[JETSON XAVIER] ERROR from primary_gie_classifier: NvBufSurfTransform failed with error -2 while con...
Hi.
I need help to fix this ERROR from primary_gie_classifier: NvBufSurfTransform failed with error -2 while converting buffer error.
I’m running deepstream-app -c source12_1080p_dec_infer-resnet_tracker_tiled_display_fp16_tx2_teste.txt
Creating LL OSD context new
0:00:06.669589624  4288      0x546ee70 WARN                 nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:checkEngineParams(): Requested Max Batch Size is less than engine batch size
0:00:06.673240148  4288      0x546ee70 INFO                 nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
0:00:06.674043382  4288      0x546ee70 WARN                 nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:generateTRTModel(): INT8 calibration file not specified. Trying FP16 mode.
0:00:15.643457716  4288      0x546ee70 INFO                 nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:generateTRTModel(): Storing the serialized cuda engine to file at /usr/src/tensorrt/samples/python/end_to_end_tensorflow_mnist/models/lenet5.uff_b8_fp16.engine
Runtime commands:
	h: Print this help
	q: Quit
	p: Pause
	r: Resume
**PERF: FPS 0 (Avg)	FPS 1 (Avg)	FPS 2 (Avg)	FPS 3 (Avg)	FPS 4 (Avg)	FPS 5 (Avg)	FPS 6 (Avg)	FPS 7 (Avg)	FPS 8 (Avg)	FPS 9 (Avg)	FPS 10 (Avg)	FPS 11 (Avg)
**PERF: 0.00 (0.00)	0.00 (0.00)	0.00 (0.00)	0.00 (0.00)	0.00 (0.00)	0.00 (0.00)	0.00 (0.00)	0.00 (0.00)	0.00 (0.00)	0.00 (0.00)	0.00 (0.00)	0.00 (0.00)
** INFO: <bus_callback:189>: Pipeline ready
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
** INFO: <bus_callback:175>: Pipeline running
0:00:16.730014705  4288      0x4e4c720 WARN                 nvinfer gstnvinfer.cpp:1149:convert_batch_and_push_to_input_thread:<primary_gie_classifier> error: NvBufSurfTransform failed with error -2 while converting buffer
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(1149): convert_batch_and_push_to_input_thread (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie_classifier
Quitting
ERROR from qtdemux3: Internal data stream error.
Debug info: qtdemux.c(6073): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin0/GstQTDemux:qtdemux3:
streaming stopped, reason error (-5)
ERROR from qtdemux9: Internal data stream error.
Debug info: qtdemux.c(6073): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin9/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin9/GstQTDemux:qtdemux9:
ERROR from qtdemux0: Internal data stream error.
Debug info: qtdemux.c(6073): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin1/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin1/GstQTDemux:qtdemux0:
ERROR from qtdemux2: Internal data stream error.
Debug info: qtdemux.c(6073): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin4/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin4/GstQTDemux:qtdemux2:
ERROR from qtdemux5: Internal data stream error.
Debug info: qtdemux.c(6073): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin5/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin5/GstQTDemux:qtdemux5:
ERROR from qtdemux8: Internal data stream error.
Debug info: qtdemux.c(6073): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin8/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin8/GstQTDemux:qtdemux8:
ERROR from qtdemux6: Internal data stream error.
Debug info: qtdemux.c(6073): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin3/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin3/GstQTDemux:qtdemux6:
ERROR from multiqueue5: Internal data stream error.
Debug info: gstmultiqueue.c(2357): gst_multi_queue_sink_event (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin3/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin3/GstMultiQueue:multiqueue5:
App run failed
the source file source12_1080p_dec_infer-resnet_tracker_tiled_display_fp16_tx2_teste.txt is a copy of the file source12_1080p_dec_infer-resnet_tracker_tiled_display_fp16_tx2.txt
# Copyright (c) 2019 NVIDIA Corporation.  All rights reserved.
# NVIDIA Corporation and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto.  Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA Corporation is strictly prohibited.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=0
rows=4
columns=3
width=1280
height=720
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=3
uri=file://../../streams/sample_1080p_h264.mp4
num-sources=12
#drop-frame-interval=2
gpu-id=0
# (0): memtype_device   - Memory type Device
# (1): memtype_pinned   - Memory type Host Pinned
# (2): memtype_unified  - Memory type Unified
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=5
sync=1
source-id=0
gpu-id=0
qos=0
nvbuf-memory-type=0
overlay-id=1
[sink1]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
sync=0
#iframeinterval=10
bitrate=2000000
output-file=out.mp4
source-id=0
[sink2]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=1
sync=0
bitrate=4000000
# set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=12
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1200
height=1200
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
##enable=1
#gpu-id=0
#model-engine-file=/usr/src/tensorrt/bin/lenet5.engine
#batch-size=12
#bbox-border-color0=1;0;0;1
#bbox-border-color1=0;1;1;1
#bbox-border-color2=0;0;1;1
#bbox-border-color3=0;1;0;1
#interval=4
#gie-unique-id=1
#nvbuf-memory-type=0
enable=1
gpu-id=0
interval=4
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_nano_teste.txt
[tracker]
enable=0
tracker-width=480
tracker-height=272
#ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_iou.so
ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_klt.so
#ll-config-file required for IOU only
#ll-config-file=iou_config.txt
gpu-id=0
[tests]
file-loop=0
the file config_infer_primary_nano_teste.txt is copy file the config_infer_primary_nano.txt. In my file model-color-format=2 when changed the parameter model-color-format = 2 to 0 or 1 the error changes, but I also can’t solve the problem
