Jetson Xavier NX CUDA issues
One of our customers is using Jetson Xavier NX (Custom BSP based on L4T 32.4.3 for emmc module) on our custom carrier board.
They are trying to get CUDA installed and make it work, but they have below issue, Please help:
I’m trying to install cuda/cudnn using sdkmanager, which usually works. However, I can’t ping the device when it is put into recovery mode. Usually, the jetson is assigned IP 192.168.55.1, but when I ping that address while connected, it don’t get a response back.
I do see the device is in recovery mode, based off doing lsusb and seeing the Nvidia Corp. device appear.
hello vbhm,
may I know what’s your use-caes? you cannot use ssh to access the board while it’s in the forced-recovery mode.
