Jetson Xavier NX appears to launch two desktop environments
My Jetson Xavier NX seems to be booting up two desktop environments, which is causing my Jetson Xavier NX to become very clunky. The problem is resolved after logging out, but this operation is required for each startup. Previously I used NoMachine to connect to Jetson Xavier NX and found that the NoMachine and physical display display was inconsistent, but it became consistent after logging out. I then moved one of the desktop environments, gnome, out of the whitelist by modifying the NoMachine configuration file, and the display became consistent after each startup, but the desktop environment was still very stagnant.
It seems that this problem occurred when I used the Headless Display Emulator
Sorry for the late response, is this still an issue to support? Thanks
we don’t guarantee the behavior from NoMachine.
