Hello. I’m developing our custom board with jetson xavier nx.
We have two types of products. Each one is identical in all aspects except for the camera. It would be great if the device could be recognized properly regardless of which camera is connected and booted.
What I discovered is that the device module is well registered in the kernel, so if we modify the device tree, each camera will function properly. Let me show you the device tree for each camera, which works well.
Camera 1.
* Copyright (c) 2015-2018, NVIDIA CORPORATION. All rights reserved.
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful, but WITHOUT
* ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
* FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
* more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
#include <dt-bindings/media/camera.h>
#include <dt-bindings/gpio/tegra186-gpio.h>
#define CAM0_PWDN TEGRA194_MAIN_GPIO(P, 4)
#define CAM0_RESET TEGRA194_MAIN_GPIO(P, 5)
//#define CAM1_PWDN TEGRA194_MAIN_GPIO(P, 5)
//#define CAM_I2C_MUX TEGRA194_AON_GPIO(CC, 3)
/* Enable Six overlays in Jetson Xavier NX */
&head0 {
win-mask = <0x3f>;
/* camera control gpio definitions */
/* F-03 usb power enable */
gpio@2200000 {
extusb-enable {
gpio-hog;
gpios = <TEGRA_MAIN_GPIO(P, 5) 0>;
output-high;
line-name = "extusb-enable";
camera-control-output-low {
gpio-hog;
output-low;
gpios = <CAM0_PWDN 0>;
label = "cam0-pwdn";
host1x {
vi@15c10000 {
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
vi_port0: port@0 {
reg = <0>;
ecam_imx415_vi_in0: endpoint {
port-index = <4>;
bus-width = <2>;
remote-endpoint = <&ecam_imx415_csi_out0>;
// vi_port1: port@1 {
// reg = <1>;
// ecam_ar0521_vi_in1: endpoint {
// port-index = <2>;
// bus-width = <2>;
// remote-endpoint = <&ecam_ar0521_csi_out1>;
nvcsi@15a00000 {
num-channels = <1>;
#size-cells = <0>;
csi_chan0: channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
csi_chan0_port0: port@0 {
reg = <0>;
ecam_imx415_csi_in0: endpoint@0 {
port-index = <4>;
bus-width = <2>;
remote-endpoint = <&ecam_imx415_out0>;
csi_chan0_port1: port@1 {
reg = <1>;
ecam_imx415_csi_out0: endpoint@1 {
remote-endpoint = <&ecam_imx415_vi_in0>;
// csi_chan1: channel@1 {
// reg = <1>;
// ports {
// #address-cells = <1>;
// #size-cells = <0>;
// csi_chan1_port0: port@0 {
// reg = <0>;
// ecam_ar0521_csi_in1: endpoint@2 {
// bus-width = <2>;
// remote-endpoint = <&ecam_ar0521_out1>;
// csi_chan1_port1: port@1 {
// reg = <1>;
// ecam_ar0521_csi_out1: endpoint@3 {
// remote-endpoint = <&ecam_ar0521_vi_in1>;
i2c@3180000 {
status = "okay";
tca6424_22_a: tca6424@22 {
compatible = "ti,tca6424";
gpio-controller;
#gpio-cells = <2>;
reg = <0x22>;
vcc-supply = <&p3509_vdd_sys_en>;
status = "okay";
tca6424_22_outlow {
* GPIO-0 : RST_CAM1
* GPIO-1 : RST_CAM2
* GPIO-2 : RST_CAM3
* .... more is there
gpio-hog;
gpios = <0 0 1 0 2 0 3 0 4 0 5 0 6 0 7 0>;
output-low;
label = "tca6424_22_outlow_0",
"tca6424_22_outlow_1",
"tca6424_22_outlow_2",
"tca6424_22_outlow_3",
"tca6424_22_outlow_4",
"tca6424_22_outlow_5",
"tca6424_22_outlow_6",
"tca6424_22_outlow_7";
tca6424_22_outhigh {
status = "disabled";
tca6424_22_input {
imx415_a@42 {
