existing eksfile(/home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)… done.
Making system.img…
populating rootfs from /home/silvirianti/Documents/Jetson/64_TX2/Linux_for_Tegra/rootfs … done.
Sync’ing system.img … done.
Converting RAW image to Sparse image…
---- Raw to Sparse Image Converter v1.0 ----------------------------
0: RAW: 4239360( 1035 blks) ==> 28:4239372
1: SKP: 24576( 6 blks) ==> 4239400:12
2: RAW: 4096( 1 blks) ==> 4239412:4108
3: SKP: 61440( 15 blks) ==> 4243520:12
4: RAW: 299008( 73 blks) ==> 4243532:299020
5: SKP: 33255424( 8119 blks) ==> 4542552:12
6: RAW: 565248( 138 blks) ==> 4542564:565260
7: SKP: 95768576( 23381 blks) ==> 5107824:12
8: RAW: 12288( 3 blks) ==> 5107836:12300
9: SKP: 4186112( 1022 blks) ==> 5120136:12
10: RAW: 1146880( 280 blks) ==> 5120148:1146892
11: SKP: 667648( 163 blks) ==> 6267040:12
12: RAW: 86016( 21 blks) ==> 6267052:86028
13: SKP: 24576( 6 blks) ==> 6353080:12
14: RAW: 143360( 35 blks) ==> 6353092:143372
15: SKP: 16384( 4 blks) ==> 6496464:12
16: RAW: 8192( 2 blks) ==> 6496476:8204
17: SKP: 4096( 1 blks) ==> 6504680:12
18: RAW: 1253376( 306 blks) ==> 6504692:1253388
19: SKP: 20480( 5 blks) ==> 7758080:12
20: RAW: 4096( 1 blks) ==> 7758092:4108
21: SKP: 40960( 10 blks) ==> 7762200:12
22: RAW: 4096( 1 blks) ==> 7762212:4108
23: SKP: 4096( 1 blks) ==> 7766320:12
24: RAW: 114688( 28 blks) ==> 7766332:114700
25: SKP: 4096( 1 blks) ==> 7881032:12
26: RAW: 126976( 31 blks) ==> 7881044:126988
27: SKP: 4096( 1 blks) ==> 8008032:12
28: RAW: 12496896( 3051 blks) ==> 8008044:12496908
29: SKP: 4096( 1 blks) ==> 20504952:12
30: RAW: 4096( 1 blks) ==> 20504964:4108
31: SKP: 4096( 1 blks) ==> 20509072:12
32: RAW: 638976( 156 blks) ==> 20509084:638988
33: SKP: 4096( 1 blks) ==> 21148072:12
34: RAW: 11378688( 2778 blks) ==> 21148084:11378700
35: SKP: 4096( 1 blks) ==> 32526784:12
36: RAW: 57344( 14 blks) ==> 32526796:57356
37: SKP: 4096( 1 blks) ==> 32584152:12
38: RAW: 9785344( 2389 blks) ==> 32584164:9785356
39: SKP: 4096( 1 blks) ==> 42369520:12
40: RAW: 4120576( 1006 blks) ==> 42369532:4120588
41: SKP: 73728( 18 blks) ==> 46490120:12
42: RAW: 8433664( 2059 blks) ==> 46490132:8433676
43: SKP: 8192( 2 blks) ==> 54923808:12
44: RAW: 3829760( 935 blks) ==> 54923820:3829772
45: SKP: 12288( 3 blks) ==> 58753592:12
46: RAW: 4096( 1 blks) ==> 58753604:4108
47: SKP: 12288( 3 blks) ==> 58757712:12
48: RAW: 4096( 1 blks) ==> 58757724:4108
49: SKP: 12288( 3 blks) ==> 58761832:12
50: RAW: 16384( 4 blks) ==> 58761844:16396
51: SKP: 16711680( 4080 blks) ==> 58778240:12
52: RAW: 81874944( 19989 blks) ==> 58778252:81874956
53: SKP: 8192( 2 blks) ==> 140653208:12
54: RAW: 25718784( 6279 blks) ==> 140653220:25718796
55: SKP: 8192( 2 blks) ==> 166372016:12
56: RAW: 23953408( 5848 blks) ==> 166372028:23953420
57: SKP: 8192( 2 blks) ==> 190325448:12
58: RAW: 37969920( 9270 blks) ==> 190325460:37969932
59: SKP: 8192( 2 blks) ==> 228295392:12
60: RAW: 118784( 29 blks) ==> 228295404:118796
61: SKP: 4096( 1 blks) ==> 228414200:12
62: RAW: 53248( 13 blks) ==> 228414212:53260
63: SKP: 90112( 22 blks) ==> 228467472:12
64: RAW: 12288( 3 blks) ==> 228467484:12300
65: SKP: 4096( 1 blks) ==> 228479784:12
66: RAW: 16384( 4 blks) ==> 228479796:16396
67: SKP: 12288( 3 blks) ==> 228496192:12
68: RAW: 16384( 4 blks) ==> 228496204:16396
69: SKP: 4096( 1 blks) ==> 228512600:12
70: RAW: 8192( 2 blks) ==> 228512612:8204
71: SKP: 4096( 1 blks) ==> 228520816:12
72: RAW: 4096( 1 blks) ==> 228520828:4108
73: SKP: 4096( 1 blks) ==> 228524936:12
74: RAW: 8192( 2 blks) ==> 228524948:8204
75: SKP: 8192( 2 blks) ==> 228533152:12
76: RAW: 8192( 2 blks) ==> 228533164:8204
77: SKP: 4096( 1 blks) ==> 228541368:12
78: RAW: 8192( 2 blks) ==> 228541380:8204
79: SKP: 4096( 1 blks) ==> 228549584:12
80: RAW: 8192( 2 blks) ==> 228549596:8204
81: SKP: 8192( 2 blks) ==> 228557800:12
82: RAW: 8192( 2 blks) ==> 228557812:8204
83: SKP: 12288( 3 blks) ==> 228566016:12
84: RAW: 28672( 7 blks) ==> 228566028:28684
85: SKP: 4096( 1 blks) ==> 228594712:12
86: RAW: 69632( 17 blks) ==> 228594724:69644
87: SKP: 12288( 3 blks) ==> 228664368:12
88: RAW: 4096( 1 blks) ==> 228664380:4108
89: SKP: 8192( 2 blks) ==> 228668488:12
90: RAW: 16384( 4 blks) ==> 228668500:16396
91: SKP: 4096( 1 blks) ==> 228684896:12
92: RAW: 8192( 2 blks) ==> 228684908:8204
93: SKP: 16384( 4 blks) ==> 228693112:12
94: RAW: 8192( 2 blks) ==> 228693124:8204
95: SKP: 4096( 1 blks) ==> 228701328:12
96: RAW: 8192( 2 blks) ==> 228701340:8204
97: SKP: 8192( 2 blks) ==> 228709544:12
98: RAW: 4096( 1 blks) ==> 228709556:4108
99: SKP: 20480( 5 blks) ==> 228713664:12
100: RAW: 4096( 1 blks) ==> 228713676:4108
101: SKP: 8192( 2 blks) ==> 228717784:12
102: RAW: 4096( 1 blks) ==> 228717796:4108
103: SKP: 12288( 3 blks) ==> 228721904:12
104: RAW: 8192( 2 blks) ==> 228721916:8204
105: SKP: 4096( 1 blks) ==> 228730120:12
106: RAW: 4096( 1 blks) ==> 228730132:4108
107: SKP: 12288( 3 blks) ==> 228734240:12
108: RAW: 4096( 1 blks) ==> 228734252:4108
109: SKP: 45056( 11 blks) ==> 228738360:12
110: RAW: 8192( 2 blks) ==> 228738372:8204
111: SKP: 28672( 7 blks) ==> 228746576:12
112: RAW: 4096( 1 blks) ==> 228746588:4108
113: SKP: 57344( 14 blks) ==> 228750696:12
114: RAW: 20480( 5 blks) ==> 228750708:20492
115: SKP: 8192( 2 blks) ==> 228771200:12
116: RAW: 16384( 4 blks) ==> 228771212:16396
117: SKP: 4096( 1 blks) ==> 228787608:12
118: RAW: 16384( 4 blks) ==> 228787620:16396
119: SKP: 20480( 5 blks) ==> 228804016:12
120: RAW: 4096( 1 blks) ==> 228804028:4108
121: SKP: 8192( 2 blks) ==> 228808136:12
122: RAW: 8192( 2 blks) ==> 228808148:8204
123: SKP: 4096( 1 blks) ==> 228816352:12
124: RAW: 524288( 128 blks) ==> 228816364:524300
125: SKP: 4096( 1 blks) ==> 229340664:12
126: RAW: 57344( 14 blks) ==> 229340676:57356
127: SKP: 32768( 8 blks) ==> 229398032:12
128: RAW: 147456( 36 blks) ==> 229398044:147468
