Jetson xaiver nx GPU problem
Jetpack:4.6 [L4T 32.6.1]
At the beginning of running the program, the GPU rate was 30% -40%. After running for about 10 days, the GPU rate was 60%-70%,why?
This may depend on the use-case. Do you run TensorRT or graphics app on GPU? Probably GPU is handling more frame data in the condition.
The frame rate of the image is 140 frames per second, which has been the same throughout the program from the beginning until encountering problems. When the GPU usage rate reached 64%, I restarted the program and the GPU usage rate returned to 30% -40%.