reset-gpios = <&tca6424_22_a 1 GPIO_ACTIVE_HIGH>;
boot-gpios = <&tca6424_22_a 2 GPIO_ACTIVE_HIGH>;
compatible = "nvidia,eimx415";
/* I2C device address */
reg = <0x42>;
/* V4L2 device node location */
devnode = "video0";
status = "okay";
/* Physical dimensions of sensor */
physical_w = "5.60";
physical_h = "3.175";
sensor_model = "eimx415";
use_decibel_gain = "true";
use_sensor_mode_id = "true";
use_dol_wdr_mode = "false";
use_master_slave_mode = "false";
limit_analog_gain = "true";
camera_mipi_lanes = /bits/ 8 <2>;
mipi-clk-configurable;
camera_mipi_clk = /bits/ 16 <2000>;
mode0 {
mclk_khz = "37125";
num_lanes = "2";
tegra_sinterface = "serial_e";
phy_mode = "DPHY";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
dynamic_pixel_bit_depth = "12";
csi_pixel_bit_depth = "12";
mode_type = "bayer";
pixel_phase = "gbrg";
active_w = "3840";
active_h = "2160";
readout_orientation = "0";
line_length = "887";
inherent_gain = "1";
mclk_multiplier = "1";
pix_clk_hz = "693000000";
gain_factor = "10";
min_gain_val = "0";
max_gain_val = "300";
step_gain_val = "3";
default_gain = "0";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
framerate_factor = "1000000";
min_framerate = "2500000";
max_framerate = "37000000";
step_framerate = "1";
default_framerate = "37000000";
exposure_factor = "1000000";
min_exp_time = "450";
max_exp_time = "400000";
step_exp_time = "1";
default_exp_time = "27027";
embedded_metadata_height = "1";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
ecam_imx415_out0: endpoint {
status = "okay";
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&ecam_imx415_csi_in0>;
};//imx415_a
};//i2c@3180000
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
* Physical settings to calculate max ISO BW
* num_csi_lanes = <>;
* Total number of CSI lanes when all cameras are active
* max_lane_speed = <>;
* Max lane speed in Kbit/s
* min_bits_per_pixel = <>;
* Min bits per pixel
* vi_peak_byte_per_pixel = <>;
* Max byte per pixel for the VI ISO case
* vi_bw_margin_pct = <>;
* Vi bandwidth margin in percentage
* max_pixel_rate = <>;
* Max pixel rate in Kpixel/s for the ISP ISO case
* isp_peak_byte_per_pixel = <>;
* Max byte per pixel for the ISP ISO case
* isp_bw_margin_pct = <>;
* Isp bandwidth margin in percentage
num_csi_lanes = <4>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <16>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <240000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
* The general guideline for naming badge_info contains 3 parts, and is as follows,
* The first part is the camera_board_id for the module; if the module is in a FFD
* platform, then use the platform name for this part.
* The second part contains the position of the module, ex. “rear” or “front”.
* The third part contains the last 6 characters of a part number which is found
* in the module's specsheet from the vender.
modules {
module0 {
badge = "imx415_front_0415";
position = "front";
orientation = "1";
drivernode0 {
/*status = "okay";*/
pcl_id = "v4l2_sensor";
devname = "e-con_cam 2-0042";
proc-device-tree = "/proc/device-tree/i2c@3180000/imx415_a@42";
/*drivernode1 {
pcl_id = "v4l2_lens";
Camera 2.
* more details.