# Copyright (c) 2018 NVIDIA Corporation.  All rights reserved.
# Following properties are mandatory when engine files are not specified:
#   int8-calib-file(Only in INT8)
#   Caffemodel mandatory properties: model-file, proto-file, output-blob-names
#   UFF: uff-file, input-dims, uff-input-blob-name, output-blob-names
#   ONNX: onnx-file
# Mandatory properties for detectors:
#   num-detected-classes
# Optional properties for detectors:
#   enable-dbscan(Default=false), interval(Primary mode only, Default=0)
#   custom-lib-path,
#   parse-bbox-func-name
# Mandatory properties for classifiers:
#   classifier-threshold, is-classifier
# Optional properties for classifiers:
#   classifier-async-mode(Secondary mode only, Default=false)
# Optional properties in secondary mode:
#   operate-on-gie-id(Default=0), operate-on-class-ids(Defaults to all classes),
#   input-object-min-width, input-object-min-height, input-object-max-width,
#   input-object-max-height
# Following properties are always recommended:
#   batch-size(Default=1)
# Other optional properties:
#   net-scale-factor(Default=1), network-mode(Default=0 i.e FP32),
#   model-color-format(Default=0 i.e. RGB) model-engine-file, labelfile-path,
#   mean-file, gie-unique-id(Default=0), offsets, gie-mode (Default=1 i.e. primary),
#   custom-lib-path, network-mode(Default=0 i.e FP32)
# The values in the config file are overridden by values set through GObject
# properties.
    [property]
    gpu-id=0
    net-scale-factor=0.0039215697906911373
    batch-size=8
    process-mode=1
    ## 0=FP32, 1=INT8, 2=FP16 mode
    network-mode=1
    num-detected-classes=10
    interval=0
    gie-unique-id=1
    #uff-file=/usr/src/tensorrt/samples/python/uff_custom_plugin/models/trained_lenet5.uff
    #uff-file=../../models/lenet5.uff
    uff-file=/usr/src/tensorrt/samples/python/end_to_end_tensorflow_mnist/models/lenet5.uff
    #uff-input-dims=-1,28,28,0 or =3,28,28,0?
    #onnx-file=/usr/src/tensorrt/data/mnist/mnist.onnx
    #int8-calib-file=/usr/src/tensorrt/data/mnist/LegacyCalibrationTable
    input-dims=1;28;28;0
    uff-input-blob-name=input_1
    output-blob-names=dense_1/Softmax
    #output-blob-names=prob
    enable-dbscan=1
    #bbox-func-name=NvDsInferParseCustomSSD
    #custom-lib-path=/opt/nvidia/deepstream/deepstream-4.0/sources/objectDetector_SSD/nvdsinfer_custom_impl_ssd/libnvdsinfer_custom_impl_ssd.so
    [class-attrs-all]
    threshold=0.2
    group-threshold=1
    ## Set eps=0.7 and minBoxes for enable-dbscan=1
    eps=0.2
    #minBoxes=3
    roi-top-offset=0
    roi-bottom-offset=0
    detected-min-w=0
    detected-min-h=0
    detected-max-w=0
    detected-max-h=0
command deepstream-app -c source12_1080p_dec_infer-resnet_tracker_tiled_display_fp16_tx2_teste.txt
with model-color-format = 0 the error is
0:00:01.548911553  7467     0x137d5470 INFO                 nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
0:00:01.788277666  7467     0x137d5470 WARN                 nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:generateTRTModel(): INT8 calibration file not specified. Trying FP16 mode.
0:00:13.845660468  7467     0x137d5470 INFO                 nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:generateTRTModel(): Storing the serialized cuda engine to file at /usr/src/tensorrt/samples/python/end_to_end_tensorflow_mnist/models/lenet5.uff_b8_fp16.engine
0:00:13.893606770  7467     0x137d5470 ERROR                nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:initialize(): RGB/BGR input format specified but network input channels is not 3
0:00:13.899066978  7467     0x137d5470 WARN                 nvinfer gstnvinfer.cpp:692:gst_nvinfer_start:<primary_gie_classifier> error: Failed to create NvDsInferContext instance
0:00:13.899173959  7467     0x137d5470 WARN                 nvinfer gstnvinfer.cpp:692:gst_nvinfer_start:<primary_gie_classifier> error: Config file path: /opt/nvidia/deepstream/deepstream-4.0/samples/configs/deepstream-app/config_infer_primary_nano_teste.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
** ERROR: <main:651>: Failed to set pipeline to PAUSED
Quitting
ERROR from primary_gie_classifier: Failed to create NvDsInferContext instance
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(692): gst_nvinfer_start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie_classifier:
App run failed
The model is lenet5 in the repository /usr/src/tensorrt/samples/python/end_to_end_tensorflow_mnist
The .pb file was generated from the command:
python3 model.py
2020-02-21 18:38:31.934098: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/ops/resource_variable_ops.py:1630: calling BaseResourceVariable.__init__ (from tensorflow.python.ops.resource_variable_ops) with constraint is deprecated and will be removed in a future version.
Instructions for updating:
If using Keras pass *_constraint arguments to layers.
