A week ago, I run my face-id project, that achieved 7fps, but now, after one week, I dont know why my project just achieve 3-4 fps, I dont modify source code and any dependency library.
Project: Face-Id based on Tensorflow (FaceNet)
OS: Ubuntu 16.04
Board: Jetson TX2
Cuda/CuDNN: 9.0/7.1.5.14
Tensorflow: 1.9.0
Hi hotdog160993,
Please try below commands then run again:
$ sudo reboot
$ sudo jetson_clocks
Thank you for reply, I have tried follow your instruction. But it doesn’t work.
This is far from a definitive way to see what is going on, but is this a stock kernel without modification, and if you run “htop” (“sudo apt-get install htop”) do you see one or more CPU cores being consumed? Does it show free RAM? Is the application you are looking at being run solely locally from a login at the TX2 and not remotely from an outside system?
Opps, sorry, my fault. I modify some code relevent to multi-processing :( really sorry.
