Jetson unable to handle multiple Realsense Camera streams
Hello everyone,
I am using the Jetson Nano development kit for implementing computer vision on an autonomous robotic platform. I have a setup of multiple RealSense cameras (one for each side of the platform) and am implementing a segmentation model. The project runs successfully when I use my laptop (through it doesn’t have any GPU cores) but fails when I run it on the Jetson. The project is successful only on 1 camera, but when I send a UDP request to get the image from another camera attached to the Jetson, it fails showing a memory access error.
I have taken screenshots of the GPU stats (which show high memory usage), as well the error pasted below. It would be great if I could get suggestions on hardware/memory optimizations I could include so that it runs smoothly on a multi-camera setup using the Jetson.
Error:
Receiving images from camera 11
2
2025-08-21 11:03:37.602821438 [E:onnxruntime:Default, cuda_call.cc:123 CudaCall] CUDA failure 700: an illegal memory access was encountered ; GPU=0 ; hostname=metazet-desktop ; file=/opt/onnxruntime/onnxruntime/core/providers/cuda/gpu_data_transfer.cc ; line=65 ; expr=cudaMemcpyAsync(dst_data, src_data, bytes, cudaMemcpyHostToDevice, static_cast<cudaStream_t>(stream.GetHandle()));
2025-08-21 11:03:37.603099485 [E:onnxruntime:Default, cuda_call.cc:123 CudaCall] CUDA failure 700: an illegal memory access was encountered ; GPU=0 ; hostname=metazet-desktop ; file=/opt/onnxruntime/onnxruntime/core/providers/cuda/cuda_execution_provider.cc ; line=446 ; expr=cudaStreamSynchronize(static_cast<cudaStream_t>(stream_));
File “/home/metazet/path_detection_jetson/software4metazet/run_segmentation_BART.py”, line 1592, in
main()
File “/home/metazet/path_detection_jetson/software4metazet/run_segmentation_BART.py”, line 1584, in main
model.run_deploy()
File “/home/metazet/path_detection_jetson/software4metazet/run_segmentation_BART.py”, line 1196, in run_deploy
interface.handle_udp_requests()
File “/home/metazet/path_detection_jetson/software4metazet/communication.py”, line 173, in handle_udp_requests
result = self.run_row_detection_callback(actual_cam_id)
File “/home/metazet/path_detection_jetson/software4metazet/run_segmentation_BART.py”, line 209, in run_row_detection
result = self.run_inference(bgr_img, depth_img, key)
File “/home/metazet/path_detection_jetson/software4metazet/run_segmentation_BART.py”, line 313, in run_inference
self.run_model()
File “/home/metazet/path_detection_jetson/software4metazet/run_segmentation_BART.py”, line 373, in run_model
output = self.inferencer.process_image(self.bgr_img)
File “/home/metazet/path_detection_jetson/software4metazet/smp_default_model_run.py”, line 66, in process_image
result = self.ort_session.run(
File “/home/metazet/.local/lib/python3.10/site-packages/onnxruntime/capi/onnxruntime_inference_collection.py”, line 273, in run
return self._sess.run(output_names, input_feed, run_options)
onnxruntime.capi.onnxruntime_pybind11_state.Fail: [ONNXRuntimeError] : 1 : FAIL : CUDA failure 700: an illegal memory access was encountered ; GPU=0 ; hostname=metazet-desktop ; file=/opt/onnxruntime/onnxruntime/core/providers/cuda/gpu_data_transfer.cc ; line=65 ; expr=cudaMemcpyAsync(dst_data, src_data, bytes, cudaMemcpyHostToDevice, static_cast<cudaStream_t>(stream.GetHandle()));
terminate called after throwing an instance of ‘onnxruntime::OnnxRuntimeException’
what(): /opt/onnxruntime/onnxruntime/core/providers/cuda/cuda_call.cc:129 std::conditional_t<THRW, void, onnxruntime::common::Status> onnxruntime::CudaCall(ERRTYPE, const char*, const char*, SUCCTYPE, const char*, const char*, int) [with ERRTYPE = cudaError; bool THRW = true; SUCCTYPE = cudaError; std::conditional_t<THRW, void, onnxruntime::common::Status> = void] /opt/onnxruntime/onnxruntime/core/providers/cuda/cuda_call.cc:121 std::conditional_t<THRW, void, onnxruntime::common::Status> onnxruntime::CudaCall(ERRTYPE, const char*, const char*, SUCCTYPE, const char*, const char*, int) [with ERRTYPE = cudaError; bool THRW = true; SUCCTYPE = cudaError; std::conditional_t<THRW, void, onnxruntime::common::Status> = void] CUDA failure 700: an illegal memory access was encountered ; GPU=0 ; hostname=metazet-desktop ; file=/opt/onnxruntime/onnxruntime/core/providers/cuda/cuda_allocator.cc ; line=98 ; expr=cudaFreeHost(p);
Aborted (core dumped)
This is possible since the USB bandwidth is limited and may be insufficient for multiple cameras. It looks similar to
connected more than two usb cameras problem on deepstream-app (Jetson Nano Dev Kit) - #12 by DaneLLL