Train on 60000 samples
2020-02-21 18:38:42.677882: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcuda.so.1
2020-02-21 18:38:42.692908: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:950] ARM64 does not support NUMA - returning NUMA node zero
2020-02-21 18:38:42.693136: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1618] Found device 0 with properties:
name: Xavier major: 7 minor: 2 memoryClockRate(GHz): 1.377
pciBusID: 0000:00:00.0
2020-02-21 18:38:42.693240: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2020-02-21 18:38:42.698725: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2020-02-21 18:38:42.701888: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcufft.so.10.0
2020-02-21 18:38:42.703251: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcurand.so.10.0
2020-02-21 18:38:42.707923: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusolver.so.10.0
2020-02-21 18:38:42.711808: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusparse.so.10.0
2020-02-21 18:38:42.724635: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2020-02-21 18:38:42.725208: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:950] ARM64 does not support NUMA - returning NUMA node zero
2020-02-21 18:38:42.725670: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:950] ARM64 does not support NUMA - returning NUMA node zero
2020-02-21 18:38:42.725856: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1746] Adding visible gpu devices: 0
2020-02-21 18:38:42.776560: W tensorflow/core/platform/profile_utils/cpu_utils.cc:98] Failed to find bogomips in /proc/cpuinfo; cannot determine CPU frequency
2020-02-21 18:38:42.777955: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x328c91a0 initialized for platform Host (this does not guarantee that XLA will be used). Devices:
2020-02-21 18:38:42.778165: I tensorflow/compiler/xla/service/service.cc:176]   StreamExecutor device (0): Host, Default Version
2020-02-21 18:38:42.906570: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:950] ARM64 does not support NUMA - returning NUMA node zero
2020-02-21 18:38:42.907563: I tensorflow/compiler/xla/service/service.cc:168] XLA service 0x320a6000 initialized for platform CUDA (this does not guarantee that XLA will be used). Devices:
2020-02-21 18:38:42.907717: I tensorflow/compiler/xla/service/service.cc:176]   StreamExecutor device (0): Xavier, Compute Capability 7.2
2020-02-21 18:38:42.908672: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:950] ARM64 does not support NUMA - returning NUMA node zero
2020-02-21 18:38:42.909025: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1618] Found device 0 with properties:
2020-02-21 18:38:42.909142: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2020-02-21 18:38:42.909221: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2020-02-21 18:38:42.909279: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcufft.so.10.0
2020-02-21 18:38:42.909332: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcurand.so.10.0
2020-02-21 18:38:42.909387: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusolver.so.10.0
2020-02-21 18:38:42.909451: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusparse.so.10.0
2020-02-21 18:38:42.909543: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2020-02-21 18:38:42.909764: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:950] ARM64 does not support NUMA - returning NUMA node zero
2020-02-21 18:38:42.910006: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:950] ARM64 does not support NUMA - returning NUMA node zero
2020-02-21 18:38:42.910129: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1746] Adding visible gpu devices: 0
2020-02-21 18:38:42.910270: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2020-02-21 18:38:44.373029: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1159] Device interconnect StreamExecutor with strength 1 edge matrix:
2020-02-21 18:38:44.373306: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1165]      0
2020-02-21 18:38:44.373374: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1178] 0:   N
2020-02-21 18:38:44.374098: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:950] ARM64 does not support NUMA - returning NUMA node zero
2020-02-21 18:38:44.374509: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:950] ARM64 does not support NUMA - returning NUMA node zero
2020-02-21 18:38:44.374970: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1304] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 5782 MB memory) -> physical GPU (device: 0, name: Xavier, pci bus id: 0000:00:00.0, compute capability: 7.2)
Epoch 1/5
2020-02-21 18:38:48.056166: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
60000/60000 [==============================] - 27s 446us/sample - loss: 0.1995 - acc: 0.9418
Epoch 2/5
60000/60000 [==============================] - 25s 420us/sample - loss: 0.0812 - acc: 0.9749
Epoch 3/5
60000/60000 [==============================] - 25s 420us/sample - loss: 0.0523 - acc: 0.9840
Epoch 4/5
60000/60000 [==============================] - 25s 419us/sample - loss: 0.0361 - acc: 0.9892
Epoch 5/5
60000/60000 [==============================] - 25s 417us/sample - loss: 0.0265 - acc: 0.9920
10000/10000 [==============================] - 3s 270us/sample - loss: 0.0651 - acc: 0.9806
WARNING:tensorflow:From model.py:78: The name tf.keras.backend.get_session is deprecated. Please use tf.compat.v1.keras.backend.get_session instead.
WARNING:tensorflow:From model.py:79: convert_variables_to_constants (from tensorflow.python.framework.graph_util_impl) is deprecated and will be removed in a future version.
Use `tf.compat.v1.graph_util.convert_variables_to_constants`
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/graph_util_impl.py:277: extract_sub_graph (from tensorflow.python.framework.graph_util_impl) is deprecated and will be removed in a future version.
Use `tf.compat.v1.graph_util.extract_sub_graph`
WARNING:tensorflow:From model.py:80: remove_training_nodes (from tensorflow.python.framework.graph_util_impl) is deprecated and will be removed in a future version.
Use `tf.compat.v1.graph_util.remove_training_nodes`
then I converted to the uff file using the command in folder /usr/src/tensorrt/samples/python/end_to_end_tensorflow_mnist/models
sudo python3 /usr/lib/python3.6/dist-packages/uff/bin/convert_to_uff.py lenet5.pb lnet5.uff
2020-02-20 14:26:49.647247: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
Loading lenet5.pb
WARNING:tensorflow:From /usr/lib/python3.6/dist-packages/uff/bin/../../uff/converters/tensorflow/conversion_helpers.py:227: The name tf.gfile.GFile is deprecated. Please use tf.io.gfile.GFile instead.
NOTE: UFF has been tested with TensorFlow 1.14.0.
WARNING: The version of TensorFlow installed on this system is not guaranteed to work with UFF.