129: SKP: 8192( 2 blks) ==> 229545512:12
130: RAW: 2019328( 493 blks) ==> 229545524:2019340
131: SKP: 20480( 5 blks) ==> 231564864:12
132: RAW: 2801664( 684 blks) ==> 231564876:2801676
133: SKP: 24576( 6 blks) ==> 234366552:12
134: RAW: 16789504( 4099 blks) ==> 234366564:16789516
135: SKP: 4186112( 1022 blks) ==> 251156080:12
136: RAW: 819200( 200 blks) ==> 251156092:819212
137: SKP: 49152( 12 blks) ==> 251975304:12
138: RAW: 4096( 1 blks) ==> 251975316:4108
139: SKP: 172032( 42 blks) ==> 251979424:12
140: RAW: 20480( 5 blks) ==> 251979436:20492
141: SKP: 110592( 27 blks) ==> 251999928:12
142: RAW: 98304( 24 blks) ==> 251999940:98316
143: SKP: 32768( 8 blks) ==> 252098256:12
144: RAW: 167936( 41 blks) ==> 252098268:167948
145: SKP: 94208( 23 blks) ==> 252266216:12
146: RAW: 2392064( 584 blks) ==> 252266228:2392076
147: SKP: 229376( 56 blks) ==> 254658304:12
148: RAW: 35856384( 8754 blks) ==> 254658316:35856396
149: SKP: 4096( 1 blks) ==> 290514712:12
150: RAW: 1413120( 345 blks) ==> 290514724:1413132
151: SKP: 4096( 1 blks) ==> 291927856:12
152: RAW: 1146880( 280 blks) ==> 291927868:1146892
153: SKP: 8192( 2 blks) ==> 293074760:12
154: RAW: 2760704( 674 blks) ==> 293074772:2760716
155: SKP: 4096( 1 blks) ==> 295835488:12
156: RAW: 16384( 4 blks) ==> 295835500:16396
157: SKP: 4096( 1 blks) ==> 295851896:12
158: RAW: 344064( 84 blks) ==> 295851908:344076
159: SKP: 4096( 1 blks) ==> 296195984:12
160: RAW: 12288( 3 blks) ==> 296195996:12300
161: SKP: 86016( 21 blks) ==> 296208296:12
162: RAW: 122880( 30 blks) ==> 296208308:122892
163: SKP: 4096( 1 blks) ==> 296331200:12
164: RAW: 479232( 117 blks) ==> 296331212:479244
165: SKP: 49152( 12 blks) ==> 296810456:12
166: RAW: 4096( 1 blks) ==> 296810468:4108
167: SKP: 208896( 51 blks) ==> 296814576:12
168: RAW: 307200( 75 blks) ==> 296814588:307212
169: SKP: 86016( 21 blks) ==> 297121800:12
170: RAW: 282624( 69 blks) ==> 297121812:282636
171: SKP: 24576( 6 blks) ==> 297404448:12
172: RAW: 8192( 2 blks) ==> 297404460:8204
173: SKP: 57344( 14 blks) ==> 297412664:12
174: RAW: 4096( 1 blks) ==> 297412676:4108
175: SKP: 12288( 3 blks) ==> 297416784:12
176: RAW: 4096( 1 blks) ==> 297416796:4108
177: SKP: 45056( 11 blks) ==> 297420904:12
178: RAW: 4096( 1 blks) ==> 297420916:4108
179: SKP: 61440( 15 blks) ==> 297425024:12
180: RAW: 12288( 3 blks) ==> 297425036:12300
181: SKP: 28672( 7 blks) ==> 297437336:12
182: RAW: 16384( 4 blks) ==> 297437348:16396
183: SKP: 552960( 135 blks) ==> 297453744:12
184: RAW: 2961408( 723 blks) ==> 297453756:2961420
185: SKP: 4096( 1 blks) ==> 300415176:12
186: RAW: 4096( 1 blks) ==> 300415188:4108
187: SKP: 4096( 1 blks) ==> 300419296:12
188: RAW: 8192( 2 blks) ==> 300419308:8204
189: SKP: 4096( 1 blks) ==> 300427512:12
190: RAW: 4096( 1 blks) ==> 300427524:4108
191: SKP: 4096( 1 blks) ==> 300431632:12
192: RAW: 16384( 4 blks) ==> 300431644:16396
193: SKP: 4096( 1 blks) ==> 300448040:12
194: RAW: 2224128( 543 blks) ==> 300448052:2224140
195: SKP: 8192( 2 blks) ==> 302672192:12
196: RAW: 32768( 8 blks) ==> 302672204:32780
197: SKP: 12288( 3 blks) ==> 302704984:12
198: RAW: 8192( 2 blks) ==> 302704996:8204
199: SKP: 4096( 1 blks) ==> 302713200:12
200: RAW: 12288( 3 blks) ==> 302713212:12300
201: SKP: 24576( 6 blks) ==> 302725512:12
202: RAW: 8192( 2 blks) ==> 302725524:8204
203: SKP: 942080( 230 blks) ==> 302733728:12
204: RAW: 937984( 229 blks) ==> 302733740:937996
205: SKP: 12288( 3 blks) ==> 303671736:12
206: RAW: 12288( 3 blks) ==> 303671748:12300
207: SKP: 86016( 21 blks) ==> 303684048:12
208: RAW: 19312640( 4715 blks) ==> 303684060:19312652
209: SKP: 4096( 1 blks) ==> 322996712:12
210: RAW: 2560000( 625 blks) ==> 322996724:2560012
211: SKP: 8192( 2 blks) ==> 325556736:12
212: RAW: 2871296( 701 blks) ==> 325556748:2871308
213: SKP: 4096( 1 blks) ==> 328428056:12
214: RAW: 16384( 4 blks) ==> 328428068:16396
215: SKP: 4096( 1 blks) ==> 328444464:12
216: RAW: 344064( 84 blks) ==> 328444476:344076
217: SKP: 4096( 1 blks) ==> 328788552:12
218: RAW: 12288( 3 blks) ==> 328788564:12300
219: SKP: 86016( 21 blks) ==> 328800864:12
220: RAW: 122880( 30 blks) ==> 328800876:122892
221: SKP: 4096( 1 blks) ==> 328923768:12
222: RAW: 479232( 117 blks) ==> 328923780:479244
223: SKP: 49152( 12 blks) ==> 329403024:12
224: RAW: 4096( 1 blks) ==> 329403036:4108
225: SKP: 204800( 50 blks) ==> 329407144:12
226: RAW: 245760( 60 blks) ==> 329407156:245772
227: SKP: 90112( 22 blks) ==> 329652928:12
228: RAW: 282624( 69 blks) ==> 329652940:282636
229: SKP: 24576( 6 blks) ==> 329935576:12
230: RAW: 8192( 2 blks) ==> 329935588:8204
231: SKP: 86016( 21 blks) ==> 329943792:12
232: RAW: 4096( 1 blks) ==> 329943804:4108
233: SKP: 12288( 3 blks) ==> 329947912:12
234: RAW: 4096( 1 blks) ==> 329947924:4108
235: SKP: 61440( 15 blks) ==> 329952032:12
236: RAW: 4096( 1 blks) ==> 329952044:4108
237: SKP: 77824( 19 blks) ==> 329956152:12
238: RAW: 4096( 1 blks) ==> 329956164:4108
239: SKP: 4096( 1 blks) ==> 329960272:12
240: RAW: 4096( 1 blks) ==> 329960284:4108
241: SKP: 28672( 7 blks) ==> 329964392:12
242: RAW: 1097728( 268 blks) ==> 329964404:1097740
243: SKP: 4096( 1 blks) ==> 331062144:12
244: RAW: 172032( 42 blks) ==> 331062156:172044
245: SKP: 8192( 2 blks) ==> 331234200:12
246: RAW: 184320( 45 blks) ==> 331234212:184332
247: SKP: 8192( 2 blks) ==> 331418544:12
248: RAW: 212992( 52 blks) ==> 331418556:213004
249: SKP: 16384( 4 blks) ==> 331631560:12
250: RAW: 16384( 4 blks) ==> 331631572:16396
251: SKP: 3751936( 916 blks) ==> 331647968:12
252: RAW: 7811072( 1907 blks) ==> 331647980:7811084
253: SKP: 12288( 3 blks) ==> 339459064:12
254: RAW: 73728( 18 blks) ==> 339459076:73740
255: SKP: 12288( 3 blks) ==> 339532816:12
256: RAW: 73728( 18 blks) ==> 339532828:73740
257: SKP: 12288( 3 blks) ==> 339606568:12
258: RAW: 69632( 17 blks) ==> 339606580:69644
