I created an SD card using the Etcher tool and image: jetson-nx-jp461-sd-card-image. When i start the Xavier it goes into a reset loop where it never boots from SD card. I keep getting the Nvidia logo on white background and then it restarts again.
I connected micro usb cable to capture the console output. console_output (32.4 KB)
I checked that thread already, I added my certificates did the update already. Because of that the apt update works normally for me. But sdk manager wont work properly.
Are you sure your apt-get update is fine? Below error shows the proxy server error.
Is this your office network environment?
0% [Working]
0% [Connecting to proxy-zsgov.global.lmco.com] [Connecting to proxy-zsgov.globa
Err:1 http://us.archive.ubuntu.com/ubuntu bionic InRelease
19:08:38.971 - info: Event: undefined - error is:
0% [Working]
19:08:38.971 - warn: Failed to get component from group data map for undefined
19:08:38.972 - info: Could not resolve 'proxy-zsgov.global.lmco.com'
19:08:38.972 - error:
Err:2 http://security.ubuntu.com/ubuntu bionic-security InRelease
19:08:38.972 - info: Event: undefined - error is:
19:08:38.972 - warn: Failed to get component from group data map for undefined
19:08:38.973 - info: Could not resolve 'proxy-zsgov.global.lmco.com'
19:08:39.020 - error:
0% [Working]
Err:3 http://us.archive.ubuntu.com/ubuntu bionic-updates InRelease
19:08:39.020 - info: Event: undefined - error is:
0% [Working]
19:08:39.020 - warn: Failed to get component from group data map for undefined
19:08:39.020 - info: Could not resolve 'proxy-zsgov.global.lmco.com'
19:08:39.021 - error:
0% [Working]
Err:4 http://us.archive.ubuntu.com/ubuntu bionic-backports InRelease
19:08:39.021 - info: Event: undefined - error is:
0% [Working]
19:08:39.021 - warn: Failed to get component from group data map for undefined
19:08:39.021 - info: Could not resolve 'proxy-zsgov.global.lmco.com'
19:08:40.349 - info:
0% [Working]
Yes, Apt update & apt upgrade worked fine. I defined the proxy information in the apt folder. And since i installed my company CA certificates i dont get any errors. When i did not have the company CA Cert i did get errors relating to certificates. I checked under /etc/ssl/certs folder and i see the CA Certificate.