UFF Version 0.6.5
=== Automatically deduced input nodes ===
[name: "input_1"
op: "Placeholder"
attr {
  key: "dtype"
  value {
    type: DT_FLOAT
attr {
  key: "shape"
  value {
    shape {
      dim {
      dim {
      dim {
      dim {
=== Automatically deduced output nodes ===
[name: "dense_1/Softmax"
op: "Softmax"
input: "dense_1/BiasAdd"
attr {
  key: "T"
  value {
    type: DT_FLOAT
Using output node dense_1/Softmax
Converting to UFF graph
DEBUG: convert reshape to flatten node
DEBUG [/usr/lib/python3.6/dist-packages/uff/bin/../../uff/converters/tensorflow/converter.py:96] Marking ['dense_1/Softmax'] as outputs
No. nodes: 13
UFF Output written to lenet5.uff
after then I tested the command in folder /usr/src/tensorrt/bin
./trtexec --uff=/usr/src/tensorrt/samples/python/end_to_end_tensorflow_mnist/models/lenet5.uff --batch=1 --output=dense_1/Softmax --uffInput=input_1,1,28,28 --saveEngine=lenet5.engine --verbose
&&&& RUNNING TensorRT.trtexec # ./trtexec --uff=/usr/src/tensorrt/samples/python/end_to_end_tensorflow_mnist/models/lenet5.uff --batch=1 --output=dense_1/Softmax --uffInput=input_1,1,28,28 --saveEngine=lenet5.engine --verbose
[01/21/2020-18:52:06] [I] === Model Options ===
[01/21/2020-18:52:06] [I] Format: UFF
[01/21/2020-18:52:06] [I] Model: /usr/src/tensorrt/samples/python/end_to_end_tensorflow_mnist/models/lenet5.uff
[01/21/2020-18:52:06] [I] Uff Inputs Layout: NCHW
[01/21/2020-18:52:06] [I] Input: input_1,1,28,28
[01/21/2020-18:52:06] [I] Output: dense_1/Softmax
[01/21/2020-18:52:06] [I] === Build Options ===
[01/21/2020-18:52:06] [I] Max batch: 1
[01/21/2020-18:52:06] [I] Workspace: 16 MB
[01/21/2020-18:52:06] [I] minTiming: 1
[01/21/2020-18:52:06] [I] avgTiming: 8
[01/21/2020-18:52:06] [I] Precision: FP32
[01/21/2020-18:52:06] [I] Calibration:
[01/21/2020-18:52:06] [I] Safe mode: Disabled
[01/21/2020-18:52:06] [I] Save engine: lenet5.engine
[01/21/2020-18:52:06] [I] Load engine:
[01/21/2020-18:52:06] [I] Inputs format: fp32:CHW
[01/21/2020-18:52:06] [I] Outputs format: fp32:CHW
[01/21/2020-18:52:06] [I] Input build shapes: model
[01/21/2020-18:52:06] [I] === System Options ===
[01/21/2020-18:52:06] [I] Device: 0
[01/21/2020-18:52:06] [I] DLACore:
[01/21/2020-18:52:06] [I] Plugins:
[01/21/2020-18:52:06] [I] === Inference Options ===
[01/21/2020-18:52:06] [I] Batch: 1
[01/21/2020-18:52:06] [I] Iterations: 10 (200 ms warm up)
[01/21/2020-18:52:06] [I] Duration: 10s
[01/21/2020-18:52:06] [I] Sleep time: 0ms
[01/21/2020-18:52:06] [I] Streams: 1
[01/21/2020-18:52:06] [I] Spin-wait: Disabled
[01/21/2020-18:52:06] [I] Multithreading: Enabled
[01/21/2020-18:52:06] [I] CUDA Graph: Disabled
[01/21/2020-18:52:06] [I] Skip inference: Disabled
[01/21/2020-18:52:06] [I] Input inference shapes: model
[01/21/2020-18:52:06] [I] === Reporting Options ===
[01/21/2020-18:52:06] [I] Verbose: Enabled
[01/21/2020-18:52:06] [I] Averages: 10 inferences
[01/21/2020-18:52:06] [I] Percentile: 99
[01/21/2020-18:52:06] [I] Dump output: Disabled
[01/21/2020-18:52:06] [I] Profile: Disabled
[01/21/2020-18:52:06] [I] Export timing to JSON file:
[01/21/2020-18:52:06] [I] Export profile to JSON file:
[01/21/2020-18:52:06] [V] [TRT] Plugin Creator registration succeeded - GridAnchor_TRT
[01/21/2020-18:52:06] [V] [TRT] Plugin Creator registration succeeded - GridAnchorRect_TRT
[01/21/2020-18:52:06] [V] [TRT] Plugin Creator registration succeeded - NMS_TRT
[01/21/2020-18:52:06] [V] [TRT] Plugin Creator registration succeeded - Reorg_TRT
[01/21/2020-18:52:06] [V] [TRT] Plugin Creator registration succeeded - Region_TRT
[01/21/2020-18:52:06] [V] [TRT] Plugin Creator registration succeeded - Clip_TRT
[01/21/2020-18:52:06] [V] [TRT] Plugin Creator registration succeeded - LReLU_TRT
[01/21/2020-18:52:06] [V] [TRT] Plugin Creator registration succeeded - PriorBox_TRT
[01/21/2020-18:52:06] [V] [TRT] Plugin Creator registration succeeded - Normalize_TRT
[01/21/2020-18:52:06] [V] [TRT] Plugin Creator registration succeeded - RPROI_TRT
[01/21/2020-18:52:06] [V] [TRT] Plugin Creator registration succeeded - BatchedNMS_TRT
[01/21/2020-18:52:06] [V] [TRT] Plugin Creator registration succeeded - FlattenConcat_TRT
[01/21/2020-18:52:07] [V] [TRT] UFFParser: Parsing input_1[Op: Input].
[01/21/2020-18:52:07] [V] [TRT] UFFParser: input_1 -> [1,28,28]
[01/21/2020-18:52:07] [V] [TRT] UFFParser: Applying order forwarding to: input_1
[01/21/2020-18:52:07] [V] [TRT] UFFParser: Parsing flatten/Reshape[Op: Flatten]. Inputs: input_1
[01/21/2020-18:52:07] [V] [TRT] UFFParser: Applying order forwarding to: flatten/Reshape
[01/21/2020-18:52:07] [V] [TRT] UFFParser: Parsing dense/kernel[Op: Const].
[01/21/2020-18:52:07] [V] [TRT] UFFParser: dense/kernel -> [784,512]
[01/21/2020-18:52:07] [V] [TRT] UFFParser: Applying order forwarding to: dense/kernel
[01/21/2020-18:52:07] [V] [TRT] UFFParser: Parsing dense/MatMul[Op: FullyConnected]. Inputs: flatten/Reshape, dense/kernel
[01/21/2020-18:52:07] [V] [TRT] UFFParser: dense/MatMul -> [512,1,1]
[01/21/2020-18:52:07] [V] [TRT] UFFParser: Applying order forwarding to: dense/MatMul
[01/21/2020-18:52:07] [V] [TRT] UFFParser: Parsing dense/bias[Op: Const].