259: SKP: 16384( 4 blks) ==> 339676224:12
260: RAW: 69632( 17 blks) ==> 339676236:69644
261: SKP: 16384( 4 blks) ==> 339745880:12
262: RAW: 61440( 15 blks) ==> 339745892:61452
263: SKP: 16384( 4 blks) ==> 339807344:12
264: RAW: 65536( 16 blks) ==> 339807356:65548
265: SKP: 4096( 1 blks) ==> 339872904:12
266: RAW: 37621760( 9185 blks) ==> 339872916:37621772
267: SKP: 49152( 12 blks) ==> 377494688:12
268: RAW: 4096( 1 blks) ==> 377494700:4108
269: SKP: 61440( 15 blks) ==> 377498808:12
270: RAW: 20480( 5 blks) ==> 377498820:20492
271: SKP: 16384( 4 blks) ==> 377519312:12
272: RAW: 7467008( 1823 blks) ==> 377519324:7467020
273: SKP: 61440( 15 blks) ==> 384986344:12
274: RAW: 16384( 4 blks) ==> 384986356:16396
275: SKP: 45056( 11 blks) ==> 385002752:12
276: RAW: 139264( 34 blks) ==> 385002764:139276
277: SKP: 12288( 3 blks) ==> 385142040:12
278: RAW: 20480( 5 blks) ==> 385142052:20492
279: SKP: 12288( 3 blks) ==> 385162544:12
280: RAW: 4096( 1 blks) ==> 385162556:4108
281: SKP: 12288( 3 blks) ==> 385166664:12
282: RAW: 28672( 7 blks) ==> 385166676:28684
283: SKP: 4096( 1 blks) ==> 385195360:12
284: RAW: 8192( 2 blks) ==> 385195372:8204
285: SKP: 4096( 1 blks) ==> 385203576:12
286: RAW: 4096( 1 blks) ==> 385203588:4108
287: SKP: 4096( 1 blks) ==> 385207696:12
288: RAW: 12288( 3 blks) ==> 385207708:12300
289: SKP: 8192( 2 blks) ==> 385220008:12
290: RAW: 24576( 6 blks) ==> 385220020:24588
291: SKP: 12288( 3 blks) ==> 385244608:12
292: RAW: 135168( 33 blks) ==> 385244620:135180
293: SKP: 24576( 6 blks) ==> 385379800:12
294: RAW: 2244608( 548 blks) ==> 385379812:2244620
295: SKP: 16384( 4 blks) ==> 387624432:12
296: RAW: 20480( 5 blks) ==> 387624444:20492
297: SKP: 4096( 1 blks) ==> 387644936:12
298: RAW: 933888( 228 blks) ==> 387644948:933900
299: SKP: 1351680( 330 blks) ==> 388578848:12
300: RAW: 38526976( 9406 blks) ==> 388578860:38526988
301: SKP: 16384( 4 blks) ==> 427105848:12
302: RAW: 8192( 2 blks) ==> 427105860:8204
303: SKP: 16384( 4 blks) ==> 427114064:12
304: RAW: 32768( 8 blks) ==> 427114076:32780
305: SKP: 4096( 1 blks) ==> 427146856:12
306: RAW: 4096( 1 blks) ==> 427146868:4108
307: SKP: 12288( 3 blks) ==> 427150976:12
308: RAW: 8192( 2 blks) ==> 427150988:8204
309: SKP: 12288( 3 blks) ==> 427159192:12
310: RAW: 8192( 2 blks) ==> 427159204:8204
311: SKP: 8192( 2 blks) ==> 427167408:12
312: RAW: 28672( 7 blks) ==> 427167420:28684
313: SKP: 4096( 1 blks) ==> 427196104:12
314: RAW: 4096( 1 blks) ==> 427196116:4108
315: SKP: 12288( 3 blks) ==> 427200224:12
316: RAW: 8192( 2 blks) ==> 427200236:8204
317: SKP: 12288( 3 blks) ==> 427208440:12
318: RAW: 32768( 8 blks) ==> 427208452:32780
319: SKP: 12288( 3 blks) ==> 427241232:12
320: RAW: 8192( 2 blks) ==> 427241244:8204
321: SKP: 12288( 3 blks) ==> 427249448:12
322: RAW: 4096( 1 blks) ==> 427249460:4108
323: SKP: 12288( 3 blks) ==> 427253568:12
324: RAW: 8192( 2 blks) ==> 427253580:8204
325: SKP: 12288( 3 blks) ==> 427261784:12
326: RAW: 8192( 2 blks) ==> 427261796:8204
327: SKP: 12288( 3 blks) ==> 427270000:12
328: RAW: 4096( 1 blks) ==> 427270012:4108
329: SKP: 12288( 3 blks) ==> 427274120:12
330: RAW: 8192( 2 blks) ==> 427274132:8204
331: SKP: 12288( 3 blks) ==> 427282336:12
332: RAW: 8192( 2 blks) ==> 427282348:8204
333: SKP: 12288( 3 blks) ==> 427290552:12
334: RAW: 4096( 1 blks) ==> 427290564:4108
335: SKP: 12288( 3 blks) ==> 427294672:12
336: RAW: 8192( 2 blks) ==> 427294684:8204
337: SKP: 12288( 3 blks) ==> 427302888:12
338: RAW: 8192( 2 blks) ==> 427302900:8204
339: SKP: 12288( 3 blks) ==> 427311104:12
340: RAW: 4096( 1 blks) ==> 427311116:4108
341: SKP: 12288( 3 blks) ==> 427315224:12
342: RAW: 8192( 2 blks) ==> 427315236:8204
343: SKP: 12288( 3 blks) ==> 427323440:12
344: RAW: 8192( 2 blks) ==> 427323452:8204
345: SKP: 12288( 3 blks) ==> 427331656:12
346: RAW: 4096( 1 blks) ==> 427331668:4108
347: SKP: 12288( 3 blks) ==> 427335776:12
348: RAW: 8192( 2 blks) ==> 427335788:8204
349: SKP: 12288( 3 blks) ==> 427343992:12
350: RAW: 4096( 1 blks) ==> 427344004:4108
351: SKP: 12288( 3 blks) ==> 427348112:12
352: RAW: 8192( 2 blks) ==> 427348124:8204
353: SKP: 12288( 3 blks) ==> 427356328:12
354: RAW: 4096( 1 blks) ==> 427356340:4108
355: SKP: 12288( 3 blks) ==> 427360448:12
356: RAW: 8192( 2 blks) ==> 427360460:8204
357: SKP: 12288( 3 blks) ==> 427368664:12
358: RAW: 4096( 1 blks) ==> 427368676:4108
359: SKP: 12288( 3 blks) ==> 427372784:12
360: RAW: 8192( 2 blks) ==> 427372796:8204
361: SKP: 12288( 3 blks) ==> 427381000:12
362: RAW: 8192( 2 blks) ==> 427381012:8204
363: SKP: 8192( 2 blks) ==> 427389216:12
364: RAW: 8192( 2 blks) ==> 427389228:8204
365: SKP: 4096( 1 blks) ==> 427397432:12
366: RAW: 4096( 1 blks) ==> 427397444:4108
367: SKP: 16384( 4 blks) ==> 427401552:12
368: RAW: 16384( 4 blks) ==> 427401564:16396
369: SKP: 12288( 3 blks) ==> 427417960:12
370: RAW: 8192( 2 blks) ==> 427417972:8204
371: SKP: 4096( 1 blks) ==> 427426176:12
372: RAW: 8192( 2 blks) ==> 427426188:8204
373: SKP: 12288( 3 blks) ==> 427434392:12
374: RAW: 12288( 3 blks) ==> 427434404:12300
375: SKP: 12288( 3 blks) ==> 427446704:12
376: RAW: 8192( 2 blks) ==> 427446716:8204
377: SKP: 12288( 3 blks) ==> 427454920:12
378: RAW: 8192( 2 blks) ==> 427454932:8204
379: SKP: 12288( 3 blks) ==> 427463136:12
380: RAW: 8192( 2 blks) ==> 427463148:8204
381: SKP: 12288( 3 blks) ==> 427471352:12
382: RAW: 8192( 2 blks) ==> 427471364:8204
383: SKP: 12288( 3 blks) ==> 427479568:12
384: RAW: 4096( 1 blks) ==> 427479580:4108
385: SKP: 12288( 3 blks) ==> 427483688:12
386: RAW: 8192( 2 blks) ==> 427483700:8204
387: SKP: 12288( 3 blks) ==> 427491904:12
388: RAW: 8192( 2 blks) ==> 427491916:8204
389: SKP: 12288( 3 blks) ==> 427500120:12
390: RAW: 4096( 1 blks) ==> 427500132:4108
391: SKP: 12288( 3 blks) ==> 427504240:12
392: RAW: 8192( 2 blks) ==> 427504252:8204
393: SKP: 12288( 3 blks) ==> 427512456:12
