Jetson Ubuntu GUI login loop
Login ubuntu log in and continue logging in and logging in again to log in again.
On the CUI screen, I confirmed that I was logging in normally and rebooted, but the same phenomenon is occurring. What should I do?
If the device cannot be flashed/booted, please refer to the page to get uart log from the device:
Jetson/General debug - eLinux.org
And get logs of host PC and Jetson device for reference. If you are using custom board, you can compare uart log of developer kit and custom board to get more information.
Also please check FAQs:
Jetson AGX Orin FAQ
If possible, we would suggest follow quick start in developer guide to re-flash the system:
Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation
And see if the issue still persists on a clean-flashed system.
Please continue posting your previous topic: Log in infinite loop - Jetson & Embedded Systems / Jetson AGX Orin - NVIDIA Developer Forums
