With the “full flash” it seems as if the Bootloader PCIE is disabeld.
Here is the output for the flach command without the additional parameters:
command:
sudo ./flash.sh -C "fbcon=map:1 net.ifnames=0 pcie_aspm=off coherent_pool=16M" rlms mmcblk0p1
output:
# L4T BSP Information:
# R35 , REVISION: 6.1
# User release: 0.0
ECID is 0x88021911647c43080c00000011050180
# Target Board Information:
# Name: rlms, Board Family: t186ref, SoC: Tegra 194,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying soft_fuses(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
./tegraflash.py --chip 0x19 --applet "/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/mb1_t194_prod.bin" --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_applet nvtboot_applet_t194.bin" --cmd "dump eeprom boardinfo cvm.bin;reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0296 ] Generating RCM messages
[ 0.0316 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
[ 0.0320 ] Header already present for /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
[ 0.0410 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0413 ] Assuming zero filled SBK key
[ 0.0430 ] tegrasign_v3.py --file /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[ 0.0432 ] Assuming zero filled SBK key
[ 0.0474 ] Warning: pub_key.key is not found
[ 0.0453 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[ 0.0501 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[ 0.0530 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin 0 0
[ 0.0534 ] RCM 0 is saved as rcm_0.rcm
[ 0.0563 ] RCM 1 is saved as rcm_1.rcm
[ 0.0565 ] RCM 2 is saved as rcm_2.rcm
[ 0.0565 ] List of rcm files are saved in rcm_list.xml
[ 0.0565 ]
[ 0.0566 ] Signing RCM messages
[ 0.0618 ] tegrasign_v3.py --key None --list rcm_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[ 0.0618 ] Assuming zero filled SBK key
[ 0.0652 ] Warning: pub_key.key is not found
[ 0.0616 ] Copying signature to RCM mesages
[ 0.0631 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.0642 ] Boot Rom communication
[ 0.0659 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0663 ] RCM version 0X190001
[ 0.0889 ] Boot Rom communication completed
[ 2.1101 ] tegrarcm_v2 --isapplet
[ 2.1111 ] Applet version 01.00.0000
[ 2.1391 ] tegrarcm_v2 --ismb2
[ 2.1844 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194_aligned.bin
[ 2.1878 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194_aligned.bin zerosbk
[ 2.1887 ] adding BCH for nvtboot_applet_t194_aligned.bin
[ 2.2008 ] tegrasign_v3.py --key None --list nvtboot_applet_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 2.2009 ] Assuming zero filled SBK key
[ 2.2022 ] Warning: pub_key.key is not found
[ 2.2001 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_aligned_sigheader.bin.encrypt nvtboot_applet_t194_aligned_sigheader.bin.hash zerosbk
[ 2.2035 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[ 2.2040 ] Applet version 01.00.0000
[ 2.2283 ] Sending mb2
[ 2.2283 ] [................................................] 100%
[ 2.2465 ] tegrarcm_v2 --boot recovery
[ 2.2470 ] Applet version 01.00.0000
[ 3.2789 ] tegrarcm_v2 --isapplet
[ 3.3081 ] tegrarcm_v2 --ismb2
[ 3.3091 ] MB2 Applet version 01.00.0000
[ 3.3438 ] tegrarcm_v2 --ismb2
[ 3.3447 ] MB2 Applet version 01.00.0000
[ 3.3803 ] Retrieving board information
[ 3.3824 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[ 3.3832 ] MB2 Applet version 01.00.0000
[ 3.4182 ] Saved platform info in chip_info.bin
[ 3.4228 ] Chip minor revision: 2
[ 3.4232 ] Bootrom revision: 0xf
[ 3.4236 ] Ram code: 0x0
[ 3.4236 ] Chip sku: 0xde
[ 3.4236 ] Chip Sample: non es
[ 3.4237 ]
[ 3.4242 ] Retrieving EEPROM data
[ 3.4243 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/cvm.bin
[ 3.4253 ] MB2 Applet version 01.00.0000
[ 3.4528 ] Saved platform info in /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/cvm.bin
[ 3.4933 ] Rebooting to recovery mode
[ 3.4957 ] tegrarcm_v2 --ismb2
[ 3.4966 ] MB2 Applet version 01.00.0000
[ 3.5219 ] Rebooting to recovery mode
[ 3.5243 ] tegrarcm_v2 --reboot recovery
[ 3.5252 ] MB2 Applet version 01.00.0000
Board ID(3668) version(200) sku(0001) revision(G.0)
lz4c installed at /usr/bin/lz4c
Compressing /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p3668-a00.dtb ...
Copy /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb to /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb.rec
NVDISP+UEFI in bootloader/nvdisp-init.bin ..
copying bctfile(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg)... done.
copying bctfile1(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)... done.
copying minratchet_config(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-ratchet-p3668.cfg)... done.
copying device_config(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-qspi-p3668.cfg)... done.
copying misc_cold_boot_config(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)... done.
copying misc_config(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)... done.
copying pinmux_config(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p3668-a01.cfg)... done.
copying gpioint_config(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg)... done.
copying pmic_config(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p3668-0001-a00.cfg)... done.
copying pmc_config(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p3668-a01.cfg)... done.
copying prod_config(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p3668-0001-a00.cfg)... done.
copying scr_config(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)... done.
copying scr_cold_boot_config(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)... done.
copying bootrom_config(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p3668-0001-a00.cfg)... done.
copying dev_params(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-qspi-l4t.cfg)... done.
copying dev_params_b(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct_b-qspi-l4t.cfg)... done.
Existing bootloader(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
copying initrd(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
bl is uefi
Making Boot image... done.
Not signing of boot.img
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/ramdisk_tmp /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra
45518 blocks
gzip: /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/kernel/Image: not in gzip format
_BASE_KERNEL_VERSION=5.10.216-rlmsf56873ad02a3
92831 blocks
Making Recovery image...
copying recdtbfile(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb.rec)... done.
20+0 records in
20+0 records out
20 bytes copied, 0.000180809 s, 111 kB/s
Existing sosfile(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing tegraboot(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/nvtboot_t194.bin) reused.
Existing cpu_bootloader(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
Existing mb2blfile(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/nvtboot_recovery_t194.bin) reused.
Existing mtspreboot(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/preboot_c10_prod_cr.bin) reused.
Existing mcepreboot(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/mce_c10_prod_cr.bin) reused.
Existing mtsproper(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/mts_c10_prod_cr.bin) reused.
Existing mb1file(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing bpffile(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/bpmp-2_t194.bin) reused.
Existing bpfdtbfile(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/tegra194-a02-bpmp-p3668-a00_lz4.dtb) reused.
Existing scefile(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/camera-rtcpu-t194-rce.img) reused.
Existing apefile(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing wb0boot(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/warmboot_t194_prod.bin) reused.
Existing tosfile(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/tos-optee_t194.img) reused.
Existing eksfile(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/eks_t194.img) reused.
copying dtbfile(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb)... done.
Copying nv_boot_control.conf to rootfs
populating kernel to rootfs... done.
populating initrd to rootfs... done.
populating kernel_tegra194-p3668-all-p3509-0000.dtb to rootfs... done.
Making system.img...
Setting "FDT /boot/dtb/kernel_tegra194-p3668-all-p3509-0000.dtb" successfully in the extlinux.conf...done.
populating rootfs from /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/rootfs ... populating /boot/extlinux/extlinux.conf ... done.
Sync'ing system.img ... done.
Converting RAW image to Sparse image... done.
system.img built successfully.
Not signing of kernel-dtb
Existing tbcfile(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/nvdisp-init.bin) reused.