394: RAW: 4096( 1 blks) ==> 427512468:4108
395: SKP: 12288( 3 blks) ==> 427516576:12
396: RAW: 8192( 2 blks) ==> 427516588:8204
397: SKP: 12288( 3 blks) ==> 427524792:12
398: RAW: 8192( 2 blks) ==> 427524804:8204
399: SKP: 8192( 2 blks) ==> 427533008:12
400: RAW: 8192( 2 blks) ==> 427533020:8204
401: SKP: 12288( 3 blks) ==> 427541224:12
402: RAW: 8192( 2 blks) ==> 427541236:8204
403: SKP: 12288( 3 blks) ==> 427549440:12
404: RAW: 4096( 1 blks) ==> 427549452:4108
405: SKP: 12288( 3 blks) ==> 427553560:12
406: RAW: 8192( 2 blks) ==> 427553572:8204
407: SKP: 12288( 3 blks) ==> 427561776:12
408: RAW: 4096( 1 blks) ==> 427561788:4108
409: SKP: 12288( 3 blks) ==> 427565896:12
410: RAW: 8192( 2 blks) ==> 427565908:8204
411: SKP: 12288( 3 blks) ==> 427574112:12
412: RAW: 4096( 1 blks) ==> 427574124:4108
413: SKP: 12288( 3 blks) ==> 427578232:12
414: RAW: 8192( 2 blks) ==> 427578244:8204
415: SKP: 12288( 3 blks) ==> 427586448:12
416: RAW: 4096( 1 blks) ==> 427586460:4108
417: SKP: 12288( 3 blks) ==> 427590568:12
418: RAW: 8192( 2 blks) ==> 427590580:8204
419: SKP: 12288( 3 blks) ==> 427598784:12
420: RAW: 8192( 2 blks) ==> 427598796:8204
421: SKP: 12288( 3 blks) ==> 427607000:12
422: RAW: 4096( 1 blks) ==> 427607012:4108
423: SKP: 12288( 3 blks) ==> 427611120:12
424: RAW: 8192( 2 blks) ==> 427611132:8204
425: SKP: 12288( 3 blks) ==> 427619336:12
426: RAW: 4096( 1 blks) ==> 427619348:4108
427: SKP: 12288( 3 blks) ==> 427623456:12
428: RAW: 4096( 1 blks) ==> 427623468:4108
429: SKP: 4096( 1 blks) ==> 427627576:12
430: RAW: 4096( 1 blks) ==> 427627588:4108
431: SKP: 12288( 3 blks) ==> 427631696:12
432: RAW: 4096( 1 blks) ==> 427631708:4108
433: SKP: 12288( 3 blks) ==> 427635816:12
434: RAW: 8192( 2 blks) ==> 427635828:8204
435: SKP: 12288( 3 blks) ==> 427644032:12
436: RAW: 8192( 2 blks) ==> 427644044:8204
437: SKP: 12288( 3 blks) ==> 427652248:12
438: RAW: 4096( 1 blks) ==> 427652260:4108
439: SKP: 12288( 3 blks) ==> 427656368:12
440: RAW: 8192( 2 blks) ==> 427656380:8204
441: SKP: 12288( 3 blks) ==> 427664584:12
442: RAW: 8192( 2 blks) ==> 427664596:8204
443: SKP: 12288( 3 blks) ==> 427672800:12
444: RAW: 4096( 1 blks) ==> 427672812:4108
445: SKP: 12288( 3 blks) ==> 427676920:12
446: RAW: 8192( 2 blks) ==> 427676932:8204
447: SKP: 12288( 3 blks) ==> 427685136:12
448: RAW: 8192( 2 blks) ==> 427685148:8204
449: SKP: 8192( 2 blks) ==> 427693352:12
450: RAW: 8192( 2 blks) ==> 427693364:8204
451: SKP: 12288( 3 blks) ==> 427701568:12
452: RAW: 8192( 2 blks) ==> 427701580:8204
453: SKP: 12288( 3 blks) ==> 427709784:12
454: RAW: 8192( 2 blks) ==> 427709796:8204
455: SKP: 12288( 3 blks) ==> 427718000:12
456: RAW: 4096( 1 blks) ==> 427718012:4108
457: SKP: 12288( 3 blks) ==> 427722120:12
458: RAW: 8192( 2 blks) ==> 427722132:8204
459: SKP: 12288( 3 blks) ==> 427730336:12
460: RAW: 4096( 1 blks) ==> 427730348:4108
461: SKP: 12288( 3 blks) ==> 427734456:12
462: RAW: 12288( 3 blks) ==> 427734468:12300
463: SKP: 12288( 3 blks) ==> 427746768:12
464: RAW: 8192( 2 blks) ==> 427746780:8204
465: SKP: 12288( 3 blks) ==> 427754984:12
466: RAW: 12288( 3 blks) ==> 427754996:12300
467: SKP: 12288( 3 blks) ==> 427767296:12
468: RAW: 8192( 2 blks) ==> 427767308:8204
469: SKP: 12288( 3 blks) ==> 427775512:12
470: RAW: 8192( 2 blks) ==> 427775524:8204
471: SKP: 12288( 3 blks) ==> 427783728:12
472: RAW: 4096( 1 blks) ==> 427783740:4108
473: SKP: 12288( 3 blks) ==> 427787848:12
474: RAW: 8192( 2 blks) ==> 427787860:8204
475: SKP: 12288( 3 blks) ==> 427796064:12
476: RAW: 8192( 2 blks) ==> 427796076:8204
477: SKP: 8192( 2 blks) ==> 427804280:12
478: RAW: 8192( 2 blks) ==> 427804292:8204
479: SKP: 12288( 3 blks) ==> 427812496:12
480: RAW: 12288( 3 blks) ==> 427812508:12300
481: SKP: 12288( 3 blks) ==> 427824808:12
482: RAW: 12288( 3 blks) ==> 427824820:12300
483: SKP: 12288( 3 blks) ==> 427837120:12
484: RAW: 8192( 2 blks) ==> 427837132:8204
485: SKP: 12288( 3 blks) ==> 427845336:12
486: RAW: 4096( 1 blks) ==> 427845348:4108
487: SKP: 12288( 3 blks) ==> 427849456:12
488: RAW: 8192( 2 blks) ==> 427849468:8204
489: SKP: 12288( 3 blks) ==> 427857672:12
490: RAW: 8192( 2 blks) ==> 427857684:8204
491: SKP: 12288( 3 blks) ==> 427865888:12
492: RAW: 4096( 1 blks) ==> 427865900:4108
493: SKP: 12288( 3 blks) ==> 427870008:12
494: RAW: 8192( 2 blks) ==> 427870020:8204
495: SKP: 12288( 3 blks) ==> 427878224:12
496: RAW: 8192( 2 blks) ==> 427878236:8204
497: SKP: 12288( 3 blks) ==> 427886440:12
498: RAW: 12288( 3 blks) ==> 427886452:12300
499: SKP: 12288( 3 blks) ==> 427898752:12
500: RAW: 8192( 2 blks) ==> 427898764:8204
501: SKP: 12288( 3 blks) ==> 427906968:12
502: RAW: 8192( 2 blks) ==> 427906980:8204
503: SKP: 4096( 1 blks) ==> 427915184:12
504: RAW: 8192( 2 blks) ==> 427915196:8204
505: SKP: 8192( 2 blks) ==> 427923400:12
506: RAW: 8192( 2 blks) ==> 427923412:8204
507: SKP: 12288( 3 blks) ==> 427931616:12
508: RAW: 8192( 2 blks) ==> 427931628:8204
509: SKP: 12288( 3 blks) ==> 427939832:12
510: RAW: 4096( 1 blks) ==> 427939844:4108
511: SKP: 12288( 3 blks) ==> 427943952:12
512: RAW: 8192( 2 blks) ==> 427943964:8204
513: SKP: 12288( 3 blks) ==> 427952168:12
514: RAW: 4096( 1 blks) ==> 427952180:4108
515: SKP: 12288( 3 blks) ==> 427956288:12
516: RAW: 8192( 2 blks) ==> 427956300:8204
517: SKP: 12288( 3 blks) ==> 427964504:12
518: RAW: 4096( 1 blks) ==> 427964516:4108
519: SKP: 12288( 3 blks) ==> 427968624:12
520: RAW: 8192( 2 blks) ==> 427968636:8204
521: SKP: 12288( 3 blks) ==> 427976840:12
522: RAW: 4096( 1 blks) ==> 427976852:4108
523: SKP: 12288( 3 blks) ==> 427980960:12
524: RAW: 8192( 2 blks) ==> 427980972:8204
525: SKP: 12288( 3 blks) ==> 427989176:12
526: RAW: 4096( 1 blks) ==> 427989188:4108
527: SKP: 12288( 3 blks) ==> 427993296:12
528: RAW: 8192( 2 blks) ==> 427993308:8204
529: SKP: 12288( 3 blks) ==> 428001512:12
