I hope this message finds you well.
I am writing to seek assistance regarding an issue I am experiencing with my NVIDIA Jetson Xavier NX board. When operating the board in MAX-N mode with all CPUs activated, the board frequently shuts down or reboots automatically while running an object detection AI model.
Observations and Details:
Power Supply**: 5V, 4A
Temperature: Maximum observed temperature is 40-42°C
Cooling Measures**: The board is equipped with a heat sink and a fan
Issue Description:
- Upon starting the AI model, the board performs as expected for a few iterations.
- After a short period, the board hangs for a few seconds and subsequently reboots or sometimes shuts down directly.
- Set the power mode to MAX-N (15W) and maximize the clock speeds using the following commands:
sudo nvpmodel -m 0
sudo jetson_clocks
2. Activate all CPUs using the following command:
sudo bash -c "echo 1 > /sys/devices/system/cpu/cpu1/online"
activate all the 6 CPU's
3. Run the object detection AI model and monitor the system's behavior.
System Configuration:
Device**: NVIDIA Jetson Xavier NX
Operating System : Ubuntu 20.06
Cooling Solution: Heat sink and fan installed
Despite the cooling measures and a stable power supply, the issue persists. I would appreciate your guidance on how to mitigate this issue and any recommendations for maintaining stable performance under high load conditions.
Thank you for your support.