[01/21/2020-18:52:07] [V] [TRT] UFFParser: dense/bias -> [512]
[01/21/2020-18:52:07] [V] [TRT] UFFParser: Applying order forwarding to: dense/bias
[01/21/2020-18:52:07] [V] [TRT] UFFParser: Parsing dense/BiasAdd[Op: Binary]. Inputs: dense/MatMul, dense/bias
[01/21/2020-18:52:07] [V] [TRT] UFFParser: dense/BiasAdd -> [512,1,1]
[01/21/2020-18:52:07] [V] [TRT] UFFParser: Applying order forwarding to: dense/BiasAdd
[01/21/2020-18:52:07] [V] [TRT] UFFParser: Parsing dense/Relu[Op: Activation]. Inputs: dense/BiasAdd
[01/21/2020-18:52:07] [V] [TRT] UFFParser: dense/Relu -> [512,1,1]
[01/21/2020-18:52:07] [V] [TRT] UFFParser: Applying order forwarding to: dense/Relu
[01/21/2020-18:52:07] [V] [TRT] UFFParser: Parsing dense_1/kernel[Op: Const].
[01/21/2020-18:52:07] [V] [TRT] UFFParser: dense_1/kernel -> [512,10]
[01/21/2020-18:52:07] [V] [TRT] UFFParser: Applying order forwarding to: dense_1/kernel
[01/21/2020-18:52:07] [V] [TRT] UFFParser: Parsing dense_1/MatMul[Op: FullyConnected]. Inputs: dense/Relu, dense_1/kernel
[01/21/2020-18:52:07] [V] [TRT] UFFParser: dense_1/MatMul -> [10,1,1]
[01/21/2020-18:52:07] [V] [TRT] UFFParser: Applying order forwarding to: dense_1/MatMul
[01/21/2020-18:52:07] [V] [TRT] UFFParser: Parsing dense_1/bias[Op: Const].
[01/21/2020-18:52:07] [V] [TRT] UFFParser: dense_1/bias -> [10]
[01/21/2020-18:52:07] [V] [TRT] UFFParser: Applying order forwarding to: dense_1/bias
[01/21/2020-18:52:07] [V] [TRT] UFFParser: Parsing dense_1/BiasAdd[Op: Binary]. Inputs: dense_1/MatMul, dense_1/bias
[01/21/2020-18:52:07] [V] [TRT] UFFParser: dense_1/BiasAdd -> [10,1,1]
[01/21/2020-18:52:07] [V] [TRT] UFFParser: Applying order forwarding to: dense_1/BiasAdd
[01/21/2020-18:52:07] [V] [TRT] UFFParser: Parsing dense_1/Softmax[Op: Softmax]. Inputs: dense_1/BiasAdd
[01/21/2020-18:52:07] [V] [TRT] UFFParser: dense_1/Softmax -> [10,1,1]
[01/21/2020-18:52:07] [V] [TRT] UFFParser: Applying order forwarding to: dense_1/Softmax
[01/21/2020-18:52:07] [V] [TRT] UFFParser: Parsing MarkOutput_0[Op: MarkOutput]. Inputs: dense_1/Softmax
[01/21/2020-18:52:07] [V] [TRT] UFFParser: Applying order forwarding to: MarkOutput_0
[01/21/2020-18:52:07] [V] [TRT] Applying generic optimizations to the graph for inference.
[01/21/2020-18:52:07] [V] [TRT] Original: 11 layers
[01/21/2020-18:52:07] [V] [TRT] After dead-layer removal: 7 layers
[01/21/2020-18:52:07] [V] [TRT] After scale fusion: 7 layers
[01/21/2020-18:52:07] [V] [TRT] Fusing dense/MatMul with dense/BiasAdd
[01/21/2020-18:52:07] [V] [TRT] Fusing dense/MatMul + dense/BiasAdd with dense/Relu
[01/21/2020-18:52:07] [V] [TRT] Fusing dense_1/MatMul with dense_1/BiasAdd
[01/21/2020-18:52:07] [V] [TRT] After vertical fusions: 4 layers
[01/21/2020-18:52:07] [V] [TRT] After final dead-layer removal: 4 layers
[01/21/2020-18:52:07] [V] [TRT] After tensor merging: 4 layers
[01/21/2020-18:52:07] [V] [TRT] After concat removal: 4 layers
[01/21/2020-18:52:07] [V] [TRT] Graph construction and optimization completed in 0.00325652 seconds.
