Jetson Xavier J9 Fan Issue
I’m currently working with an Xavier AGX dev kit. When I pulled the heat sink off to install the SSD, the J9 Fan connector broke (wires pulled from pins). Although I know the pin out and part numbers, I’m having trouble finding the connector and pins on any reliable website and it doesn’t appear I can purchase directly through ACES. I called the NVIDA 1-800 to see if I could purchase pins and the connector directly through NVIDA or if I could send the unit back for repair but I was told I needed to make a formal forum post for any hardware related issues (which is why I’m posting here- sorry I know people have posted about this previously). Any further guidance on this would be appreciated.
Housing: ACES 5080-4H0-001
Pins: ACES 88232-T
Pin Out:
Pin 1: GND
Pin 2: 5V
Pin 3: Fan_Tach
Pin 4: Fan_PWM
Hi, do you mean the connector is broken? Can you please share a photo of that?
