Working on Ubuntu Desktop 18.04.2 with a Jetson-Xavier that has stopped working.
The UART Debug channel throws
[0010063.673] I> MB1 (prd-version: 1.0.0.0-t194-41334769-a3872862)
[0063.678] I> Boot-mode: L1 RCM
[0063.681] I> chip revision : A02
[0063.684] I> Bootrom patch version : 7 (correctly patched)
[0063.689] I> ATE fuse revision : 0x200
[0063.693] I> Ram repair fuse : 0x0
[0063.696] I> Ram Code : 0x0
[0063.698] I> rst_source : 0xb
[0063.701] I> rst_level : 0x1
[0063.705] I> USB configuration success
[0065.959] I> Command received is 1
[0066.251] I> Command received is 1
[0066.259] I> Command received is 2
[0066.264] I> bct_bootrom image downloaded
[0066.271] I> Command received is 2
[0066.279] E> No fuse-bypass data
[0066.282] E> MB1_PLATFORM_CONFIG: device prod data is empty in MB1 BCT.
[0066.288] E> MB1_PLATFORM_CONFIG: Failed to initialize device prod.
[0066.295] I> temperature = 39500
[0066.298] W> Skipping boost for clk:bpmp_cpu_nic
[0066.303] W> Skipping boost for clk:bpmp_apb
[0066.306] W> Skipping boost for clk:axi_cbb
[0066.310] W> Skipping boost for clk:aon_cpu_nic
[0066.315] W> Skipping boost for clk:aon_can0
[0066.319] W> Skipping boost for clk:aon_can1
[0066.323] I> Boot-device: eMMC
[0066.326] I> Boot-device: eMMC
[0066.329] W> DEVICE_PROD: device prod is not initialized.
[0066.334] W> DEVICE_PROD: device prod is not initialized.
[0066.353] I> Sdmmc: HS400 mode enabled
[0066.357] I> bct_mb1 image downloaded
[0066.363] I> Command received is 2
[0066.374] I> ECC region[0]: Start:0x0, End:0x0
[0066.378] I> ECC region[1]: Start:0x0, End:0x0
[0066.382] I> ECC region[2]: Start:0x0, End:0x0
[0066.386] I> ECC region[3]: Start:0x0, End:0x0
[0066.390] I> ECC region[4]: Start:0x0, End:0x0
[0066.395] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0066.400] I> Non-ECC region[1]: Start:0x0, End:0x0
[0066.405] I> Non-ECC region[2]: Start:0x0, End:0x0
[0066.409] I> Non-ECC region[3]: Start:0x0, End:0x0
[0066.414] I> Non-ECC region[4]: Start:0x0, End:0x0
[0066.420] W> MB1_PLATFORM_CONFIG: Rail ID 9 not found in pmic rail config table.
[0066.427] E> FAILED: Thermal config
[0066.430] W> DEVICE_PROD: device prod is not initialized.
[0066.435] W> DEVICE_PROD: device prod is not initialized.
[0066.444] W> MB1_PLATFORM_CONFIG: Rail ID 7 not found in pmic rail config table.
[0066.451] E> FAILED: MEMIO rail config
[0066.464] E> task 40 failed (err: 0x1c)
[0066.467] E> top caller module: NONE, error module: NONE, reason: 0x1c, aux_info: 0x00
[0066.475] I> MB1(1.0.0.0-t194-41334769-a3872862) BIT boot status dump :
1111111111110000111111111111001100001111100000000000000000000000000000000000000000000000000000000000000000000000000000000000000011001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
And The Jetpack 4.1 installer fails with the output:
[ 9.5355 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem tmpPCVisQ1_1_sigheader.bct.encrypt
[ 9.5373 ] Applet version 01.00.0000
[ 9.8257 ] Sending bct_bootrom
[ 9.8260 ] [................................................] 100%
[ 9.8323 ] Sending bct_mb1
[ 9.8378 ] [................................................] 100%
[ 9.8471 ] Sending bct_mem
[ 9.9303 ] [................................................] 100%
[ 10.0775 ]
Error: Return value 8
Command tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem tmpPCVisQ1_1_sigheader.bct.encrypt
Failed flashing t186ref.
I get the same error when trying to flash Jetpack 4.2
I have run through the forums but there is no obvious place to find the meaning of this return value and the debug error is equally unhelpful.