&head0 {
win-mask = <0x3f>;
gpio@2200000 {
extusb-enable {
gpio-hog;
output-high;
host1x {
vi@15c10000 {
num-channels = <1>;
ports {
#size-cells = <0>;
vi_port0: port@0 {
reg = <0>;
e3322_vi_in0: endpoint {
port-index = <4>;
bus-width = <2>;
remote-endpoint = <&e3322_csi_out0>;
// reg = <1>;
// bus-width = <2>;
nvcsi@15a00000 {
num-channels = <1>;
#size-cells = <0>;
reg = <0>;
ports {
#size-cells = <0>;
reg = <0>;
e3322_csi_in0: endpoint@0 {
port-index = <4>;
bus-width = <2>;
remote-endpoint = <&e3322_veye327_out0>;
reg = <1>;
e3322_csi_out0: endpoint@1 {
remote-endpoint = <&e3322_vi_in0>;
// reg = <1>;
// ports {
// reg = <0>;
// bus-width = <2>;
// reg = <1>;
i2c@3180000 {
status = "okay";
veye327_a@3b {
devnode = "video0";
compatible = "nvidia,veye327";
reg = <0x3b>;
physical_w = "5.6";
physical_h = "3.1";
sensor_model = "veye327";
use_sensor_mode_id = "false";
//dovdd-supply = <&en_vdd_cam>;
avdd-reg = "vana";
dvdd-reg = "vdig";
iovdd-reg = "dovdd";
mode0 { /* CS307_MODE_1920X1080_30FPS */
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "1920";
active_h = "1080";
pixel_t = "yuv_uyvy16";
line_length = "2200";
mclk_multiplier = "2";
pix_clk_hz = "74250000";
gain_factor = "16";
min_gain_val = "16"; /* 1.00x */
max_gain_val = "170"; /* 10.66x */
step_gain_val = "1";
default_gain = "16"; /* 1.00x */
min_framerate = "2000000"; /* 2.0 fps */
max_framerate = "30000000"; /* 30 fps */
default_framerate = "30000000"; /* 30 fps */
min_exp_time = "13"; /* us */
max_exp_time = "333333"; /* us */
default_exp_time = "2495"; /* us */
embedded_metadata_height = "0";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
e3322_veye327_out0: endpoint {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&e3322_csi_in0>;
};//veye327_a
};//i2c@3180000
num_csi_lanes = <12>;
min_bits_per_pixel = <8>;
modules {
module0 {
badge = "e3322_bottomleft_A815P2";
position = "bottomleft";
orientation = "1";
drivernode0 {
status = "okay";
devname = "csx307 2-003b";
proc-device-tree = "/proc/device-tree/i2c@3180000/veye327_a@3b";
/*drivernode1 {
I tried to merge above two device tree like below(one csi channel and two endpoints of port).
* more details.
&head0 {
win-mask = <0x3f>;
gpio@2200000 {
extusb-enable {
gpio-hog;
output-high;
gpio-hog;
output-low;
host1x {
vi@15c10000 {
num-channels = <1>;
ports {
#size-cells = <0>;
vi_port0: port@0 {
reg = <0>;
port-index = <4>;
bus-width = <2>;
// reg = <1>;
// bus-width = <2>;
nvcsi@15a00000 {
num-channels = <1>;
#size-cells = <0>;
reg = <0>;
ports {
#size-cells = <0>;
reg = <0>;
port-index = <4>;
bus-width = <2>;
e3322_csi_in0: endpoint@1 {
port-index = <4>;
bus-width = <2>;
reg = <1>;
ecam_imx415_csi_out0: endpoint@2 {
// reg = <1>;
// ports {
// reg = <0>;
// bus-width = <2>;
// reg = <1>;
i2c@3180000 {
status = "okay";
gpio-controller;
#gpio-cells = <2>;
reg = <0x22>;
status = "okay";
tca6424_22_outlow {
* GPIO-0 : RST_CAM1
* GPIO-1 : RST_CAM2
* GPIO-2 : RST_CAM3
gpio-hog;
output-low;
tca6424_22_input {
imx415_a@42 {
reg = <0x42>;
devnode = "video0";
status = "okay";
mode0 {
mclk_khz = "37125";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "3840";
active_h = "2160";
gain_factor = "10";
min_gain_val = "0";
default_gain = "0";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
status = "okay";
port-index = <0>;
bus-width = <2>;
};//imx415_a
veye327_a@3b {
devnode = "video0";
reg = <0x3b>;
physical_w = "5.6";
physical_h = "3.1";
avdd-reg = "vana";
dvdd-reg = "vdig";
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "1920";
active_h = "1080";
gain_factor = "16";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
status = "okay";
port-index = <0>;
bus-width = <2>;
};//veye327_a
};//i2c@3180000
modules {
module0 {
position = "front";
orientation = "1";
drivernode0 {
/*drivernode1 {
module1 {
orientation = "1";
drivernode0 {
/*drivernode1 {
When checking the kernel messages after connecting and booting each camera, they are initially recognized as I2C devices. However, when attempting to receive data, the message “uvcvideo: Failed to query (GET_DEF) UVC control 7 on unit 2: -32 (exp. 2)” is displayed.
While it may be tempting to attribute this issue to the differences in “num_csi_lanes” or “max_bits_per_pixel” in the device tree, I have confirmed that this aspect does not affect each camera operation.
To modify the device tree in order to ensure proper operation regardless of the two type of camera module connected, what steps should be taken?