530: RAW: 4096( 1 blks) ==> 428001524:4108
531: SKP: 12288( 3 blks) ==> 428005632:12
532: RAW: 8192( 2 blks) ==> 428005644:8204
533: SKP: 4096( 1 blks) ==> 428013848:12
534: RAW: 4096( 1 blks) ==> 428013860:4108
535: SKP: 12288( 3 blks) ==> 428017968:12
536: RAW: 4096( 1 blks) ==> 428017980:4108
537: SKP: 4096( 1 blks) ==> 428022088:12
538: RAW: 4096( 1 blks) ==> 428022100:4108
539: SKP: 12288( 3 blks) ==> 428026208:12
540: RAW: 16384( 4 blks) ==> 428026220:16396
541: SKP: 12288( 3 blks) ==> 428042616:12
542: RAW: 4096( 1 blks) ==> 428042628:4108
543: SKP: 4096( 1 blks) ==> 428046736:12
544: RAW: 4096( 1 blks) ==> 428046748:4108
545: SKP: 12288( 3 blks) ==> 428050856:12
546: RAW: 8192( 2 blks) ==> 428050868:8204
547: SKP: 12288( 3 blks) ==> 428059072:12
548: RAW: 4096( 1 blks) ==> 428059084:4108
549: SKP: 12288( 3 blks) ==> 428063192:12
550: RAW: 8192( 2 blks) ==> 428063204:8204
551: SKP: 12288( 3 blks) ==> 428071408:12
552: RAW: 4096( 1 blks) ==> 428071420:4108
553: SKP: 12288( 3 blks) ==> 428075528:12
554: RAW: 8192( 2 blks) ==> 428075540:8204
555: SKP: 12288( 3 blks) ==> 428083744:12
556: RAW: 8192( 2 blks) ==> 428083756:8204
557: SKP: 8192( 2 blks) ==> 428091960:12
558: RAW: 12288( 3 blks) ==> 428091972:12300
559: SKP: 12288( 3 blks) ==> 428104272:12
560: RAW: 8192( 2 blks) ==> 428104284:8204
561: SKP: 12288( 3 blks) ==> 428112488:12
562: RAW: 4096( 1 blks) ==> 428112500:4108
563: SKP: 12288( 3 blks) ==> 428116608:12
564: RAW: 8192( 2 blks) ==> 428116620:8204
565: SKP: 12288( 3 blks) ==> 428124824:12
566: RAW: 4096( 1 blks) ==> 428124836:4108
567: SKP: 12288( 3 blks) ==> 428128944:12
568: RAW: 8192( 2 blks) ==> 428128956:8204
569: SKP: 12288( 3 blks) ==> 428137160:12
570: RAW: 4096( 1 blks) ==> 428137172:4108
571: SKP: 12288( 3 blks) ==> 428141280:12
572: RAW: 8192( 2 blks) ==> 428141292:8204
573: SKP: 12288( 3 blks) ==> 428149496:12
574: RAW: 4096( 1 blks) ==> 428149508:4108
575: SKP: 12288( 3 blks) ==> 428153616:12
576: RAW: 8192( 2 blks) ==> 428153628:8204
577: SKP: 12288( 3 blks) ==> 428161832:12
578: RAW: 4096( 1 blks) ==> 428161844:4108
579: SKP: 12288( 3 blks) ==> 428165952:12
580: RAW: 8192( 2 blks) ==> 428165964:8204
581: SKP: 12288( 3 blks) ==> 428174168:12
582: RAW: 4096( 1 blks) ==> 428174180:4108
583: SKP: 12288( 3 blks) ==> 428178288:12
584: RAW: 8192( 2 blks) ==> 428178300:8204
585: SKP: 12288( 3 blks) ==> 428186504:12
586: RAW: 8192( 2 blks) ==> 428186516:8204
587: SKP: 8192( 2 blks) ==> 428194720:12
588: RAW: 8192( 2 blks) ==> 428194732:8204
589: SKP: 12288( 3 blks) ==> 428202936:12
590: RAW: 8192( 2 blks) ==> 428202948:8204
591: SKP: 12288( 3 blks) ==> 428211152:12
592: RAW: 4096( 1 blks) ==> 428211164:4108
593: SKP: 12288( 3 blks) ==> 428215272:12
594: RAW: 8192( 2 blks) ==> 428215284:8204
595: SKP: 12288( 3 blks) ==> 428223488:12
596: RAW: 4096( 1 blks) ==> 428223500:4108
597: SKP: 12288( 3 blks) ==> 428227608:12
598: RAW: 8192( 2 blks) ==> 428227620:8204
599: SKP: 12288( 3 blks) ==> 428235824:12
600: RAW: 4096( 1 blks) ==> 428235836:4108
601: SKP: 12288( 3 blks) ==> 428239944:12
602: RAW: 8192( 2 blks) ==> 428239956:8204
603: SKP: 12288( 3 blks) ==> 428248160:12
604: RAW: 4096( 1 blks) ==> 428248172:4108
605: SKP: 12288( 3 blks) ==> 428252280:12
606: RAW: 8192( 2 blks) ==> 428252292:8204
607: SKP: 12288( 3 blks) ==> 428260496:12
608: RAW: 4096( 1 blks) ==> 428260508:4108
609: SKP: 12288( 3 blks) ==> 428264616:12
610: RAW: 8192( 2 blks) ==> 428264628:8204
611: SKP: 12288( 3 blks) ==> 428272832:12
612: RAW: 8192( 2 blks) ==> 428272844:8204
613: SKP: 12288( 3 blks) ==> 428281048:12
614: RAW: 4096( 1 blks) ==> 428281060:4108
615: SKP: 12288( 3 blks) ==> 428285168:12
616: RAW: 8192( 2 blks) ==> 428285180:8204
617: SKP: 12288( 3 blks) ==> 428293384:12
618: RAW: 8192( 2 blks) ==> 428293396:8204
619: SKP: 12288( 3 blks) ==> 428301600:12
620: RAW: 4096( 1 blks) ==> 428301612:4108
621: SKP: 12288( 3 blks) ==> 428305720:12
622: RAW: 8192( 2 blks) ==> 428305732:8204
623: SKP: 12288( 3 blks) ==> 428313936:12
624: RAW: 4096( 1 blks) ==> 428313948:4108
625: SKP: 12288( 3 blks) ==> 428318056:12
626: RAW: 8192( 2 blks) ==> 428318068:8204
627: SKP: 12288( 3 blks) ==> 428326272:12
628: RAW: 8192( 2 blks) ==> 428326284:8204
629: SKP: 8192( 2 blks) ==> 428334488:12
630: RAW: 8192( 2 blks) ==> 428334500:8204
631: SKP: 12288( 3 blks) ==> 428342704:12
632: RAW: 8192( 2 blks) ==> 428342716:8204
633: SKP: 12288( 3 blks) ==> 428350920:12
634: RAW: 4096( 1 blks) ==> 428350932:4108
635: SKP: 12288( 3 blks) ==> 428355040:12
636: RAW: 8192( 2 blks) ==> 428355052:8204
637: SKP: 12288( 3 blks) ==> 428363256:12
638: RAW: 4096( 1 blks) ==> 428363268:4108
639: SKP: 12288( 3 blks) ==> 428367376:12
640: RAW: 8192( 2 blks) ==> 428367388:8204
641: SKP: 4096( 1 blks) ==> 428375592:12
642: RAW: 4096( 1 blks) ==> 428375604:4108
643: SKP: 12288( 3 blks) ==> 428379712:12
644: RAW: 8192( 2 blks) ==> 428379724:8204
645: SKP: 12288( 3 blks) ==> 428387928:12
646: RAW: 4096( 1 blks) ==> 428387940:4108
647: SKP: 12288( 3 blks) ==> 428392048:12
648: RAW: 4096( 1 blks) ==> 428392060:4108
649: SKP: 12288( 3 blks) ==> 428396168:12
650: RAW: 12288( 3 blks) ==> 428396180:12300
651: SKP: 12288( 3 blks) ==> 428408480:12
652: RAW: 4096( 1 blks) ==> 428408492:4108
653: SKP: 12288( 3 blks) ==> 428412600:12
654: RAW: 8192( 2 blks) ==> 428412612:8204
655: SKP: 12288( 3 blks) ==> 428420816:12
656: RAW: 4096( 1 blks) ==> 428420828:4108
657: SKP: 12288( 3 blks) ==> 428424936:12
658: RAW: 8192( 2 blks) ==> 428424948:8204
659: SKP: 12288( 3 blks) ==> 428433152:12
660: RAW: 8192( 2 blks) ==> 428433164:8204
661: SKP: 12288( 3 blks) ==> 428441368:12
662: RAW: 4096( 1 blks) ==> 428441380:4108
663: SKP: 12288( 3 blks) ==> 428445488:12
664: RAW: 8192( 2 blks) ==> 428445500:8204
665: SKP: 12288( 3 blks) ==> 428453704:12
666: RAW: 8192( 2 blks) ==> 428453716:8204