[01/21/2020-18:52:07] [I] [TRT]
[01/21/2020-18:52:07] [I] [TRT] --------------- Layers running on DLA:
[01/21/2020-18:52:07] [I] [TRT] --------------- Layers running on GPU:
[01/21/2020-18:52:07] [I] [TRT] dense/MatMul + dense/BiasAdd + dense/Relu, dense_1/MatMul + dense_1/BiasAdd, dense_1/Softmax_HL_1804289383, dense_1/Softmax,
[01/21/2020-18:52:12] [V] [TRT] Constructing optimization profile number 0 out of 1
*************** Autotuning format combination: Float(1,28,784,784) -> Float(1,1,1,512) ***************
[01/21/2020-18:52:12] [V] [TRT] --------------- Timing Runner: dense/MatMul + dense/BiasAdd + dense/Relu (CaskFullyConnected)
[01/21/2020-18:52:12] [V] [TRT] dense/MatMul + dense/BiasAdd + dense/Relu (caskFullyConnectedFP32) Set Tactic Name: volta_sgemm_128x32_relu_nn_v1
[01/21/2020-18:52:12] [V] [TRT] Tactic: 8190451076631534509 time 0.278528
[01/21/2020-18:52:12] [V] [TRT] dense/MatMul + dense/BiasAdd + dense/Relu (caskFullyConnectedFP32) Set Tactic Name: volta_sgemm_32x128_relu_nn_v1
[01/21/2020-18:52:12] [V] [TRT] Tactic: 5918215112415401770 time 0.37072
[01/21/2020-18:52:12] [V] [TRT] dense/MatMul + dense/BiasAdd + dense/Relu (caskFullyConnectedFP32) Set Tactic Name: volta_sgemm_64x64_relu_nn_v1
[01/21/2020-18:52:12] [V] [TRT] Tactic: 3514307671120560729 time 0.391168
[01/21/2020-18:52:12] [V] [TRT] dense/MatMul + dense/BiasAdd + dense/Relu (caskFullyConnectedFP32) Set Tactic Name: volta_sgemm_128x128_relu_nn_v1
[01/21/2020-18:52:12] [V] [TRT] Tactic: 3380542644225735979 time 0.682976
[01/21/2020-18:52:12] [V] [TRT] dense/MatMul + dense/BiasAdd + dense/Relu (caskFullyConnectedFP32) Set Tactic Name: volta_sgemm_128x64_relu_nn_v1
[01/21/2020-18:52:12] [V] [TRT] Tactic: 2365066484941477695 time 0.421856
[01/21/2020-18:52:12] [V] [TRT] Fastest Tactic: 8190451076631534509 Time: 0.278528
[01/21/2020-18:52:12] [V] [TRT] --------------- Timing Runner: dense/MatMul + dense/BiasAdd + dense/Relu (CudaFullyConnected)
[01/21/2020-18:52:12] [V] [TRT] Tactic: 0 time 0.125888
[01/21/2020-18:52:12] [V] [TRT] Tactic: 1 time 0.123904
[01/21/2020-18:52:12] [V] [TRT] Fastest Tactic: 1 Time: 0.123904
[01/21/2020-18:52:12] [V] [TRT] >>>>>>>>>>>>>>> Chose Runner Type: CudaFullyConnected Tactic: 1
[01/21/2020-18:52:12] [V] [TRT] *************** Autotuning format combination: Float(1,1,1,512) -> Float(1,1,1,10) ***************
[01/21/2020-18:52:12] [V] [TRT] --------------- Timing Runner: dense_1/MatMul + dense_1/BiasAdd (CaskFullyConnected)
[01/21/2020-18:52:12] [V] [TRT] dense_1/MatMul + dense_1/BiasAdd (caskFullyConnectedFP32) Set Tactic Name: volta_sgemm_128x32_relu_nn_v1
[01/21/2020-18:52:12] [V] [TRT] Tactic: 8190451076631534509 time 0.128992
[01/21/2020-18:52:12] [V] [TRT] dense_1/MatMul + dense_1/BiasAdd (caskFullyConnectedFP32) Set Tactic Name: volta_sgemm_32x128_relu_nn_v1
[01/21/2020-18:52:12] [V] [TRT] Tactic: 5918215112415401770 time 0.133152
[01/21/2020-18:52:12] [V] [TRT] dense_1/MatMul + dense_1/BiasAdd (caskFullyConnectedFP32) Set Tactic Name: volta_sgemm_64x64_relu_nn_v1
[01/21/2020-18:52:12] [V] [TRT] Tactic: 3514307671120560729 time 0.256992
[01/21/2020-18:52:12] [V] [TRT] dense_1/MatMul + dense_1/BiasAdd (caskFullyConnectedFP32) Set Tactic Name: volta_sgemm_128x128_relu_nn_v1
[01/21/2020-18:52:12] [V] [TRT] Tactic: 3380542644225735979 time 0.466976
[01/21/2020-18:52:12] [V] [TRT] dense_1/MatMul + dense_1/BiasAdd (caskFullyConnectedFP32) Set Tactic Name: volta_sgemm_128x64_relu_nn_v1
[01/21/2020-18:52:12] [V] [TRT] Tactic: 2365066484941477695 time 0.249856
[01/21/2020-18:52:12] [V] [TRT] Fastest Tactic: 8190451076631534509 Time: 0.128992
[01/21/2020-18:52:12] [V] [TRT] --------------- Timing Runner: dense_1/MatMul + dense_1/BiasAdd (CudaFullyConnected)
[01/21/2020-18:52:12] [V] [TRT] Tactic: 0 time 0.043008
[01/21/2020-18:52:12] [V] [TRT] Tactic: 1 time 0.033728
[01/21/2020-18:52:12] [V] [TRT] Fastest Tactic: 1 Time: 0.033728
[01/21/2020-18:52:12] [V] [TRT] *************** Autotuning format combination: Float(1,1,1,10) -> Float(1,1,1,10) ***************
[01/21/2020-18:52:12] [V] [TRT] --------------- Timing Runner: dense_1/Softmax_HL_1804289383 (SoftMax)
[01/21/2020-18:52:12] [V] [TRT] Tactic: 1001 time 0.020448
[01/21/2020-18:52:12] [V] [TRT] Fastest Tactic: 1001 Time: 0.020448
[01/21/2020-18:52:12] [V] [TRT] >>>>>>>>>>>>>>> Chose Runner Type: SoftMax Tactic: 1001
[01/21/2020-18:52:12] [V] [TRT] *************** Autotuning format combination: Float(1,1,1,10) -> Float(1,10,10,10) ***************
[01/21/2020-18:52:12] [V] [TRT] --------------- Timing Runner: dense_1/Softmax (Shuffle)
[01/21/2020-18:52:12] [V] [TRT] Tactic: 0 is the only option, timing skipped
[01/21/2020-18:52:12] [V] [TRT] Fastest Tactic: 0 Time: 0
[01/21/2020-18:52:12] [V] [TRT] Formats and tactics selection completed in 0.255097 seconds.
[01/21/2020-18:52:12] [V] [TRT] After reformat layers: 4 layers
[01/21/2020-18:52:12] [V] [TRT] Block size 16777216
[01/21/2020-18:52:12] [V] [TRT] Block size 2048
[01/21/2020-18:52:12] [V] [TRT] Block size 512
[01/21/2020-18:52:12] [V] [TRT] Total Activation Memory: 16779776
[01/21/2020-18:52:12] [I] [TRT] Detected 1 inputs and 1 output network tensors.
