Xavier AGX Devkit uses a power MCU EFM8SB10F2G, and its firmware is available in download center right?
We have flashed earlier version and now want to check weather the same old version is compatible with L4T 32.4.3? or how to get this detail? I see current firmware version is 0.11
I am not sure about the earlier version we have used its back in 2019. I just wanted more detail on the firmware and version compatibility with BSPs
hello venkatraman.bhat,
are you taking about Power Button Supervisor Firmware?
We have followed OEM guide for power button supervisor circuit and flashed the firmware binary on Xavier AGX. but we are observing Post Shutdown auto Reboot problem in the board. we have seen this issue in 10% of the cases and
when the "max mode "of the GPU used then shutdown, the reboot issue is seen.
Can you please suggest a solution or a work around?
could you please share the error logs for reference,
thanks