667: SKP: 12288( 3 blks) ==> 428461920:12
668: RAW: 4096( 1 blks) ==> 428461932:4108
669: SKP: 12288( 3 blks) ==> 428466040:12
670: RAW: 8192( 2 blks) ==> 428466052:8204
671: SKP: 12288( 3 blks) ==> 428474256:12
672: RAW: 8192( 2 blks) ==> 428474268:8204
673: SKP: 12288( 3 blks) ==> 428482472:12
674: RAW: 122880( 30 blks) ==> 428482484:122892
675: SKP: 12288( 3 blks) ==> 428605376:12
676: RAW: 8192( 2 blks) ==> 428605388:8204
677: SKP: 12288( 3 blks) ==> 428613592:12
678: RAW: 4096( 1 blks) ==> 428613604:4108
679: SKP: 12288( 3 blks) ==> 428617712:12
680: RAW: 8192( 2 blks) ==> 428617724:8204
681: SKP: 24576( 6 blks) ==> 428625928:12
682: RAW: 73728( 18 blks) ==> 428625940:73740
683: SKP: 12288( 3 blks) ==> 428699680:12
684: RAW: 8192( 2 blks) ==> 428699692:8204
685: SKP: 12288( 3 blks) ==> 428707896:12
686: RAW: 8192( 2 blks) ==> 428707908:8204
687: SKP: 12288( 3 blks) ==> 428716112:12
688: RAW: 4096( 1 blks) ==> 428716124:4108
689: SKP: 12288( 3 blks) ==> 428720232:12
690: RAW: 12288( 3 blks) ==> 428720244:12300
691: SKP: 8192( 2 blks) ==> 428732544:12
692: RAW: 12288( 3 blks) ==> 428732556:12300
693: SKP: 12288( 3 blks) ==> 428744856:12
694: RAW: 8192( 2 blks) ==> 428744868:8204
695: SKP: 12288( 3 blks) ==> 428753072:12
696: RAW: 8192( 2 blks) ==> 428753084:8204
697: SKP: 12288( 3 blks) ==> 428761288:12
698: RAW: 8192( 2 blks) ==> 428761300:8204
699: SKP: 12288( 3 blks) ==> 428769504:12
700: RAW: 4096( 1 blks) ==> 428769516:4108
701: SKP: 4096( 1 blks) ==> 428773624:12
702: RAW: 4096( 1 blks) ==> 428773636:4108
703: SKP: 12288( 3 blks) ==> 428777744:12
704: RAW: 4096( 1 blks) ==> 428777756:4108
705: SKP: 8192( 2 blks) ==> 428781864:12
706: RAW: 4096( 1 blks) ==> 428781876:4108
707: SKP: 4096( 1 blks) ==> 428785984:12
708: RAW: 4096( 1 blks) ==> 428785996:4108
709: SKP: 4096( 1 blks) ==> 428790104:12
710: RAW: 16384( 4 blks) ==> 428790116:16396
711: SKP: 4096( 1 blks) ==> 428806512:12
712: RAW: 4096( 1 blks) ==> 428806524:4108
713: SKP: 4096( 1 blks) ==> 428810632:12
714: RAW: 4096( 1 blks) ==> 428810644:4108
715: SKP: 8192( 2 blks) ==> 428814752:12
716: RAW: 12288( 3 blks) ==> 428814764:12300
717: SKP: 4096( 1 blks) ==> 428827064:12
718: RAW: 4096( 1 blks) ==> 428827076:4108
719: SKP: 4096( 1 blks) ==> 428831184:12
720: RAW: 4096( 1 blks) ==> 428831196:4108
721: SKP: 8192( 2 blks) ==> 428835304:12
722: RAW: 4096( 1 blks) ==> 428835316:4108
723: SKP: 4096( 1 blks) ==> 428839424:12
724: RAW: 4096( 1 blks) ==> 428839436:4108
725: SKP: 4096( 1 blks) ==> 428843544:12
726: RAW: 16384( 4 blks) ==> 428843556:16396
727: SKP: 4096( 1 blks) ==> 428859952:12
728: RAW: 4096( 1 blks) ==> 428859964:4108
729: SKP: 4096( 1 blks) ==> 428864072:12
730: RAW: 4096( 1 blks) ==> 428864084:4108
731: SKP: 4096( 1 blks) ==> 428868192:12
732: RAW: 16384( 4 blks) ==> 428868204:16396
733: SKP: 4096( 1 blks) ==> 428884600:12
734: RAW: 4096( 1 blks) ==> 428884612:4108
735: SKP: 4096( 1 blks) ==> 428888720:12
736: RAW: 4096( 1 blks) ==> 428888732:4108
737: SKP: 8192( 2 blks) ==> 428892840:12
738: RAW: 12288( 3 blks) ==> 428892852:12300
739: SKP: 4096( 1 blks) ==> 428905152:12
740: RAW: 4096( 1 blks) ==> 428905164:4108
741: SKP: 4096( 1 blks) ==> 428909272:12
742: RAW: 4096( 1 blks) ==> 428909284:4108
743: SKP: 8192( 2 blks) ==> 428913392:12
744: RAW: 4096( 1 blks) ==> 428913404:4108
745: SKP: 4096( 1 blks) ==> 428917512:12
746: RAW: 4096( 1 blks) ==> 428917524:4108
747: SKP: 4096( 1 blks) ==> 428921632:12
748: RAW: 12288( 3 blks) ==> 428921644:12300
749: SKP: 8192( 2 blks) ==> 428933944:12
750: RAW: 4096( 1 blks) ==> 428933956:4108
751: SKP: 4096( 1 blks) ==> 428938064:12
752: RAW: 4096( 1 blks) ==> 428938076:4108
753: SKP: 4096( 1 blks) ==> 428942184:12
754: RAW: 16384( 4 blks) ==> 428942196:16396
755: SKP: 4096( 1 blks) ==> 428958592:12
756: RAW: 4096( 1 blks) ==> 428958604:4108
757: SKP: 4096( 1 blks) ==> 428962712:12
758: RAW: 4096( 1 blks) ==> 428962724:4108
759: SKP: 8192( 2 blks) ==> 428966832:12
760: RAW: 12288( 3 blks) ==> 428966844:12300
761: SKP: 4096( 1 blks) ==> 428979144:12
762: RAW: 4096( 1 blks) ==> 428979156:4108
763: SKP: 4096( 1 blks) ==> 428983264:12
764: RAW: 4096( 1 blks) ==> 428983276:4108
765: SKP: 8192( 2 blks) ==> 428987384:12
766: RAW: 12288( 3 blks) ==> 428987396:12300
767: SKP: 4096( 1 blks) ==> 428999696:12
768: RAW: 4096( 1 blks) ==> 428999708:4108
769: SKP: 4096( 1 blks) ==> 429003816:12
770: RAW: 4096( 1 blks) ==> 429003828:4108
771: SKP: 8192( 2 blks) ==> 429007936:12
772: RAW: 4096( 1 blks) ==> 429007948:4108
773: SKP: 4096( 1 blks) ==> 429012056:12
774: RAW: 4096( 1 blks) ==> 429012068:4108
775: SKP: 4096( 1 blks) ==> 429016176:12
776: RAW: 16384( 4 blks) ==> 429016188:16396
777: SKP: 4096( 1 blks) ==> 429032584:12
778: RAW: 4096( 1 blks) ==> 429032596:4108
779: SKP: 4096( 1 blks) ==> 429036704:12
780: RAW: 4096( 1 blks) ==> 429036716:4108
781: SKP: 4096( 1 blks) ==> 429040824:12
782: RAW: 16384( 4 blks) ==> 429040836:16396
783: SKP: 4096( 1 blks) ==> 429057232:12
784: RAW: 4096( 1 blks) ==> 429057244:4108
785: SKP: 4096( 1 blks) ==> 429061352:12
786: RAW: 4096( 1 blks) ==> 429061364:4108
787: SKP: 8192( 2 blks) ==> 429065472:12
788: RAW: 12288( 3 blks) ==> 429065484:12300
789: SKP: 4096( 1 blks) ==> 429077784:12
790: RAW: 4096( 1 blks) ==> 429077796:4108
791: SKP: 4096( 1 blks) ==> 429081904:12
792: RAW: 4096( 1 blks) ==> 429081916:4108
793: SKP: 8192( 2 blks) ==> 429086024:12
794: RAW: 4096( 1 blks) ==> 429086036:4108
795: SKP: 4096( 1 blks) ==> 429090144:12
796: RAW: 4096( 1 blks) ==> 429090156:4108
797: SKP: 4096( 1 blks) ==> 429094264:12
798: RAW: 12288( 3 blks) ==> 429094276:12300
799: SKP: 8192( 2 blks) ==> 429106576:12
800: RAW: 4096( 1 blks) ==> 429106588:4108
801: SKP: 4096( 1 blks) ==> 429110696:12
802: RAW: 4096( 1 blks) ==> 429110708:4108
803: SKP: 4096( 1 blks) ==> 429114816:12