[01/21/2020-18:52:12] [V] [TRT] Engine generation completed in 5.13601 seconds.
[01/21/2020-18:52:12] [V] [TRT] Engine Layer Information:
[01/21/2020-18:52:12] [V] [TRT] Layer: dense/MatMul + dense/BiasAdd + dense/Relu (FullyConnected), Tactic: 1, input_1[Float(1,28,28)] -> dense/Relu[Float(512,1,1)]
[01/21/2020-18:52:12] [V] [TRT] Layer: dense_1/MatMul + dense_1/BiasAdd (FullyConnected), Tactic: 1, dense/Relu[Float(512,1,1)] -> dense_1/BiasAdd[Float(10,1,1)]
[01/21/2020-18:52:12] [V] [TRT] Layer: dense_1/Softmax_HL_1804289383 (SoftMax), Tactic: 1001, dense_1/BiasAdd[Float(10,1,1)] -> dense_1/Softmax_HL_1804289383[Float(10,1,1)]
[01/21/2020-18:52:12] [V] [TRT] Layer: dense_1/Softmax (Shuffle), Tactic: 0, dense_1/Softmax_HL_1804289383[Float(10,1,1)] -> dense_1/Softmax[Float(1,1,10)]
[01/21/2020-18:52:13] [I] Average over 10 runs is 0.468269 ms (host walltime is 0.547745 ms, 99% percentile time is 0.795712).
[01/21/2020-18:52:13] [I] Average over 10 runs is 0.320851 ms (host walltime is 0.362989 ms, 99% percentile time is 0.567168).
[01/21/2020-18:52:13] [I] Average over 10 runs is 0.296128 ms (host walltime is 0.334411 ms, 99% percentile time is 0.365568).
[01/21/2020-18:52:13] [I] Average over 10 runs is 0.295936 ms (host walltime is 0.336683 ms, 99% percentile time is 0.350208).
[01/21/2020-18:52:13] [I] Average over 10 runs is 0.29145 ms (host walltime is 0.327396 ms, 99% percentile time is 0.33888).
[01/21/2020-18:52:13] [I] Average over 10 runs is 0.456618 ms (host walltime is 0.506729 ms, 99% percentile time is 1.90154).
[01/21/2020-18:52:13] [I] Average over 10 runs is 0.158112 ms (host walltime is 1.03403 ms, 99% percentile time is 0.164896).
[01/21/2020-18:52:13] [I] Average over 10 runs is 0.281194 ms (host walltime is 1.05704 ms, 99% percentile time is 1.16944).
[01/21/2020-18:52:13] [I] Average over 10 runs is 0.395085 ms (host walltime is 0.901245 ms, 99% percentile time is 1.65485).
[01/21/2020-18:52:13] [I] Average over 10 runs is 0.261875 ms (host walltime is 0.294909 ms, 99% percentile time is 0.31872).
&&&& PASSED TensorRT.trtexec # ./trtexec --uff=/usr/src/tensorrt/samples/python/end_to_end_tensorflow_mnist/models/lenet5.uff --batch=1 --output=dense_1/Softmax --uffInput=input_1,1,28,28 --saveEngine=lenet5.engine --verbose
The lenet5.engine was generate successfully
deepstream-app --version-all
deepstream-app version 4.0.2
DeepStreamSDK 4.0.2
CUDA Driver Version: 10.0
CUDA Runtime Version: 10.0
TensorRT Version: 6.0
cuDNN Version: 7.6
libNVWarp360 Version: 2.0.0d5
how can i resolve this error? Do I need an extra code to be able to run lenet5 deepstream?
+1
I’m getting the same error.
+1
I am having the same problem.
Hi lucasssss,
for lenet5, since it’s single channel/gray input, so you should set model-color-format = 2 .
And, with “model-color-format = 2”, what failure log did you see?
File: source12_1080p_dec_infer-resnet_tracker_tiled_display_fp16_tx2_teste.txt
[application]
[tiled-display]
enable=0
rows=4
columns=3
width=1280
height=720
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
type=3
num-sources=12
gpu-id=0
cudadec-memtype=0
[sink0]
enable=1
type=5
sync=1
source-id=0
gpu-id=0
qos=0
nvbuf-memory-type=0
overlay-id=1
[sink1]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
sync=0
#iframeinterval=10
bitrate=2000000
output-file=out.mp4
source-id=0
[sink2]
enable=0
type=4
#1=h264 2=h265
codec=1
sync=0
bitrate=4000000
rtsp-port=8554
udp-port=5400
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
live-source=0
batch-size=12
width=1200
height=1200
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
##enable=1
#gpu-id=0
#batch-size=12
#interval=4
#gie-unique-id=1
enable=1
gpu-id=0
interval=4
gie-unique-id=1
nvbuf-memory-type=0
[tracker]
enable=0
tracker-width=480
tracker-height=272
gpu-id=0
[tests]
file-loop=0
File: config_infer_primary_nano_teste.txt
#   ONNX: onnx-file
#   custom-lib-path,
# properties.
    [property]
    gpu-id=0
    batch-size=8
    process-mode=1
    network-mode=1
    interval=0
    gie-unique-id=1
    enable-dbscan=0
    [class-attrs-all]
    threshold=0.2
    group-threshold=1
    eps=0.2
    #minBoxes=3
    roi-top-offset=0
    roi-bottom-offset=0
    detected-min-w=0
    detected-min-h=0
    detected-max-w=0
    detected-max-h=0
Command: deepstream-app -c source12_1080p_dec_infer-resnet_tracker_tiled_display_fp16_tx2_teste.txt with model-color-format = 2
console log:
0:00:01.612466173 10595     0x13f8a670 INFO                 nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
0:00:01.848463807 10595     0x13f8a670 WARN                 nvinfer gstnvinfer.cpp:515:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:generateTRTModel(): INT8 calibration file not specified. Trying FP16 mode.