131072+0 records in
131072+0 records out
67108864 bytes (67 MB, 64 MiB) copied, 0.23572 s, 285 MB/s
Sync'ing esp.img ... done.
copying tbcdtbfile(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb)... done.
copying cfgfile(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/t186ref/cfg/flash_l4t_t194_spi_emmc_p3668.xml) to flash.xml... done.
done.
Existing flasher(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
Existing flashapp(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/tegraflash.py) reused.
copying overlay_dtb(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/kernel/dtb/L4TConfiguration.dtbo)... done.
copying overlay_dtb(/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/kernel/dtb/tegra194-p3668-p3509-overlay.dtbo)... done.
/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin --sdram_config tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg,tegra194-memcfg-sw-override.cfg --odmdata 0xB8190000 --overlay_dtb L4TConfiguration.dtbo,tegra194-p3668-p3509-overlay.dtbo, --bldtb tegra194-p3668-all-p3509-0000.dtb --applet mb1_t194_prod.bin --cmd "flash; reboot" --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --cfg flash.xml --chip 0x19 --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --device_config tegra19x-mb1-bct-device-qspi-p3668.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p3668-a01.cfg --gpioint_config tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --pmic_config tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --pmc_config tegra19x-mb1-padvoltage-p3668-a01.cfg --prod_config tegra19x-mb1-prod-p3668-0001-a00.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --br_cmd_config tegra194-mb1-bct-reset-p3668-0001-a00.cfg --dev_params tegra194-br-bct-qspi-l4t.cfg,tegra194-br-bct_b-qspi-l4t.cfg --bin "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bpmp_fw bpmp-2_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p3668-a00_lz4.dtb; spe_fw spe_t194.bin; tos tos-optee_t194.img; eks eks_t194.img; bootloader_dtb tegra194-p3668-all-p3509-0000.dtb" --ramcode 0 --bct_backup --boot_chain A
saving flash command in /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[ 0.0350 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0352 ] Assuming zero filled SBK key
[ 0.0020 ] Generating RCM messages
[ 0.0033 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[ 0.0036 ] Header already present for mb1_t194_prod.bin
[ 0.0412 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0429 ] tegrasign_v3.py --file mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[ 0.0430 ] Assuming zero filled SBK key
[ 0.0452 ] Warning: pub_key.key is not found
[ 0.0135 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[ 0.0181 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[ 0.0203 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 0.0206 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.0213 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.0213 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.0213 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.0213 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.0213 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.0213 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.0213 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.0213 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.0213 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.0213 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.0213 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.0213 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.0213 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.0213 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.0213 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.0213 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.0213 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.0213 ]
[ 0.0228 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[ 0.0230 ] RCM 0 is saved as rcm_0.rcm
[ 0.0258 ] RCM 1 is saved as rcm_1.rcm
[ 0.0259 ] RCM 2 is saved as rcm_2.rcm
[ 0.0260 ] List of rcm files are saved in rcm_list.xml
[ 0.0260 ]
[ 0.0260 ] Signing RCM messages
[ 0.0608 ] tegrasign_v3.py --key None --list rcm_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[ 0.0609 ] Assuming zero filled SBK key
[ 0.0637 ] Warning: pub_key.key is not found
[ 0.0304 ] Copying signature to RCM mesages
[ 0.0318 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.0329 ] odmdata (to decode) = 3088646144
[ 0.0329 ] Odmdata strings: PCIE_XBAR_8_1_1_0_1,UFS_DISABLED,NVHS_PCIE,enable-debug-console,enable-denver-wdt
[ 0.0329 ] Bpmp odmdata config: {'pcie-xbar-config': [0, 1, 'PCIE_XBAR_8_1_1_0_1'], 'pcie-c0-endpoint-enable': [1, 0, ''], 'pcie-c4-endpoint-enable': [1, 0, ''], 'ufs-config': [0, 1, 'UFS_DISABLED'], 'sata-enable': [1, 0, ''], 'nvhs-owner': [0, 1, 'PCIE'], 'pcie-c5-endpoint-enable': [1, 0, '']}
[ 0.0342 ] bpmp_dtb is compressed; decompressing...
[ 0.0342 ] lz4c -df tegra194-a02-bpmp-p3668-a00_lz4.dtb tegra194-a02-bpmp-p3668-a00_lz4_with_odm.dtb
[ 0.0361 ] tegra194-a02-bpmp-p3 : decoded 606912 bytes
[ 0.0361 ]
[ 0.1849 ] Re-compressing updated bpmp_dtb
[ 0.1849 ] lz4c -zf tegra194-a02-bpmp-p3668-a00_lz4_with_odm.dtb tegra194-a02-bpmp-p3668-a00_lz4.dtb
[ 0.1868 ] Compressed 606849 bytes into 38768 bytes ==> 6.39%
[ 0.1868 ]
[ 0.4246 ] Concatenating L4TConfiguration.dtbo,tegra194-p3668-p3509-overlay.dtbo to tegra194-p3668-all-p3509-0000_with_odm_overlay.dtb
[ 0.4251 ] Parsing partition layout
[ 0.4272 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.4289 ] Got ramcode 0 from the command line
[ 0.4289 ] Disable BPMP dtb trim, using default dtb
[ 0.4289 ]
[ 0.4289 ] Creating list of images to be signed
[ 0.4304 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[ 0.4307 ] MB1: Nvheader already present is mb1_t194_prod_aligned.bin
[ 0.4316 ] Header already present for mb1_t194_prod_aligned_sigheader.bin
[ 0.4319 ] MB1: Nvheader already present is mb1_b_t194_prod_aligned.bin
[ 0.4345 ] Header already present for mb1_b_t194_prod_aligned_sigheader.bin
[ 0.4348 ] adding BCH for spe_t194_aligned.bin
[ 0.4373 ] adding BCH for nvtboot_t194_aligned.bin
[ 0.4397 ] Header already present for preboot_c10_prod_cr_aligned.bin
[ 0.4440 ] Header already present for mce_c10_prod_cr_aligned.bin
[ 0.4447 ] adding BCH for mts_c10_prod_cr_aligned.bin
[ 0.4536 ] Header already present for warmboot_t194_prod_aligned.bin
[ 0.5137 ] adding BCH for nvdisp-init_aligned.bin
[ 0.5201 ] adding BCH for tegra194-p3668-all-p3509-0000_aligned.dtb
[ 0.5783 ] adding BCH for tos-optee_t194_aligned.img
[ 0.5876 ] adding BCH for eks_t194_aligned.img
