Jetson xavier NX emmc SPI stop working with NVME disk
Hi everyone. We are using Jetson Xavier NX 16GB emmc on custom carrier board. We enabled SPI via Jetson-io (the python script) but when we connect nvme disk to the carrier formatted with gpt EXT4 SPI stops to work and in jetson-io.py script does not remain setted (eg. spi1[*]). If we used a not formatted disk the problem does not arise.
I hope in your help.
Don’t know what the root cause. However I would suggest configure the SPI by jetson-io before the NVME formatted and save the /boot/kernel_tegra194-p3668-all-p3509-0000-user-custom.dtb and apply to NVME rootfs to apply to enable the SPI
LABEL JetsonIO
        MENU LABEL Custom Header Config: <HDR40 User Custom [2022-09-22-022655]>
        LINUX /boot/Image
        FDT /boot/kernel_tegra194-p3668-all-p3509-0000-user-custom.dtb
Thank you, I tried your suggestion but it didn’t work. At the moment I have no ideas. At the moment I don’t boot from disk but from emmc. Could it be due to the disk’s file system type? Thank you
Do you able boot from NVME without configure the /boot/extlinux/extlinux.conf ?
Dear ShaneCCC, I’m not booting from NVME, I’m booting from emmc on Xavier 16GB emmc (production module). Have you got suggestions?
Configure the SPI by jetson-io without NVME and reboot to applied and power down the NX to connect the NVME again.
Unfortunately nothing work with this suggestion
Sorry for the late response, is this still an issue to support? Thanks
I made a workaround but yes, at the moment is still an issue
Could you share what your workaround is as reference? Thanks
