I have flashed jetson tx2 using a host system sdk manager has installed in it correctly and i have not found any errors, but while programming i am unable to execue any program thus as checking the directory i could not find cuda, cudnnn etc… kindly clarify this
hi,
from the sdkmanger i have installed everything where can i find the libraries
and i went through the installation guide as for it drivers need to installed before installation of jetson but my sdkmanager didnt contain any thing as provided in the image for the driver installation guide “https://docs.nvidia.com/sdk-manager/install-with-sdkm-drive/index.html”
Are you certain everything installed correctly?
The installation comes in two stages (flash with the OS and then the SDKManager will SSH into the Jetson - I think - rather than USB recovery mode to install the CUDA libraries etc).
Once you get to the stage where it asks you to input the username and password, I find it is best to unplug the USB. I’ve also found that you should also ensure that your systems are connected to the internet or a DNS capable router for this to work properly.
I am not certain about it, but as for the SDK manger the process is completed and finished,
and I am able to do the sample program provided in the website "https://github.com/dusty-nv/jetson-inference/blob/master/docs/imagenet-camera-2.md" and able to activate the camera for recognition although the terminal icon opened as a “question mark”.
i have purchased two jetson tx2, so for the second one i tried removing the usb interlinking the host and jetson tx2 after OS has been flashed and when it asked for the login password it meant with an error that usb has to be linked
The first line is the details you want to look at.
For locating CUDA libraries use the command:
msubs-ai@msubsai-desktop:~$ which nvcc
/usr/local/cuda-10.0/bin/nvcc
And if that returns correctly you can get CUDA version information:
msubs-ai@msubsai-desktop:~$ nvcc --version
Copyright (c) 2005-2018 NVIDIA Corporation
Built on Sun_Sep_30_21:09:22_CDT_2018
Cuda compilation tools, release 10.0, V10.0.166
As for the USB in the installation - my apologies, my understanding of the process is still a little uncertain, even though I’ve done it >15 times. Installing with the USB is probably fine.
Thanks for the comment you provided based on the first post i provided you could know cuda is installed but i dont have the libraries working and that is where i am stuck see i cannot find the " jetson_clock.sh" file in my jetson tx2 which is a basic command
other than cuda how to check cuDNN, TensorRT, computervision and developer tools
And it seems that jetson_clock.sh doesn’t exist. It’s important to note that the video tutorial is using Jetpack 3.0 and the SDKManager will probably install Jetpack 4.2 by default.
Jetpack 4.2 as on my system doesn’t have the jetson_clock.sh file.
In later releases “~/jetson_clocks.sh” has moved to:
/usr/bin/jetson_clocks
Tip: Tab completion finds many of these. Just type a few characters, e.g., “jet”, and then hit the tab key to see possibilities. Once you see it, type “which jetson_clocks”.