[ 0.6082 ] adding BCH for adsp-fw_aligned.bin
[ 0.6090 ] adding BCH for camera-rtcpu-t194-rce_aligned.img
[ 0.6181 ] adding BCH for bpmp-2_t194_aligned.bin
[ 0.6307 ] adding BCH for tegra194-a02-bpmp-p3668-a00_lz4_aligned.dtb
[ 0.6488 ] adding BCH for spe_t194_aligned.bin
[ 0.6497 ] adding BCH for nvtboot_t194_aligned.bin
[ 0.6518 ] Header already present for preboot_c10_prod_cr_aligned.bin
[ 0.6560 ] Header already present for mce_c10_prod_cr_aligned.bin
[ 0.6564 ] adding BCH for mts_c10_prod_cr_aligned.bin
[ 0.6655 ] Header already present for warmboot_t194_prod_aligned.bin
[ 0.7260 ] adding BCH for nvdisp-init_aligned.bin
[ 0.7332 ] adding BCH for tegra194-p3668-all-p3509-0000_aligned.dtb
[ 0.7916 ] adding BCH for tos-optee_t194_aligned.img
[ 0.8003 ] adding BCH for eks_t194_aligned.img
[ 0.8208 ] adding BCH for adsp-fw_aligned.bin
[ 0.8218 ] adding BCH for camera-rtcpu-t194-rce_aligned.img
[ 0.8309 ] adding BCH for bpmp-2_t194_aligned.bin
[ 0.8431 ] adding BCH for tegra194-a02-bpmp-p3668-a00_lz4_aligned.dtb
[ 0.8628 ] Filling MB1 storage info
[ 0.8628 ] Parsing dev params for multi chains
[ 0.8628 ] Generating br-bct
[ 0.8644 ] Performing cfg overlay
[ 0.8644 ] ['tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg', 'tegra194-memcfg-sw-override.cfg']
[ 0.8647 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg -s tegra194-memcfg-sw-override.cfg -o /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/16553/tmpjvoqd8qu1.cfg
[ 0.9303 ] Updating dev and MSS params in BR BCT
[ 0.9303 ] tegrabct_v2 --dev_param tegra194-br-bct-qspi-l4t.cfg --sdram /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/16553/tmpjvoqd8qu1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 0.9987 ] Updating bl info
[ 1.0004 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 1.0019 ] Generating br-bct
[ 1.0034 ] Performing cfg overlay
[ 1.0034 ] ['/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/16553/tmpjvoqd8qu1.cfg']
[ 1.0034 ] Updating dev and MSS params in BR BCT
[ 1.0034 ] tegrabct_v2 --dev_param tegra194-br-bct_b-qspi-l4t.cfg --sdram /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/16553/tmpjvoqd8qu1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 1.0737 ] Updating bl info
[ 1.0754 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 1.0770 ] Generating BCT backup image
[ 1.0771 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[ 1.0775 ] 32768+0 records in
[ 1.1093 ] 32768+0 records out
[ 1.1093 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0311967 s, 1.1 MB/s
[ 1.1093 ]
[ 1.1093 ] Concatenating BCT for chain A to bct_backup.img
[ 1.1093 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[ 1.1098 ] 2888+0 records in
[ 1.1137 ] 2888+0 records out
[ 1.1137 ] 2888 bytes (2.9 kB, 2.8 KiB) copied, 0.00338609 s, 853 kB/s
[ 1.1137 ]
[ 1.1137 ] Concatenating BCT for chain B to bct_backup.img
[ 1.1137 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[ 1.1140 ] 2888+0 records in
[ 1.1179 ] 2888+0 records out
[ 1.1179 ] 2888 bytes (2.9 kB, 2.8 KiB) copied, 0.00343291 s, 841 kB/s
[ 1.1179 ]
[ 1.1179 ] Generating signatures
[ 1.1527 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key
[ 1.1530 ] Assuming zero filled SBK key
[ 1.2272 ] Warning: pub_key.key is not found
[ 1.1939 ] Parsing dev params for multi chains
[ 1.1939 ] Generating br-bct
[ 1.1954 ] Performing cfg overlay
[ 1.1954 ] ['/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/16553/tmpjvoqd8qu1.cfg']
[ 1.1954 ] Updating dev and MSS params in BR BCT
[ 1.1954 ] tegrabct_v2 --dev_param tegra194-br-bct-qspi-l4t.cfg --sdram /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/16553/tmpjvoqd8qu1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 1.2632 ] Updating bl info
[ 1.2650 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 1.2669 ] Updating smd info
[ 1.2684 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[ 1.2691 ] Updating Odmdata
[ 1.2707 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0xB8190000
[ 1.2714 ] Signing BCT
[ 1.2714 ] Get Signed section of bct
[ 1.2731 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[ 1.3085 ] tegrasign_v3.py --key None --list bct_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[ 1.3087 ] Assuming zero filled SBK key
[ 1.3098 ] Warning: pub_key.key is not found
[ 1.2765 ] Updating BCT with signature
[ 1.2781 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[ 1.2789 ] Generating br-bct
[ 1.2804 ] Performing cfg overlay
[ 1.2804 ] ['/home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/16553/tmpjvoqd8qu1.cfg']
[ 1.2804 ] Updating dev and MSS params in BR BCT
[ 1.2805 ] tegrabct_v2 --dev_param tegra194-br-bct_b-qspi-l4t.cfg --sdram /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/16553/tmpjvoqd8qu1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 1.3534 ] Updating bl info
[ 1.3551 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 1.3571 ] Updating smd info
[ 1.3586 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[ 1.3592 ] Updating Odmdata
[ 1.3606 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0xB8190000
[ 1.3612 ] Signing BCT
[ 1.3612 ] Get Signed section of bct
[ 1.3629 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[ 1.3984 ] tegrasign_v3.py --key None --list bct_list.xml --getmontgomeryvalues montgomery.bin --pubkeyhash pub_key.key
[ 1.3985 ] Assuming zero filled SBK key
[ 1.3998 ] Warning: pub_key.key is not found
[ 1.3665 ] Updating BCT with signature
[ 1.3681 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[ 1.3690 ] Generating BCT backup image
[ 1.3691 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[ 1.3694 ] 32768+0 records in
[ 1.4016 ] 32768+0 records out
[ 1.4016 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0316434 s, 1.0 MB/s
[ 1.4016 ]
[ 1.4017 ] Concatenating BCT for chain A to bct_backup.img
[ 1.4017 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[ 1.4021 ] 2888+0 records in
[ 1.4058 ] 2888+0 records out
[ 1.4059 ] 2888 bytes (2.9 kB, 2.8 KiB) copied, 0.00324221 s, 891 kB/s
[ 1.4059 ]
[ 1.4059 ] Concatenating BCT for chain B to bct_backup.img
[ 1.4059 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[ 1.4064 ] 2888+0 records in
[ 1.4128 ] 2888+0 records out
[ 1.4128 ] 2888 bytes (2.9 kB, 2.8 KiB) copied, 0.00580933 s, 497 kB/s
[ 1.4128 ]
[ 1.4128 ] Generating coldboot mb1-bct
[ 1.4147 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/16553/tmpjvoqd8qu1.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --pinmux tegra19x-mb1-pinmux-p3668-a01.cfg --pmc tegra19x-mb1-padvoltage-p3668-a01.cfg --pmic tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --brcommand tegra194-mb1-bct-reset-p3668-0001-a00.cfg --prod tegra19x-mb1-prod-p3668-0001-a00.cfg --gpioint tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --device tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 1.4151 ] MB1-BCT version: 0x1