804: RAW: 16384( 4 blks) ==> 429114828:16396
805: SKP: 4096( 1 blks) ==> 429131224:12
806: RAW: 4096( 1 blks) ==> 429131236:4108
807: SKP: 4096( 1 blks) ==> 429135344:12
808: RAW: 4096( 1 blks) ==> 429135356:4108
809: SKP: 8192( 2 blks) ==> 429139464:12
810: RAW: 12288( 3 blks) ==> 429139476:12300
811: SKP: 4096( 1 blks) ==> 429151776:12
812: RAW: 4096( 1 blks) ==> 429151788:4108
813: SKP: 4096( 1 blks) ==> 429155896:12
814: RAW: 4096( 1 blks) ==> 429155908:4108
815: SKP: 8192( 2 blks) ==> 429160016:12
816: RAW: 4096( 1 blks) ==> 429160028:4108
817: SKP: 4096( 1 blks) ==> 429164136:12
818: RAW: 4096( 1 blks) ==> 429164148:4108
819: SKP: 4096( 1 blks) ==> 429168256:12
820: RAW: 12288( 3 blks) ==> 429168268:12300
821: SKP: 8192( 2 blks) ==> 429180568:12
822: RAW: 4096( 1 blks) ==> 429180580:4108
823: SKP: 4096( 1 blks) ==> 429184688:12
824: RAW: 4096( 1 blks) ==> 429184700:4108
825: SKP: 4096( 1 blks) ==> 429188808:12
826: RAW: 16384( 4 blks) ==> 429188820:16396
827: SKP: 4096( 1 blks) ==> 429205216:12
828: RAW: 4096( 1 blks) ==> 429205228:4108
829: SKP: 4096( 1 blks) ==> 429209336:12
830: RAW: 4096( 1 blks) ==> 429209348:4108
831: SKP: 8192( 2 blks) ==> 429213456:12
832: RAW: 12288( 3 blks) ==> 429213468:12300
833: SKP: 4096( 1 blks) ==> 429225768:12
834: RAW: 4096( 1 blks) ==> 429225780:4108
835: SKP: 4096( 1 blks) ==> 429229888:12
836: RAW: 4096( 1 blks) ==> 429229900:4108
837: SKP: 8192( 2 blks) ==> 429234008:12
838: RAW: 12288( 3 blks) ==> 429234020:12300
839: SKP: 4096( 1 blks) ==> 429246320:12
840: RAW: 4096( 1 blks) ==> 429246332:4108
841: SKP: 4096( 1 blks) ==> 429250440:12
842: RAW: 4096( 1 blks) ==> 429250452:4108
843: SKP: 8192( 2 blks) ==> 429254560:12
844: RAW: 4096( 1 blks) ==> 429254572:4108
845: SKP: 4096( 1 blks) ==> 429258680:12
846: RAW: 4096( 1 blks) ==> 429258692:4108
847: SKP: 4096( 1 blks) ==> 429262800:12
848: RAW: 16384( 4 blks) ==> 429262812:16396
849: SKP: 4096( 1 blks) ==> 429279208:12
850: RAW: 4096( 1 blks) ==> 429279220:4108
851: SKP: 4096( 1 blks) ==> 429283328:12
852: RAW: 4096( 1 blks) ==> 429283340:4108
853: SKP: 4096( 1 blks) ==> 429287448:12
854: RAW: 16384( 4 blks) ==> 429287460:16396
855: SKP: 4096( 1 blks) ==> 429303856:12
856: RAW: 4096( 1 blks) ==> 429303868:4108
857: SKP: 4096( 1 blks) ==> 429307976:12
858: RAW: 4096( 1 blks) ==> 429307988:4108
859: SKP: 8192( 2 blks) ==> 429312096:12
860: RAW: 12288( 3 blks) ==> 429312108:12300
861: SKP: 4096( 1 blks) ==> 429324408:12
862: RAW: 4096( 1 blks) ==> 429324420:4108
863: SKP: 4096( 1 blks) ==> 429328528:12
864: RAW: 4096( 1 blks) ==> 429328540:4108
865: SKP: 8192( 2 blks) ==> 429332648:12
866: RAW: 4096( 1 blks) ==> 429332660:4108
867: SKP: 4096( 1 blks) ==> 429336768:12
868: RAW: 4096( 1 blks) ==> 429336780:4108
869: SKP: 4096( 1 blks) ==> 429340888:12
870: RAW: 8192( 2 blks) ==> 429340900:8204
871: SKP: 12288( 3 blks) ==> 429349104:12
872: RAW: 4096( 1 blks) ==> 429349116:4108
873: SKP: 12288( 3 blks) ==> 429353224:12
874: RAW: 8192( 2 blks) ==> 429353236:8204
875: SKP: 12288( 3 blks) ==> 429361440:12
876: RAW: 8192( 2 blks) ==> 429361452:8204
877: SKP: 12288( 3 blks) ==> 429369656:12
878: RAW: 4096( 1 blks) ==> 429369668:4108
879: SKP: 12288( 3 blks) ==> 429373776:12
880: RAW: 8192( 2 blks) ==> 429373788:8204
881: SKP: 12288( 3 blks) ==> 429381992:12
882: RAW: 4096( 1 blks) ==> 429382004:4108
883: SKP: 12288( 3 blks) ==> 429386112:12
884: RAW: 8192( 2 blks) ==> 429386124:8204
885: SKP: 12288( 3 blks) ==> 429394328:12
886: RAW: 4096( 1 blks) ==> 429394340:4108
887: SKP: 12288( 3 blks) ==> 429398448:12
888: RAW: 8192( 2 blks) ==> 429398460:8204
889: SKP: 12288( 3 blks) ==> 429406664:12
890: RAW: 4096( 1 blks) ==> 429406676:4108
891: SKP: 12288( 3 blks) ==> 429410784:12
892: RAW: 8192( 2 blks) ==> 429410796:8204
893: SKP: 12288( 3 blks) ==> 429419000:12
894: RAW: 4096( 1 blks) ==> 429419012:4108
895: SKP: 12288( 3 blks) ==> 429423120:12
896: RAW: 8192( 2 blks) ==> 429423132:8204
897: SKP: 12288( 3 blks) ==> 429431336:12
898: RAW: 8192( 2 blks) ==> 429431348:8204
899: SKP: 8192( 2 blks) ==> 429439552:12
900: RAW: 8192( 2 blks) ==> 429439564:8204
901: SKP: 12288( 3 blks) ==> 429447768:12
902: RAW: 8192( 2 blks) ==> 429447780:8204
903: SKP: 12288( 3 blks) ==> 429455984:12
904: RAW: 4096( 1 blks) ==> 429455996:4108
905: SKP: 12288( 3 blks) ==> 429460104:12
906: RAW: 8192( 2 blks) ==> 429460116:8204
907: SKP: 12288( 3 blks) ==> 429468320:12
908: RAW: 4096( 1 blks) ==> 429468332:4108
909: SKP: 12288( 3 blks) ==> 429472440:12
910: RAW: 4096( 1 blks) ==> 429472452:4108
911: SKP: 4096( 1 blks) ==> 429476560:12
912: RAW: 4096( 1 blks) ==> 429476572:4108
913: SKP: 12288( 3 blks) ==> 429480680:12
914: RAW: 8192( 2 blks) ==> 429480692:8204
915: SKP: 12288( 3 blks) ==> 429488896:12
916: RAW: 4096( 1 blks) ==> 429488908:4108
917: SKP: 12288( 3 blks) ==> 429493016:12
918: RAW: 8192( 2 blks) ==> 429493028:8204
919: SKP: 12288( 3 blks) ==> 429501232:12
920: RAW: 12288( 3 blks) ==> 429501244:12300
921: SKP: 12288( 3 blks) ==> 429513544:12
922: RAW: 4096( 1 blks) ==> 429513556:4108
923: SKP: 12288( 3 blks) ==> 429517664:12
924: RAW: 12288( 3 blks) ==> 429517676:12300
925: SKP: 12288( 3 blks) ==> 429529976:12
926: RAW: 4096( 1 blks) ==> 429529988:4108
927: SKP: 12288( 3 blks) ==> 429534096:12
928: RAW: 8192( 2 blks) ==> 429534108:8204
929: SKP: 12288( 3 blks) ==> 429542312:12
930: RAW: 4096( 1 blks) ==> 429542324:4108
931: SKP: 12288( 3 blks) ==> 429546432:12
932: RAW: 8192( 2 blks) ==> 429546444:8204
933: SKP: 12288( 3 blks) ==> 429554648:12
934: RAW: 4096( 1 blks) ==> 429554660:4108
935: SKP: 12288( 3 blks) ==> 429558768:12
936: RAW: 8192( 2 blks) ==> 429558780:8204
937: SKP: 12288( 3 blks) ==> 429566984:12
938: RAW: 8192( 2 blks) ==> 429566996:8204
939: SKP: 12288( 3 blks) ==> 429575200:12
940: RAW: 4096( 1 blks) ==> 429575212:4108
