Hi everyone!
(Note: the xavier is in the highest performance mode (nvpmodel -m 0 , jetson_clocks)*)
when i tried to query the memory clock rate and the memory bandwidth of the jetson xavier using the following commands:
cudaGetDeviceProperties(&deviceProp, dev);
printf(“Using Device %d: %s\n”, dev, deviceProp.name);
printf(“Memory Clock Rate (KHz): %d\n”, deviceProp.memoryClockRate);
printf(“Memory Bus Width (bits): %d\n”,deviceProp.memoryBusWidth);
printf(“Peak Memory Bandwidth (GB/s): %f\n\n”,2.0deviceProp.memoryClockRate(deviceProp.memoryBusWidth/8)/1.0e6);
it gave me the following output:
Using Device 0: Xavier
Memory Clock Rate (KHz): 1377000
Memory Bus Width (bits): 256
Peak Memory Bandwidth (GB/s): 88.128000
From the xavier specs , when we are in the highest performace mode(MAXN) i expected the clock rate to be 2.133Mhz, why does it give me only 1.377Mhz??