[ 1.4155 ] Parsing config file :tegra19x-mb1-pinmux-p3668-a01.cfg
[ 1.4156 ] Added Platform Config 0 data with size :- 2496
[ 1.4169 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini-p3668.cfg
[ 1.4171 ] Added Platform Config 1 data with size :- 19640
[ 1.4293 ] Parsing config file :tegra19x-mb1-padvoltage-p3668-a01.cfg
[ 1.4295 ] Added Platform Config 2 data with size :- 24
[ 1.4296 ] Parsing config file :tegra194-mb1-bct-pmic-p3668-0001-a00.cfg
[ 1.4298 ] Added Platform Config 4 data with size :- 348
[ 1.4300 ] Parsing config file :tegra194-mb1-bct-reset-p3668-0001-a00.cfg
[ 1.4302 ] Added Platform Config 3 data with size :- 92
[ 1.4303 ] Parsing config file :tegra19x-mb1-prod-p3668-0001-a00.cfg
[ 1.4305 ] Added Platform Config 5 data with size :- 140
[ 1.4307 ] Parsing config file :tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg
[ 1.4308 ] Added Platform Config 7 data with size :- 392
[ 1.4314 ] Parsing config file :tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 1.4315 ] Added Platform Config 9 data with size :- 40
[ 1.4316 ]
[ 1.4316 ] Updating mb1-bct with firmware information
[ 1.4331 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 1.4337 ] Updating mb1-bct with storage information
[ 1.4351 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 1.4358 ] Updating mb1-bct with ratchet information
[ 1.4374 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 1.4378 ] FwIndex: 1, MinRatchetLevel: 0
[ 1.4382 ] FwIndex: 2, MinRatchetLevel: 0
[ 1.4382 ] FwIndex: 3, MinRatchetLevel: 0
[ 1.4382 ] FwIndex: 4, MinRatchetLevel: 0
[ 1.4382 ] FwIndex: 5, MinRatchetLevel: 0
[ 1.4382 ] FwIndex: 6, MinRatchetLevel: 0
[ 1.4382 ] FwIndex: 7, MinRatchetLevel: 0
[ 1.4382 ] FwIndex: 11, MinRatchetLevel: 0
[ 1.4382 ] FwIndex: 12, MinRatchetLevel: 0
[ 1.4382 ] FwIndex: 13, MinRatchetLevel: 0
[ 1.4382 ] FwIndex: 14, MinRatchetLevel: 0
[ 1.4382 ] FwIndex: 15, MinRatchetLevel: 0
[ 1.4382 ] FwIndex: 16, MinRatchetLevel: 0
[ 1.4382 ] FwIndex: 17, MinRatchetLevel: 0
[ 1.4382 ] FwIndex: 18, MinRatchetLevel: 0
[ 1.4382 ] FwIndex: 19, MinRatchetLevel: 0
[ 1.4382 ] FwIndex: 30, MinRatchetLevel: 0
[ 1.4383 ] FwIndex: 31, MinRatchetLevel: 0
[ 1.4383 ]
[ 1.4399 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 1.4416 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 1.4420 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 1.4776 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 1.4778 ] Assuming zero filled SBK key
[ 1.4792 ] Warning: pub_key.key is not found
[ 1.4476 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 1.4487 ] Generating recovery mb1-bct
[ 1.4505 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/16553/tmpjvoqd8qu1.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --pinmux tegra19x-mb1-pinmux-p3668-a01.cfg --pmc tegra19x-mb1-padvoltage-p3668-a01.cfg --pmic tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --brcommand tegra194-mb1-bct-reset-p3668-0001-a00.cfg --prod tegra19x-mb1-prod-p3668-0001-a00.cfg --gpioint tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --device tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 1.4510 ] MB1-BCT version: 0x1
[ 1.4514 ] Parsing config file :tegra19x-mb1-pinmux-p3668-a01.cfg
[ 1.4515 ] Added Platform Config 0 data with size :- 2496
[ 1.4527 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini-p3668.cfg
[ 1.4529 ] Added Platform Config 1 data with size :- 19640
[ 1.4646 ] Parsing config file :tegra19x-mb1-padvoltage-p3668-a01.cfg
[ 1.4648 ] Added Platform Config 2 data with size :- 24
[ 1.4649 ] Parsing config file :tegra194-mb1-bct-pmic-p3668-0001-a00.cfg
[ 1.4651 ] Added Platform Config 4 data with size :- 348
[ 1.4652 ] Parsing config file :tegra194-mb1-bct-reset-p3668-0001-a00.cfg
[ 1.4654 ] Added Platform Config 3 data with size :- 92
[ 1.4655 ] Parsing config file :tegra19x-mb1-prod-p3668-0001-a00.cfg
[ 1.4657 ] Added Platform Config 5 data with size :- 140
[ 1.4658 ] Parsing config file :tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg
[ 1.4661 ] Added Platform Config 7 data with size :- 392
[ 1.4663 ] Parsing config file :tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 1.4665 ] Added Platform Config 9 data with size :- 40
[ 1.4665 ]
[ 1.4665 ] Updating mb1-bct with firmware information
[ 1.4680 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[ 1.4686 ] Updating mb1-bct with storage information
[ 1.4701 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 1.4708 ] Updating mb1-bct with ratchet information
[ 1.4723 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 1.4727 ] FwIndex: 1, MinRatchetLevel: 0
[ 1.4731 ] FwIndex: 2, MinRatchetLevel: 0
[ 1.4731 ] FwIndex: 3, MinRatchetLevel: 0
[ 1.4731 ] FwIndex: 4, MinRatchetLevel: 0
[ 1.4731 ] FwIndex: 5, MinRatchetLevel: 0
[ 1.4732 ] FwIndex: 6, MinRatchetLevel: 0
[ 1.4732 ] FwIndex: 7, MinRatchetLevel: 0
[ 1.4732 ] FwIndex: 11, MinRatchetLevel: 0
[ 1.4732 ] FwIndex: 12, MinRatchetLevel: 0
[ 1.4732 ] FwIndex: 13, MinRatchetLevel: 0
[ 1.4732 ] FwIndex: 14, MinRatchetLevel: 0
[ 1.4732 ] FwIndex: 15, MinRatchetLevel: 0
[ 1.4732 ] FwIndex: 16, MinRatchetLevel: 0
[ 1.4732 ] FwIndex: 17, MinRatchetLevel: 0
[ 1.4732 ] FwIndex: 18, MinRatchetLevel: 0
[ 1.4732 ] FwIndex: 19, MinRatchetLevel: 0
[ 1.4732 ] FwIndex: 30, MinRatchetLevel: 0
[ 1.4732 ] FwIndex: 31, MinRatchetLevel: 0
[ 1.4732 ]
[ 1.4748 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1_aligned.bct
[ 1.4764 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 1.4767 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 1.5125 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 1.5126 ] Assuming zero filled SBK key
[ 1.5136 ] Warning: pub_key.key is not found
[ 1.4820 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 1.4829 ] Generating coldboot mem-bct
[ 1.4843 ] tegrabct_v2 --chip 0x19 0 --sdram /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/16553/tmpjvoqd8qu1.cfg --membct /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/16553/tmpjvoqd8qu1_1.bct /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/16553/tmpjvoqd8qu1_2.bct /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/16553/tmpjvoqd8qu1_3.bct /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/16553/tmpjvoqd8qu1_4.bct
[ 1.4846 ] Packing sdram param for instance[0]
[ 1.5514 ] Packing sdram param for instance[1]
[ 1.5515 ] Packing sdram param for instance[2]
[ 1.5516 ] Packing sdram param for instance[3]
[ 1.5517 ] Packing sdram param for instance[4]
