Jetson won't boot after update TOS image
@JerryChang ,
Thanks for your reply.
I tested it. The output seems to be like the one above:
ERR [4243] TEES:main:905: failed to find an OP-TEE supplicant device.
Did you find any insight on the internal thread for tracking?
Best,
hello jdiegodelgado,
this still look like a permission issue since the optee kernel driver is up and “/dev/teepriv0” exists.
the error reported means tee-supplicant cannot open the file.
please examine the permission of the device file, $ ls -la /dev/teepriv0
@JerryChang ,
Permissions:
nvidia@tegra-ubuntu:~$ ls -la /dev/teepriv0
crw------- 1 root root 243, 16 Apr 11 20:31 /dev/teepriv0
Best,
can it works by chmod to 664 or 644?
Hi @JerryChang ,
Changed the permissions for the one that you suggested, but problem persists.
crw-rw-r-- 1 root root 243, 16 Sep  8  2022 /dev/teepriv0
$ sudo tee-supplicant
ERR [8652] TEES:main:905: failed to find an OP-TEE supplicant device
Best,
oh… had you update tee-supplicant , or you’re using the default app under rootfs for verification?
please refer to atf_and_optee_README.txt for step-3. within [Verifying the Image] section.
this means all the user-space files under /install should copy to your target.
  1. Copy all the files under ./optee/install/t<platform> to the target.
furthermore, please share all steps in details if you still cannot resolve this issue.
for example,
the command to build the OP-TEE source package, OP-TEE dtb, ATF source code…etc, and, you should generate the tos.img with python script.
what exactly binaries you’ve replace with. finally, the steps you’ve done to flash the target.
Hi @JerryChang ,
This time I did not use a custom approach. I’m using the default app that comes with JetPack 5.1
Best,
however, $ sudo xtest is able to run with the native JetPack release, I’ve tested locally.
I reflashed everything and now it seems to work. Is this output normal?
$sudo xtest
Run test suite with level=0
TEE test application started over default TEE instance
# regression+pkcs11
* regression_1001 Core self tests
 - 1001 -   skip test, pseudo TA not found
  regression_1001 OK
* regression_1002 PTA parameters
 - 1002 -   skip test, pseudo TA not found
  regression_1002 OK
* regression_1003 Core internal read/write mutex
 - 1003 -   skip test, pseudo TA not found
  regression_1003 OK
* regression_1004 Test User Crypt TA
o regression_1004.1 AES encrypt
  regression_1004.1 OK
o regression_1004.2 AES decrypt
  regression_1004.2 OK
o regression_1004.3 SHA-256 test, 3 bytes input
  regression_1004.3 OK
o regression_1004.4 AES-256 ECB encrypt (32B, fixed key)
  regression_1004.4 OK
o regression_1004.5 AES-256 ECB decrypt (32B, fixed key)
  regression_1004.5 OK
  regression_1004 OK
* regression_1005 Many sessions
  regression_1005 OK
Best
yes, that’s looks normal.
BTW, it should be lots of test sessions, you’ve omitted the $ sudo xtest output logs, right?
@JerryChang ,
Yes! I omitted the rest of the logs. At the end I saw this:
30161 subtests of which 0 failed
125 test cases of which 0 failed
0 test cases were skipped
TEE test application done!
Thanks for your help. One last question (I don’t know if we need a new thread for this), but do you have a guide or steps in case I want to develop a Trusted Application, like a dummy “hello world” for a Jetson platform?
[optee_examples — OP-TEE documentation documentation]
Best,
here’s developer guide. OP-TEE: Open Portable Trusted Execution Environment — Jetson Linux Developer Guide documentation
you may see-also public sources for OP-TEE hwkey-agent TA/CA example.
there’s also a README file it provides an overview of the hwkey-app and how to compile and use it.
for instance,
TA: r35.3.1/Linux_for_Tegra/source/public/atf_and_optee/optee/samples/hwkey-agent/ta/
CA: r35.3.1/Linux_for_Tegra/source/public/atf_and_optee/optee/samples/hwkey-agent/
let’s close this, and have a new thread if you need further supports.
thanks