0:00:12.192338983 10595     0x13f8a670 INFO                 nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:generateTRTModel(): Storing the serialized cuda engine to file at /usr/src/tensorrt/samples/python/end_to_end_tensorflow_mnist/models/lenet5.uff_b8_fp16.engine
Runtime commands:
	h: Print this help
	q: Quit
	p: Pause
	r: Resume
0:00:13.406614393 10595     0x13968320 WARN                 nvinfer gstnvinfer.cpp:1149:convert_batch_and_push_to_input_thread:<primary_gie_classifier> error: NvBufSurfTransform failed with error -2 while converting buffer
Debug info: qtdemux.c(6073): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin1/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin1/GstQTDemux:qtdemux2:
ERROR from qtdemux4: Internal data stream error.
Debug info: qtdemux.c(6073): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin2/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin2/GstQTDemux:qtdemux4:
Debug info: qtdemux.c(6073): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin8/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin8/GstQTDemux:qtdemux9:
Quitting
Debug info: qtdemux.c(6073): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin5/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin5/GstQTDemux:qtdemux6:
Debug info: qtdemux.c(6073): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin6/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin6/GstQTDemux:qtdemux5:
ERROR from qtdemux1: Internal data stream error.
Debug info: qtdemux.c(6073): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin4/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin4/GstQTDemux:qtdemux1:
Debug info: qtdemux.c(6073): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin3/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin3/GstQTDemux:qtdemux0:
ERROR from qtdemux7: Internal data stream error.
Debug info: qtdemux.c(6073): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin7/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin7/GstQTDemux:qtdemux7:
Debug info: qtdemux.c(6073): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin10/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin10/GstQTDemux:qtdemux8:
ERROR from multiqueue9: Internal data stream error.
Debug info: gstmultiqueue.c(2357): gst_multi_queue_sink_event (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin10/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin10/GstMultiQueue:multiqueue9:
ERROR from qtdemux10: Internal data stream error.
Debug info: qtdemux.c(6073): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin9/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin9/GstQTDemux:qtdemux10:
App run failed
My error: ERROR from primary_gie_classifier: NvBufSurfTransform failed with error -2 while converting buffer
Hi all,
Thanks for reporting this issue!
It’s a bug of DeepStream, currently, streammux output width and height can’t be 16 times of larger than the width & height of network resolution . We will fix it ASAP.
So, as a workaround for now, you could change the width and height from 1200 to 448 (=28 x 16) in the streammux node.
[streammux]
gpu-id=0
live-source=0
batch-size=12
width=1200
height=1200
Hi, mchi.
The error has changed.
My file: source12_1080p_dec_infer-resnet_tracker_tiled_display_fp16_tx2_teste.txt
[application]
[tiled-display]
enable=0
rows=4
columns=3
width=1280
height=720
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
type=3
num-sources=12
gpu-id=0
cudadec-memtype=0
[sink0]
enable=1
type=5
sync=1
source-id=0
gpu-id=0
qos=0
nvbuf-memory-type=0
overlay-id=1
[sink1]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
sync=0
#iframeinterval=10
bitrate=2000000
output-file=out.mp4
source-id=0
[sink2]
enable=0
type=4
#1=h264 2=h265
codec=1
sync=0
bitrate=4000000
rtsp-port=8554
udp-port=5400
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
live-source=0
batch-size=12
#width=1200
#height=1200
width=448
height=448
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
##enable=1
#gpu-id=0
#batch-size=12
#interval=4
#gie-unique-id=1
enable=1
gpu-id=0
interval=4
gie-unique-id=1
nvbuf-memory-type=0
[tracker]
enable=0
tracker-width=480
tracker-height=272
gpu-id=0
[tests]
file-loop=0
My file: config_infer_primary_nano_teste.txt
#   ONNX: onnx-file
#   custom-lib-path,
# properties.
    [property]
    gpu-id=0
    batch-size=8
    process-mode=1
    network-mode=0
    interval=0
    gie-unique-id=1
    #output-blob-names=dense_1/Softmax
    #enable-dbscan=0
    [class-attrs-all]
    threshold=0.2
    group-threshold=1
    eps=0.2
    #minBoxes=3
    roi-top-offset=0
    roi-bottom-offset=0
    detected-min-w=0
    detected-min-h=0
    detected-max-w=0
    detected-max-h=0
My command: deepstream-app -c source12_1080p_dec_infer-resnet_tracker_tiled_display_fp16_tx2_teste.txt
terminal log:
0:00:01.524100440 19755      0xdeb3a70 INFO                 nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:initialize(): Trying to create engine from model files
0:00:07.356594947 19755      0xdeb3a70 INFO                 nvinfer gstnvinfer.cpp:519:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:generateTRTModel(): Storing the serialized cuda engine to file at /usr/src/tensorrt/samples/python/end_to_end_tensorflow_mnist/models/lenet5.uff_b8_fp32.engine
Runtime commands:
	h: Print this help
	q: Quit
	p: Pause
	r: Resume
0:00:08.213980348 19755      0xd88ef70 ERROR                nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:parseBoundingBox(): Could not find output coverage layer for parsing objects
0:00:08.214094627 19755      0xd88ef70 ERROR                nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:fillDetectionOutput(): Failed to parse bboxes
0:00:08.214153575 19755      0xd88ef70 ERROR                nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:parseBoundingBox(): Could not find output coverage layer for parsing objects
0:00:08.214194025 19755      0xd88ef70 ERROR                nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:fillDetectionOutput(): Failed to parse bboxes
My errors: parseBoundingBox(): Could not find output coverage layer for parsing objects, fillDetectionOutput(): Failed to parse bboxes, nvinfer gstnvinfer.cpp:511:gst_nvinfer_logger:<primary_gie_classifier> NvDsInferContext[UID 1]:fillDetectionOutput(): Failed to parse bboxes