[ 1.5518 ] Packing sdram param for instance[5]
[ 1.5520 ] Packing sdram param for instance[6]
[ 1.5522 ] Packing sdram param for instance[7]
[ 1.5522 ] Packing sdram param for instance[8]
[ 1.5522 ] Packing sdram param for instance[9]
[ 1.5522 ] Packing sdram param for instance[10]
[ 1.5522 ] Packing sdram param for instance[11]
[ 1.5522 ] Packing sdram param for instance[12]
[ 1.5522 ] Packing sdram param for instance[13]
[ 1.5522 ] Packing sdram param for instance[14]
[ 1.5522 ] Packing sdram param for instance[15]
[ 1.5522 ]
[ 1.5522 ] Getting sector size from pt
[ 1.5536 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 1.5540 ] BlockSize read from layout is 200
[ 1.5554 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/16553/tmpjvoqd8qu1_1.bct /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/16553/tmpjvoqd8qu1_2.bct /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/16553/tmpjvoqd8qu1_3.bct /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/16553/tmpjvoqd8qu1_4.bct
[ 1.5557 ] adding BCH for /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/16553/tmpjvoqd8qu1_1.bct
[ 1.5600 ] tegrahost_v2 --chip 0x19 --align mem_coldboot_aligned.bct
[ 1.5619 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot_aligned.bct zerosbk
[ 1.5622 ] Header already present for mem_coldboot_aligned.bct
[ 1.5975 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 1.5976 ] Assuming zero filled SBK key
[ 1.5989 ] Warning: pub_key.key is not found
[ 1.5673 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[ 1.5684 ] Generating recovery mem-bct
[ 1.5699 ] tegrabct_v2 --chip 0x19 0 --sdram /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/16553/tmpjvoqd8qu1.cfg --membct /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/16553/tmpjvoqd8qu1_1.bct /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/16553/tmpjvoqd8qu1_2.bct /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/16553/tmpjvoqd8qu1_3.bct /home/nuc3/u-boot-flasher-tx2/Linux_for_Tegra/bootloader/16553/tmpjvoqd8qu1_4.bct
[ 1.5702 ] Packing sdram param for instance[0]
[ 1.6399 ] Packing sdram param for instance[1]
[ 1.6400 ] Packing sdram param for instance[2]
[ 1.6402 ] Packing sdram param for instance[3]
[ 1.6403 ] Packing sdram param for instance[4]
[ 1.6405 ] Packing sdram param for instance[5]
[ 1.6407 ] Packing sdram param for instance[6]
[ 1.6407 ] Packing sdram param for instance[7]
[ 1.6407 ] Packing sdram param for instance[8]
[ 1.6407 ] Packing sdram param for instance[9]
[ 1.6407 ] Packing sdram param for instance[10]
[ 1.6407 ] Packing sdram param for instance[11]
[ 1.6407 ] Packing sdram param for instance[12]
[ 1.6408 ] Packing sdram param for instance[13]
[ 1.6408 ] Packing sdram param for instance[14]
[ 1.6408 ] Packing sdram param for instance[15]
[ 1.6408 ]
[ 1.6425 ] tegrahost_v2 --chip 0x19 --align mem_rcm_aligned.bct
[ 1.6443 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[ 1.6447 ] adding BCH for mem_rcm_aligned.bct
[ 1.6807 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 1.6808 ] Assuming zero filled SBK key
[ 1.6821 ] Warning: pub_key.key is not found
[ 1.6504 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[ 1.6519 ] Copying signatures
[ 1.6534 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 1.8711 ] Boot Rom communication
[ 1.8729 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
[ 1.8732 ] BR_CID: 0x88021911647c43080c00000011050180
[ 1.8959 ] RCM version 0X190001
[ 1.9260 ] Boot Rom communication completed
[ 3.9455 ] tegrarcm_v2 --isapplet
[ 3.9465 ] Applet version 01.00.0000
[ 3.9719 ] Sending BCTs
[ 3.9745 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
[ 3.9756 ] Applet version 01.00.0000
[ 4.0075 ] Sending bct_bootrom
[ 4.0079 ] [................................................] 100%
[ 4.0097 ] Sending bct_mb1
[ 4.0151 ] [................................................] 100%
[ 4.0206 ] Sending bct_mem
[ 4.0695 ] [................................................] 100%
[ 4.1083 ] Generating blob
[ 4.1119 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_cpu_t194_aligned.bin
[ 4.1157 ] tegrahost_v2 --chip 0x19 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvtboot_recovery_cpu_t194_aligned.bin zerosbk
[ 4.1169 ] adding BCH for blob_nvtboot_recovery_cpu_t194_aligned.bin
[ 4.1605 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_cpu_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 4.1606 ] Assuming zero filled SBK key
[ 4.1617 ] Warning: pub_key.key is not found
[ 4.1301 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_cpu_t194_aligned_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_t194_aligned_sigheader.bin.hash zerosbk
[ 4.1443 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_t194_aligned.bin
[ 4.1478 ] tegrahost_v2 --chip 0x19 0 --magicid MB2B --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvtboot_recovery_t194_aligned.bin zerosbk
[ 4.1487 ] adding BCH for blob_nvtboot_recovery_t194_aligned.bin
[ 4.1993 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 4.1996 ] Assuming zero filled SBK key
[ 4.2028 ] Warning: pub_key.key is not found
[ 4.1719 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_t194_aligned_sigheader.bin.encrypt blob_nvtboot_recovery_t194_aligned_sigheader.bin.hash zerosbk
[ 4.1836 ] tegrahost_v2 --chip 0x19 --align blob_preboot_c10_prod_cr_aligned.bin
[ 4.1869 ] tegrahost_v2 --chip 0x19 0 --magicid MTSP --appendsigheader blob_preboot_c10_prod_cr_aligned.bin zerosbk
[ 4.1878 ] Header already present for blob_preboot_c10_prod_cr_aligned.bin
[ 4.2252 ] tegrasign_v3.py --key None --list blob_preboot_c10_prod_cr_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 4.2254 ] Assuming zero filled SBK key
[ 4.2284 ] Warning: pub_key.key is not found
[ 4.1975 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_preboot_c10_prod_cr_aligned_sigheader.bin.encrypt blob_preboot_c10_prod_cr_aligned_sigheader.bin.hash zerosbk
[ 4.2026 ] tegrahost_v2 --chip 0x19 --align blob_mce_c10_prod_cr_aligned.bin
[ 4.2061 ] tegrahost_v2 --chip 0x19 0 --magicid MTSM --appendsigheader blob_mce_c10_prod_cr_aligned.bin zerosbk
[ 4.2070 ] Header already present for blob_mce_c10_prod_cr_aligned.bin
[ 4.2488 ] tegrasign_v3.py --key None --list blob_mce_c10_prod_cr_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 4.2490 ] Assuming zero filled SBK key
[ 4.2527 ] Warning: pub_key.key is not found
[ 4.2220 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mce_c10_prod_cr_aligned_sigheader.bin.encrypt blob_mce_c10_prod_cr_aligned_sigheader.bin.hash zerosbk
[ 4.2358 ] tegrahost_v2 --chip 0x19 --align blob_mts_c10_prod_cr_aligned.bin
