Hi there!
I been working in docker for a while and i found a problem running the example from docker checkpoint documentation: Link to Docker Checkpoint
Running the command i get this error:
$ docker checkpoint create cr checkpoint1
Error response from daemon: Cannot checkpoint container cr: nvidia-container-runtime did not terminate successfully: exit status 1: criu failed: type NOTIFY errno 0 path= /run/containerd/io.containerd.runtime.v2.task/moby/702011d32f4b26bcc119793feb376169ca2bb287ba1f466caa6bdf68f4a608f9/criu-dump.log: unknown
After looking the criu-dump.log file i found this at the end:
(00.003611) Error (criu/proc_parse.c:2571): Can't open 12081/task/12081/children on procfs: No such file or directory
(00.003645) Collected (0 attempts, -1 in_progress)
(00.003714) Unlock network
(00.003802) Unfreezing tasks into 1
(00.003843) Error (criu/cr-dump.c:1709): Dumping FAILED.
My Jetson characteristics are:
- Jetson Xavier AGX
- Linux ubuntu 4.9.299-tegra #1 SMP PREEMPT Tue Nov 22 09:24:30 PST 2022 aarch64 GNU/Linux
- R32 (release), REVISION: 7.3, GCID: 31982016, BOARD: t186ref, EABI: aarch64, DATE: Tue Nov 22 17:32:54 UTC 2022
- docker version 20.10.12
- CRIU Version: 3.6
I want to know why this error is happening and how to fully run the checkpoint flow work.
Regards.
Could you try if it works with sudo
$ sudo docker ...
Thanks @AastaLLL.
The same message pops out:
/moby/609c20a3ca67f7d1c4d1affb7ed0f21f5f9c7ba04b380506d1b88c7702d50c00/criu-dump.log: unknown
Based on the below ticket in NV container, checkpoint is not supported.
system
Closed
7
