Pls I have a problem with the camera driver .
avdd-cam-2v8 required by the camera deserializer is disabled.
The device node cannot be generated because the driver reports an error.
[ 0.518081] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 3.442414] vdd-1v0: supplied by regulator-dummy
[ 3.448205] vdd-1v8-hs: supplied by regulator-dummy
[ 3.453231] vdd-1v8-ls: supplied by regulator-dummy
[ 3.458273] vdd-1v8-ao: supplied by regulator-dummy
[ 3.462481] vddio-ddr-1v1: supplied by regulator-dummy
[ 3.467432] vdd-rtc: supplied by regulator-dummy
[ 3.471181] vdd-ao-3v3: supplied by regulator-dummy
[ 3.477930] vddio-emmc-3v3: supplied by regulator-dummy
[ 3.486218] vdd-usb-3v3: supplied by regulator-dummy
[ 3.492867] vddio-sdmmc1-3v3: supplied by regulator-dummy
[ 3.499717] vdd-csi-1v2: supplied by vdd-1v8-ls
[ 3.505828] spmic-ldo8: supplied by vdd-1v8-ls
[ 8.948483] tegradc 15200000.display: dc_hdmi_hotplug_init: couldn’t get regulator vdd_hdmi_5v0, -517
[ 9.272095] vdd-5v-usb: supplied by vdd-ac-bat
[ 41.952639] vdd-3v3-cvb: disabling
[ 41.952649] p2822_vdd_1v8_cvb: disabling
[ 41.952654] vdd-epb-1v0: disabling
[ 41.952659] vdd-sata-1v5: disabling
[ 41.952663] vdd-1v8-slt: disabling
[ 41.952666] vdd-3v3-slt: disabling
[ 41.952671] vdd-3v3-pcie: disabling
[ 41.952679] vdd-1v8-sd: disabling
[ 41.952683] vdd-sdmmc1-sw: disabling
[ 41.952687] avdd-cam-2v8: disabling
[ 41.952692] vdd_sys_en: disabling
[ 41.952696] vdd-12v-pcie: disabling
My version is Xavier jetpack SDK 5.0.1. This is my tegra194-fixed-regulator-p2822-1000.dtsi and tegra194-camera-ar0231-a00.dtsi
tegra194-fixed-regulator-p2822-1000.dtsi (4.6 KB)
tegra194-camera-ar0231-a00.dtsi (32.1 KB)
hello 1098852226,
JetPack-5.0.1 is a developer preview release and it’ll deprecate soon.
please moving to JetPack-5.0.2 since it’s the latest production release.
thanks