[ 4.2392 ] tegrahost_v2 --chip 0x19 0 --magicid MTSB --appendsigheader blob_mts_c10_prod_cr_aligned.bin zerosbk
[ 4.2401 ] adding BCH for blob_mts_c10_prod_cr_aligned.bin
[ 4.3653 ] tegrasign_v3.py --key None --list blob_mts_c10_prod_cr_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 4.3654 ] Assuming zero filled SBK key
[ 4.3722 ] Warning: pub_key.key is not found
[ 4.3405 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mts_c10_prod_cr_aligned_sigheader.bin.encrypt blob_mts_c10_prod_cr_aligned_sigheader.bin.hash zerosbk
[ 4.3794 ] tegrahost_v2 --chip 0x19 --align blob_bpmp-2_t194_aligned.bin
[ 4.3814 ] tegrahost_v2 --chip 0x19 0 --magicid BPMF --ratchet_blob ratchet_blob.bin --appendsigheader blob_bpmp-2_t194_aligned.bin zerosbk
[ 4.3818 ] adding BCH for blob_bpmp-2_t194_aligned.bin
[ 4.4363 ] tegrasign_v3.py --key None --list blob_bpmp-2_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 4.4364 ] Assuming zero filled SBK key
[ 4.4391 ] Warning: pub_key.key is not found
[ 4.4075 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_bpmp-2_t194_aligned_sigheader.bin.encrypt blob_bpmp-2_t194_aligned_sigheader.bin.hash zerosbk
[ 4.4204 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-a02-bpmp-p3668-a00_lz4_aligned.dtb
[ 4.4224 ] tegrahost_v2 --chip 0x19 0 --magicid BPMD --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra194-a02-bpmp-p3668-a00_lz4_aligned.dtb zerosbk
[ 4.4228 ] adding BCH for blob_tegra194-a02-bpmp-p3668-a00_lz4_aligned.dtb
[ 4.4585 ] tegrasign_v3.py --key None --list blob_tegra194-a02-bpmp-p3668-a00_lz4_aligned_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 4.4586 ] Assuming zero filled SBK key
[ 4.4596 ] Warning: pub_key.key is not found
[ 4.4279 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-a02-bpmp-p3668-a00_lz4_aligned_sigheader.dtb.encrypt blob_tegra194-a02-bpmp-p3668-a00_lz4_aligned_sigheader.dtb.hash zerosbk
[ 4.4305 ] tegrahost_v2 --chip 0x19 --align blob_spe_t194_aligned.bin
[ 4.4323 ] tegrahost_v2 --chip 0x19 0 --magicid SPEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_spe_t194_aligned.bin zerosbk
[ 4.4326 ] adding BCH for blob_spe_t194_aligned.bin
[ 4.4693 ] tegrasign_v3.py --key None --list blob_spe_t194_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 4.4694 ] Assuming zero filled SBK key
[ 4.4706 ] Warning: pub_key.key is not found
[ 4.4388 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_spe_t194_aligned_sigheader.bin.encrypt blob_spe_t194_aligned_sigheader.bin.hash zerosbk
[ 4.4425 ] tegrahost_v2 --chip 0x19 --align blob_tos-optee_t194_aligned.img
[ 4.4444 ] tegrahost_v2 --chip 0x19 0 --magicid TOSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tos-optee_t194_aligned.img zerosbk
[ 4.4447 ] adding BCH for blob_tos-optee_t194_aligned.img
[ 4.5029 ] tegrasign_v3.py --key None --list blob_tos-optee_t194_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 4.5030 ] Assuming zero filled SBK key
[ 4.5052 ] Warning: pub_key.key is not found
[ 4.4737 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tos-optee_t194_aligned_sigheader.img.encrypt blob_tos-optee_t194_aligned_sigheader.img.hash zerosbk
[ 4.4883 ] tegrahost_v2 --chip 0x19 --align blob_eks_t194_aligned.img
[ 4.4904 ] tegrahost_v2 --chip 0x19 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_eks_t194_aligned.img zerosbk
[ 4.4908 ] adding BCH for blob_eks_t194_aligned.img
[ 4.5258 ] tegrasign_v3.py --key None --list blob_eks_t194_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 4.5259 ] Assuming zero filled SBK key
[ 4.5270 ] Warning: pub_key.key is not found
[ 4.4952 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_eks_t194_aligned_sigheader.img.encrypt blob_eks_t194_aligned_sigheader.img.hash zerosbk
[ 4.4977 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-p3668-all-p3509-0000_aligned.dtb
[ 4.4996 ] tegrahost_v2 --chip 0x19 0 --magicid CDTB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra194-p3668-all-p3509-0000_aligned.dtb zerosbk
[ 4.4999 ] adding BCH for blob_tegra194-p3668-all-p3509-0000_aligned.dtb
[ 4.5415 ] tegrasign_v3.py --key None --list blob_tegra194-p3668-all-p3509-0000_aligned_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 4.5416 ] Assuming zero filled SBK key
[ 4.5428 ] Warning: pub_key.key is not found
[ 4.5112 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-p3668-all-p3509-0000_aligned_sigheader.dtb.encrypt blob_tegra194-p3668-all-p3509-0000_aligned_sigheader.dtb.hash zerosbk
[ 4.5167 ] tegrahost_v2 --chip 0x19 --generateblob blob.xml blob.bin
[ 4.5170 ] number of images in blob are 11
[ 4.5172 ] blobsize is 6662328
[ 4.5173 ] Added binary blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt of size 232976
[ 4.5196 ] Added binary blob_nvtboot_recovery_t194_sigheader.bin.encrypt of size 206016
[ 4.5200 ] Added binary blob_preboot_c10_prod_cr_sigheader.bin.encrypt of size 24016
[ 4.5203 ] Added binary blob_mce_c10_prod_cr_sigheader.bin.encrypt of size 145184
[ 4.5206 ] Added binary blob_mts_c10_prod_cr_sigheader.bin.encrypt of size 3429968
[ 4.5216 ] Added binary blob_bpmp-2_t194_sigheader.bin.encrypt of size 1007392
[ 4.5225 ] Added binary blob_tegra194-a02-bpmp-p3668-a00_lz4_sigheader.dtb.encrypt of size 42864
[ 4.5229 ] Added binary blob_spe_t194_sigheader.bin.encrypt of size 95232
[ 4.5231 ] Added binary blob_tos-optee_t194_sigheader.img.encrypt of size 1137424
[ 4.5233 ] Added binary blob_eks_t194_sigheader.img.encrypt of size 5136
[ 4.5235 ] Added binary blob_tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt of size 335936
[ 4.5264 ] Sending bootloader and pre-requisite binaries
[ 4.5280 ] tegrarcm_v2 --download blob blob.bin
[ 4.5282 ] Applet version 01.00.0000
[ 4.5531 ] Sending blob
[ 4.5532 ] [................................................] 100%
[ 5.5122 ] tegrarcm_v2 --boot recovery
[ 5.5125 ] Applet version 01.00.0000
[ 6.5432 ] tegrarcm_v2 --isapplet
[ 7.4829 ] tegrarcm_v2 --ismb2
[ 7.5201 ] tegradevflash_v2 --iscpubl
[ 7.5212 ] Bootloader version 01.00.0000
[ 7.5474 ] Bootloader version 01.00.0000
[ 7.5489 ] Retrieving storage infomation
[ 7.5512 ] tegrarcm_v2 --oem platformdetails storage storage_info.bin
[ 7.5521 ] Applet is not running on device. Continue with Bootloader
[ 7.5897 ] tegradevflash_v2 --oem platformdetails storage storage_info.bin
[ 7.5906 ] Bootloader version 01.00.0000
[ 7.6229 ] Saved platform info in storage_info.bin
[ 7.6257 ] Flashing the device
[ 7.6283 ] tegraparser_v2 --storageinfo storage_info.bin --generategpt --pt flash.xml.bin
[ 7.6294 ] gpt_secondary_3_0.bin:
[ 7.6305 ] partition_id partition_name StartingLba EndingLba
[ 7.6314 ] 1 BCT 0 255
[ 7.6326 ] 2 mb1 256 767
[ 7.6338 ] 3 mb1_b 768 1279
[ 7.6348 ] 4 MB1_BCT 1280 1407
