I have new jetson Xavier-nx (not evk) and it seems to have issues while flashing. The flashing seems to get stuck with QSPI: Erasing entire device (log from the uart output). I tried via both sdk manager and ./flash (i know they both are same, just wanted to make sure).
some logs:
[0132.426] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio’ driver
[0132.583] I> tegrabl_gpio_driver_register: register ‘nvidia,tegra194-gpio-aon’ driver
[0132.586] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0132.597] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0132.603] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0132.607] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0132.613] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0132.622] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0132.630] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0132.635] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0132.644] I> fixed regulator driver initialized
[0132.662] I> CPU: Nvidia Carmel
[0132.662] I> CPU: MIDR: 0x4e0f0040, MPIDR: 0x80000000
[0132.662] I> chip revision : A02P
[0132.662] I> Boot-device: QSPI
[0132.663] I> Boot_device: QSPI_FLASH instance: 0
[0132.665] I> QSPI source rate = 204000 Khz
[0132.668] I> Requested rate for QSPI clock = 34000 Khz
[0132.673] I> BPMP-set rate for QSPI clk = 34000 Khz
[0132.678] I> QSPI Flash Size = 32 MB
[0132.686] I> Qspi initialized successfully
[0132.686] I> qspi flash-0 params source = boot args
[0133.109] I> sdmmc DDR50 mode
[0133.119] I> sdmmc-3 params source = safe params
[0133.121] I> Found 47 partitions in QSPI_FLASH (instance 0)
[0133.138] W> Cannot find any partition table for 00000003
[0133.150] I> Found 11 partitions in SDMMC_USER (instance 3)
[0133.151] I> Recovery boot_type: 0
[0133.151] I> Entering 3p server
[0133.151] I> USB configuration success
[0133.528] I> Populate storage info
[0133.611] I> Erasing device 3: 0
[0133.612] I> QSPI: Erasing entire device
" (not evk)?"
From which verndor? or custom carrier board?
The QSPI will get flashed when you use flash.sh or SDK manager.
The carrier board is a custom carrier board, but I was able to flash and use 4 out of the 5 Xavier nx using the same carrier board(s) … This is the only 1 Xavier-nx that I am having trouble with.
Which JetPack version you flashed? Can you try another one? Sich as JetPack 4.6.2?
Please take that module to devkit and see if it can get flashed by sdkm.