941: SKP: 12288( 3 blks) ==> 429579320:12
942: RAW: 8192( 2 blks) ==> 429579332:8204
943: SKP: 12288( 3 blks) ==> 429587536:12
944: RAW: 8192( 2 blks) ==> 429587548:8204
945: SKP: 12288( 3 blks) ==> 429595752:12
946: RAW: 4096( 1 blks) ==> 429595764:4108
947: SKP: 12288( 3 blks) ==> 429599872:12
948: RAW: 8192( 2 blks) ==> 429599884:8204
949: SKP: 12288( 3 blks) ==> 429608088:12
950: RAW: 4096( 1 blks) ==> 429608100:4108
951: SKP: 12288( 3 blks) ==> 429612208:12
952: RAW: 8192( 2 blks) ==> 429612220:8204
953: SKP: 12288( 3 blks) ==> 429620424:12
954: RAW: 8192( 2 blks) ==> 429620436:8204
955: SKP: 8192( 2 blks) ==> 429628640:12
956: RAW: 8192( 2 blks) ==> 429628652:8204
957: SKP: 12288( 3 blks) ==> 429636856:12
958: RAW: 8192( 2 blks) ==> 429636868:8204
959: SKP: 12288( 3 blks) ==> 429645072:12
960: RAW: 4096( 1 blks) ==> 429645084:4108
961: SKP: 12288( 3 blks) ==> 429649192:12
962: RAW: 8192( 2 blks) ==> 429649204:8204
963: SKP: 12288( 3 blks) ==> 429657408:12
964: RAW: 8192( 2 blks) ==> 429657420:8204
965: SKP: 12288( 3 blks) ==> 429665624:12
966: RAW: 4096( 1 blks) ==> 429665636:4108
967: SKP: 12288( 3 blks) ==> 429669744:12
968: RAW: 8192( 2 blks) ==> 429669756:8204
969: SKP: 12288( 3 blks) ==> 429677960:12
970: RAW: 8192( 2 blks) ==> 429677972:8204
971: SKP: 12288( 3 blks) ==> 429686176:12
972: RAW: 4096( 1 blks) ==> 429686188:4108
973: SKP: 12288( 3 blks) ==> 429690296:12
974: RAW: 8192( 2 blks) ==> 429690308:8204
975: SKP: 12288( 3 blks) ==> 429698512:12
976: RAW: 4096( 1 blks) ==> 429698524:4108
977: SKP: 12288( 3 blks) ==> 429702632:12
978: RAW: 8192( 2 blks) ==> 429702644:8204
979: SKP: 12288( 3 blks) ==> 429710848:12
980: RAW: 8192( 2 blks) ==> 429710860:8204
981: SKP: 12288( 3 blks) ==> 429719064:12
982: RAW: 4096( 1 blks) ==> 429719076:4108
983: SKP: 12288( 3 blks) ==> 429723184:12
984: RAW: 8192( 2 blks) ==> 429723196:8204
985: SKP: 12288( 3 blks) ==> 429731400:1
[ 2.2658 ] tegrahost_v2 --updatesigheader blob_preboot_d15_prod_cr_sigheader.bin.encrypt blob_preboot_d15_prod_cr_sigheader.bin.hash zerosbk
[ 2.2667 ]
[ 2.2675 ] tegrahost_v2 --align blob_mce_mts_d15_prod_cr.bin
[ 2.2682 ]
[ 2.2689 ] tegrahost_v2 --appendsigheader blob_mce_mts_d15_prod_cr.bin zerosbk
[ 2.2732 ]
[ 2.2743 ] tegrasign_v2 --key None --list blob_mce_mts_d15_prod_cr_sigheader.bin_list.xml
[ 2.2751 ] Assuming zero filled SBK key
[ 2.3212 ]
[ 2.3221 ] tegrahost_v2 --updatesigheader blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt blob_mce_mts_d15_prod_cr_sigheader.bin.hash zerosbk
[ 2.3244 ]
[ 2.3254 ] tegrahost_v2 --align blob_bpmp.bin
[ 2.3263 ]
[ 2.3271 ] tegrahost_v2 --appendsigheader blob_bpmp.bin zerosbk
[ 2.3284 ]
[ 2.3291 ] tegrasign_v2 --key None --list blob_bpmp_sigheader.bin_list.xml
[ 2.3296 ] Assuming zero filled SBK key
[ 2.3434 ]
[ 2.3443 ] tegrahost_v2 --updatesigheader blob_bpmp_sigheader.bin.encrypt blob_bpmp_sigheader.bin.hash zerosbk
[ 2.3453 ]
[ 2.3462 ] tegrahost_v2 --align blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb
[ 2.3467 ]
[ 2.3474 ] tegrahost_v2 --appendsigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb zerosbk
[ 2.3484 ]
[ 2.3492 ] tegrasign_v2 --key None --list blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb_list.xml
[ 2.3496 ] Assuming zero filled SBK key
[ 2.3608 ]
[ 2.3617 ] tegrahost_v2 --updatesigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.hash zerosbk
[ 2.3628 ]
[ 2.3636 ] tegrahost_v2 --align blob_tos.img
[ 2.3642 ]
[ 2.3649 ] tegrahost_v2 --appendsigheader blob_tos.img zerosbk
[ 2.3656 ]
[ 2.3664 ] tegrasign_v2 --key None --list blob_tos_sigheader.img_list.xml
[ 2.3670 ] Assuming zero filled SBK key
[ 2.3688 ]
[ 2.3698 ] tegrahost_v2 --updatesigheader blob_tos_sigheader.img.encrypt blob_tos_sigheader.img.hash zerosbk
[ 2.3706 ]
[ 2.3713 ] tegrahost_v2 --align blob_eks.img
[ 2.3719 ]
[ 2.3726 ] tegrahost_v2 --appendsigheader blob_eks.img zerosbk
[ 2.3733 ]
[ 2.3741 ] tegrasign_v2 --key None --list blob_eks_sigheader.img_list.xml
[ 2.3746 ] Assuming zero filled SBK key
[ 2.3748 ]
[ 2.3757 ] tegrahost_v2 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[ 2.3763 ]
[ 2.3772 ] tegrahost_v2 --align blob_tegra186-quill-p3310-1000-c03-00-base.dtb
[ 2.3778 ]
[ 2.3784 ] tegrahost_v2 --appendsigheader blob_tegra186-quill-p3310-1000-c03-00-base.dtb zerosbk
[ 2.3797 ]
[ 2.3807 ] tegrasign_v2 --key None --list blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb_list.xml
[ 2.3813 ] Assuming zero filled SBK key
[ 2.3900 ]
[ 2.3911 ] tegrahost_v2 --updatesigheader blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.hash zerosbk
[ 2.3925 ]
[ 2.3935 ] tegrahost_v2 --generateblob blob.xml blob.bin
[ 2.3940 ] number of images in blob are 9
[ 2.3942 ] blobsize is 3749384
[ 2.3943 ] Added binary blob_nvtboot_recovery_cpu_sigheader.bin.encrypt of size 190048
[ 2.3954 ] Added binary blob_nvtboot_recovery_sigheader.bin.encrypt of size 79600
[ 2.3957 ] Added binary blob_preboot_d15_prod_cr_sigheader.bin.encrypt of size 63024
[ 2.3960 ] Added binary blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt of size 2076832
[ 2.3966 ] Added binary blob_bpmp_sigheader.bin.encrypt of size 529440
[ 2.3972 ] Added binary blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt of size 466160
[ 2.3979 ] Added binary blob_tos_sigheader.img.encrypt of size 62976
[ 2.3981 ] Added binary blob_eks_sigheader.img.encrypt of size 1488
[ 2.3984 ] Added binary blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt of size 279664
[ 2.3996 ]
[ 2.3997 ] Sending bootloader and pre-requisite binaries
[ 2.4003 ] tegrarcm_v2 --download blob blob.bin
[ 2.4008 ] Applet version 01.00.0000
[ 2.4170 ] Sending blob
[ 2.5428 ]
Error: Return value 1
Command tegrarcm_v2 --download blob blob.bin
Failed flashing t186ref.
Sorry for my typo. It should be “flash.sh”