[ 7.6350 ] 5 MEM_BCT 1408 1919
[ 7.6353 ] 6 spe-fw 1920 2431
[ 7.6355 ] 7 mb2 2432 2943
[ 7.6357 ] 8 mts-preboot 2944 3071
[ 7.6360 ] 9 mts-mce 3072 3455
[ 7.6362 ] 10 mts-proper 3456 11647
[ 7.6365 ] 11 sc7 11648 11903
[ 7.6368 ] 12 xusb-fw 11904 12287
[ 7.6368 ] 13 cpu-bootloader 12288 20479
[ 7.6368 ] 14 bootloader-dtb 20480 21375
[ 7.6368 ] 15 secure-os 21376 26495
[ 7.6368 ] 16 eks 26496 26623
[ 7.6368 ] 17 adsp-fw 26624 28671
[ 7.6368 ] 18 rce-fw 28672 30719
[ 7.6368 ] 19 sce-fw 30720 32767
[ 7.6368 ] 20 bpmp-fw 32768 35839
[ 7.6368 ] 21 bpmp-fw-dtb 35840 37887
[ 7.6369 ] 22 reserved_for_chain_A_boot 37888 41983
[ 7.6369 ] 23 MB1_BCT_b 41984 42111
[ 7.6369 ] 24 MEM_BCT_b 42112 42623
[ 7.6369 ] 25 spe-fw_b 42624 43135
[ 7.6369 ] 26 mb2_b 43136 43647
[ 7.6369 ] 27 mts-preboot_b 43648 43775
[ 7.6369 ] 28 mts-mce_b 43776 44159
[ 7.6369 ] 29 mts-proper_b 44160 52351
[ 7.6369 ] 30 sc7_b 52352 52607
[ 7.6369 ] 31 xusb-fw_b 52608 52991
[ 7.6369 ] 32 cpu-bootloader_b 52992 61183
[ 7.6369 ] 33 bootloader-dtb_b 61184 62079
[ 7.6369 ] 34 reserved_for_chain_B_boot 62080 63359
[ 7.6369 ] 35 uefi_variables 63360 63615
[ 7.6369 ] 36 uefi_ftw 63616 63999
[ 7.6369 ] 37 BCT-boot-chain_backup 64768 64895
[ 7.6369 ] 38 reserved_partition 64896 65023
[ 7.6369 ] 39 secondary_gpt_backup 65024 65151
[ 7.6370 ] 40 VER_b 65152 65279
[ 7.6370 ] 41 VER 65280 65407
[ 7.6370 ] gpt_primary_1_3.bin:
[ 7.6370 ] partition_id partition_name StartingLba EndingLba
[ 7.6370 ] 1 APP 40 29360167
[ 7.6370 ] 2 kernel 29360168 29491239
[ 7.6370 ] 3 kernel-dtb 29491240 29492135
[ 7.6370 ] 4 reserved_for_chain_A_user 29492136 29558783
[ 7.6370 ] 5 secure-os_b 29558784 29563903
[ 7.6370 ] 6 eks_b 29563904 29564031
[ 7.6370 ] 7 adsp-fw_b 29564032 29566079
[ 7.6370 ] 8 rce-fw_b 29566080 29568127
[ 7.6370 ] 9 sce-fw_b 29568128 29570175
[ 7.6370 ] 10 bpmp-fw_b 29570176 29573247
[ 7.6370 ] 11 bpmp-fw-dtb_b 29573248 29575295
[ 7.6370 ] 12 kernel_b 29575296 29706367
[ 7.6370 ] 13 kernel-dtb_b 29706368 29707263
[ 7.6370 ] 14 reserved_for_chain_B_user 29707264 29773823
[ 7.6370 ] 15 recovery 29773824 29937663
[ 7.6371 ] 16 recovery-dtb 29937664 29938687
[ 7.6371 ] 17 RECROOTFS 29938688 30143487
[ 7.6371 ] 18 esp 30143488 30274559
[ 7.6371 ] 19 recovery_alt 30274560 30438399
[ 7.6371 ] 20 recovery-dtb_alt 30438400 30439423
[ 7.6371 ] 21 esp_alt 30439424 30570495
[ 7.6371 ] 22 UDA 30570496 30777303
[ 7.6371 ] gpt_secondary_1_3.bin:
[ 7.6371 ] partition_id partition_name StartingLba EndingLba
[ 7.6371 ] 1 APP 40 29360167
[ 7.6371 ] 2 kernel 29360168 29491239
[ 7.6371 ] 3 kernel-dtb 29491240 29492135
[ 7.6371 ] 4 reserved_for_chain_A_user 29492136 29558783
[ 7.6371 ] 5 secure-os_b 29558784 29563903
[ 7.6371 ] 6 eks_b 29563904 29564031
[ 7.6371 ] 7 adsp-fw_b 29564032 29566079
[ 7.6371 ] 8 rce-fw_b 29566080 29568127
[ 7.6371 ] 9 sce-fw_b 29568128 29570175
[ 7.6372 ] 10 bpmp-fw_b 29570176 29573247
[ 7.6372 ] 11 bpmp-fw-dtb_b 29573248 29575295
[ 7.6372 ] 12 kernel_b 29575296 29706367
[ 7.6372 ] 13 kernel-dtb_b 29706368 29707263
[ 7.6372 ] 14 reserved_for_chain_B_user 29707264 29773823
[ 7.6372 ] 15 recovery 29773824 29937663
[ 7.6372 ] 16 recovery-dtb 29937664 29938687
[ 7.6372 ] 17 RECROOTFS 29938688 30143487
[ 7.6372 ] 18 esp 30143488 30274559
[ 7.6372 ] 19 recovery_alt 30274560 30438399
[ 7.6372 ] 20 recovery-dtb_alt 30438400 30439423
[ 7.6372 ] 21 esp_alt 30439424 30570495
[ 7.6372 ] 22 UDA 30570496 30777303
[ 7.6372 ]
[ 7.6373 ] Start flashing
[ 7.6387 ] tegradevflash_v2 --pt flash.xml.bin --create
[ 7.6389 ] Bootloader version 01.00.0000
[ 7.6633 ] Erasing spi: 0 ......... [Done]
[ 76.6716 ] Writing partition secondary_gpt with gpt_secondary_3_0.bin [ 16896 bytes ]
[ 76.6726 ] [................................................] 100%
[ 76.8066 ] Erasing sdmmc_user: 3 ......... [Done]
[ 77.7054 ] Writing partition master_boot_record with mbr_1_3.bin [ 512 bytes ]
[ 77.7057 ] [................................................] 100%
[ 77.7068 ] Writing partition primary_gpt with gpt_primary_1_3.bin [ 16896 bytes ]
[ 77.7139 ] [................................................] 100%
[ 77.7155 ] Writing partition secondary_gpt with gpt_secondary_1_3.bin [ 16896 bytes ]
[ 77.7363 ] [................................................] 100%
[ 77.7576 ] Writing partition mb1 with mb1_t194_prod_aligned_sigheader.bin.encrypt [ 249008 bytes ]
[ 77.7589 ] [................................................] 100%
[ 77.7694 ] Writing partition mb1_b with mb1_b_t194_prod_aligned_sigheader.bin.encrypt [ 249008 bytes ]
[ 79.5144 ] [................................................] 100%
[ 79.5253 ] Writing partition spe-fw with spe_t194_sigheader.bin.encrypt [ 95232 bytes ]
[ 81.2695 ] [................................................] 100%
[ 81.2743 ] Writing partition mb2 with nvtboot_t194_sigheader.bin.encrypt [ 207584 bytes ]
[ 81.9415 ] [................................................] 100%
[ 81.9501 ] Writing partition mts-preboot with preboot_c10_prod_cr_sigheader.bin.encrypt [ 24016 bytes ]
[ 83.4039 ] [................................................] 100%
[ 83.4057 ] Writing partition mts-mce with mce_c10_prod_cr_sigheader.bin.encrypt [ 145184 bytes ]
[ 83.5767 ] [................................................] 100%
[ 83.5833 ] Writing partition mts-proper with mts_c10_prod_cr_sigheader.bin.encrypt [ 3429968 bytes ]
[ 84.5995 ] [................................................] 100%
[ 106.6757 ] Writing partition sc7 with warmboot_t194_prod_sigheader.bin.encrypt [ 55264 bytes ]
[ 108.6621 ] [................................................] 100%
[ 108.6651 ] Writing partition xusb-fw with xusb_sil_rel_fw [ 129024 bytes ]
[ 109.0517 ] [................................................] 100%
[ 109.0674 ] Writing partition cpu-bootloader with nvdisp-init_sigheader.bin.encrypt [ 3215360 bytes ]
[ 109.9687 ] [................................................] 100%
[ 132.0204 ] Writing partition bootloader-dtb with tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt [ 335936 bytes ]
[ 132.5075 ] [................................................] 100%
[ 132.5217 ] Writing partition secure-os with tos-optee_t194_sigheader.img.encrypt [ 1137424 bytes ]
[ 134.8680 ] [................................................] 100%
[ 142.2249 ] Writing partition eks with eks_t194_sigheader.img.encrypt [ 5136 bytes ]
[ 142.8486 ] [................................................] 100%
[ 142.8504 ] Writing partition adsp-fw with adsp-fw_sigheader.bin.encrypt [ 396848 bytes ]
[ 142.8929 ] [................................................] 100%
[ 142.9104 ] Writing partition rce-fw with camera-rtcpu-t194-rce_sigheader.img.encrypt [ 529776 bytes ]
