Jetson TX2/Xavier (L4T R32.7.3) Trusty hwkey-agent / EKS provisioning questions
We’re developing a product on Jetson TX2 and Jetson Xavier (T194) running Jetson Linux / L4T R32.7.3 (JetPack 4.6.3). Our goal is to use the Trusty hwkey-agent Trusted Application together with the Linux hwkey-app client to seal/unseal sensitive data (e.g., LUKS key material) using hardware-derived keys.
We tested on two systems with the same software stack:
  • Development machine: hwkey-app succeeds
  • Production machine with burned fuses: hwkey-app fails
On the production machine we see the following error when running hwkey-app:
/hwkey-app -e -i plain.bin -o sealed.bin -t
tipc_connect: can't connect to tipc service "hwkey-agent.srv.crypto-srv" (err=107)
Questions:
  1. In L4T R32.7.3, does the NVIDIA-provided prebuilt Trusty TOS include the hwkey-agent TA and support deriving keys from hardware fuses / SE keyslots as required by hwkey-app?
  2. If we provision the EKS partition with an EKB (eks.img) generated with our OEM key material, will the prebuilt TOS automatically detect and use it at boot for hwkey-agent / hwkey-app operations, or is a TOS rebuild/configuration change required? For a production-fused machine, is it the expected workflow:
    • generate eks.img with NVIDIA’s gen_ekb.py using the correct KEK2/OEM key inputs (matching what is burned on the module), and
    • flash eks.img into the EKS partition,
      and then hwkey-app should succeed?
      If not, what additional steps are required (TOS rebuild options, required configs, signing, etc.)?
Environment:
  • L4T Version: R32.7.3
  • JetPack: 4.6.3
  • Platform: Tegra T194 (Xavier) and Jetson TX2
Thanks,
Shabnam
Thanks for visiting the NVIDIA Developer Forums.
To ensure better visibility and support, I’ve moved your post to the Jetson category where it’s more appropriate
Cheers,
Tom
hello shabnam.ab,
you may enable Disk Encryption, it encrypts a whole disk or partition to protect the data.
the boot partition (“APP”) remains in an unencrypted format, so the bootloader can still load kernel and device tree blob; the root partition (“APP_ENC”) would be encrypted.
the user_key is specified in EKB (i.e. eks.img)
CA sample, hwkey-agent/CA_sample/tool/gen_ekb/example.sh to generate eks.img, the sym.key is the user_key. Trusty retrieves user_key from eks.img, and loads the key into keyslot_14 for decryption, when you perform image flashing, please use --use_key options to specify the user_key.
please see-also Topic 258603 for reference.
