Hi all,
We have products deployed at clients using TRT2/CUDA8
Problem, padding is not handled and it has consequences on the result of our soft.
So we decided to switch to TRT3/CUDA9
To do so, we uninstalled CUDA8, same for TRT2 & openCV
We installed then CUDA9, TRT3 & OpenCV.
to do so we used the deb packages provided in Jetpack 3.2 (version arm64 of course)
But when we launch our service, we have this error :
[2018-02-21 09:10:59.120] [segnet] [info] createInferBuilder
terminate called after throwing an instance of 'nvinfer1::CudaError'
what(): std::exception
Aborted (core dumped)
Do you know why ?
We also have a version on PC that was ok.
And i am pretty sure that when i flashed a Jetson (tX2 by the way) from scratch, it worked correctly.
Thx for your help
Regards,
François