[ 145.6809 ] [................................................] 100%
[ 145.7065 ] Writing partition bpmp-fw with bpmp-2_t194_sigheader.bin.encrypt [ 1007392 bytes ]
[ 149.4008 ] [................................................] 100%
[ 149.4394 ] Writing partition bpmp-fw-dtb with tegra194-a02-bpmp-p3668-a00_lz4_sigheader.dtb.encrypt [ 42864 bytes ]
[ 156.4596 ] [................................................] 100%
[ 156.4617 ] Writing partition spe-fw_b with spe_t194_sigheader.bin.encrypt [ 95232 bytes ]
[ 156.7648 ] [................................................] 100%
[ 156.7692 ] Writing partition mb2_b with nvtboot_t194_sigheader.bin.encrypt [ 207584 bytes ]
[ 157.4353 ] [................................................] 100%
[ 157.4437 ] Writing partition mts-preboot_b with preboot_c10_prod_cr_sigheader.bin.encrypt [ 24016 bytes ]
[ 158.8943 ] [................................................] 100%
[ 158.8961 ] Writing partition mts-mce_b with mce_c10_prod_cr_sigheader.bin.encrypt [ 145184 bytes ]
[ 159.0677 ] [................................................] 100%
[ 159.0746 ] Writing partition mts-proper_b with mts_c10_prod_cr_sigheader.bin.encrypt [ 3429968 bytes ]
[ 160.0903 ] [................................................] 100%
[ 182.1708 ] Writing partition sc7_b with warmboot_t194_prod_sigheader.bin.encrypt [ 55264 bytes ]
[ 184.1572 ] [................................................] 100%
[ 184.1601 ] Writing partition xusb-fw_b with xusb_sil_rel_fw [ 129024 bytes ]
[ 184.5469 ] [................................................] 100%
[ 184.5529 ] Writing partition cpu-bootloader_b with nvdisp-init_sigheader.bin.encrypt [ 3215360 bytes ]
[ 185.4545 ] [................................................] 100%
[ 207.5234 ] Writing partition bootloader-dtb_b with tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt [ 335936 bytes ]
[ 208.0112 ] [................................................] 100%
[ 208.0251 ] Writing partition VER_b with qspi_bootblob_ver.txt [ 109 bytes ]
[ 210.3698 ] [................................................] 100%
[ 210.3799 ] Writing partition VER with qspi_bootblob_ver.txt [ 109 bytes ]
[ 210.3847 ] [................................................] 100%
[ 210.3858 ] Writing partition master_boot_record with mbr_1_3.bin [ 512 bytes ]
[ 210.3907 ] [................................................] 100%
[ 210.3921 ] Writing partition APP with system.img [ 9486422880 bytes ]
[ 210.3979 ] [................................................] 100%
[ 776.5774 ] Writing partition kernel with boot.img [ 43868160 bytes ]
[ 776.6296 ] [................................................] 100%
[ 779.2293 ] Writing partition kernel-dtb with kernel_tegra194-p3668-all-p3509-0000.dtb [ 320586 bytes ]
[ 779.2520 ] [................................................] 100%
[ 779.2599 ] Writing partition secure-os_b with tos-optee_t194_sigheader.img.encrypt [ 1137424 bytes ]
[ 779.2790 ] [................................................] 100%
[ 779.3382 ] Writing partition eks_b with eks_t194_sigheader.img.encrypt [ 5136 bytes ]
[ 779.3652 ] [................................................] 100%
[ 779.3733 ] Writing partition adsp-fw_b with adsp-fw_sigheader.bin.encrypt [ 396848 bytes ]
[ 779.3874 ] [................................................] 100%
[ 779.3947 ] Writing partition rce-fw_b with camera-rtcpu-t194-rce_sigheader.img.encrypt [ 529776 bytes ]
[ 779.4210 ] [................................................] 100%
[ 779.4360 ] Writing partition bpmp-fw_b with bpmp-2_t194_sigheader.bin.encrypt [ 1007392 bytes ]
[ 779.4705 ] [................................................] 100%
[ 779.5088 ] Writing partition bpmp-fw-dtb_b with tegra194-a02-bpmp-p3668-a00_lz4_sigheader.dtb.encrypt [ 42864 bytes ]
[ 779.5489 ] [................................................] 100%
[ 779.5573 ] Writing partition kernel_b with boot.img [ 43868160 bytes ]
[ 779.5626 ] [................................................] 100%
[ 782.4127 ] Writing partition kernel-dtb_b with kernel_tegra194-p3668-all-p3509-0000.dtb [ 320586 bytes ]
[ 782.4346 ] [................................................] 100%
[ 782.4428 ] Writing partition recovery with recovery.img [ 50601984 bytes ]
[ 782.4626 ] [................................................] 100%
[ 785.3101 ] Writing partition recovery-dtb with tegra194-p3668-all-p3509-0000.dtb.rec [ 320586 bytes ]
[ 785.3252 ] [................................................] 100%
[ 785.3330 ] Writing partition esp with esp.img [ 67108864 bytes ]
[ 785.3529 ] [................................................] 100%
[ 789.3186 ] tegradevflash_v2 --write BCT br_bct_BR.bct
[ 789.3198 ] Bootloader version 01.00.0000
[ 789.3460 ] Writing partition BCT with br_bct_BR.bct [ 2888 bytes ]
[ 789.3462 ] [................................................] 100%
[ 789.4722 ] tegradevflash_v2 --write BCT-boot-chain_backup bct_backup.img
[ 789.4736 ] Bootloader version 01.00.0000
[ 789.4990 ] Writing partition BCT-boot-chain_backup with bct_backup.img [ 32768 bytes ]
[ 789.5006 ] [................................................] 100%
[ 789.7573 ] tegradevflash_v2 --write MB1_BCT mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 789.7587 ] Bootloader version 01.00.0000
[ 789.7841 ] Writing partition MB1_BCT with mb1_cold_boot_bct_MB1_sigheader.bct.encrypt [ 30416 bytes ]
[ 789.7861 ] [................................................] 100%
[ 790.0046 ] tegradevflash_v2 --write MB1_BCT_b mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 790.0060 ] Bootloader version 01.00.0000
[ 790.0310 ] Writing partition MB1_BCT_b with mb1_cold_boot_bct_MB1_sigheader.bct.encrypt [ 30416 bytes ]
[ 790.0329 ] [................................................] 100%
[ 790.2580 ] tegradevflash_v2 --write MEM_BCT mem_coldboot_sigheader.bct.encrypt
[ 790.2585 ] Bootloader version 01.00.0000
[ 790.2838 ] Writing partition MEM_BCT with mem_coldboot_sigheader.bct.encrypt [ 198656 bytes ]
[ 790.2856 ] [................................................] 100%
[ 791.6930 ] tegradevflash_v2 --write MEM_BCT_b mem_coldboot_sigheader.bct.encrypt
[ 791.6942 ] Bootloader version 01.00.0000
[ 791.7206 ] Writing partition MEM_BCT_b with mem_coldboot_sigheader.bct.encrypt [ 198656 bytes ]
[ 791.7222 ] [................................................] 100%
[ 793.1167 ] Flashing completed
[ 793.1168 ] Coldbooting the device
[ 793.1195 ] tegrarcm_v2 --ismb2
[ 793.1477 ] tegradevflash_v2 --reboot coldboot
[ 793.1486 ] Bootloader version 01.00.0000
*** The target t186ref has been flashed successfully. ***
Reset the board to boot from internal eMMC.
