After flashing Jetson TX2 it does not boot it is stuck at the step where you need to complete Ubuntu setup before installing SDK components
The device is stuck at “Please complete system configuration setup on /dev/ttyGS0 to proceed…”
Followed by “(1/2 of 2) A Start Job is running for end-user configuration after initial OEM installation”
and will not boot into graphical environment to proceed. SSH is not enabled and the SDK manager can no longer connect to the device.
I was attempting to re-flash with a modified kernel for an avuidea J90 carrier board.
How can I recover my device?
Thank you.
