I need FAN_TACH and SD card detect, I don’t know to implement two function in the pin GPIO08,Can I change one GPIO or combine the schematic
You need to change one of the GPIO to another and also modify the device tree and pinmux.
Which GPIO are you suggesting?
change which one FAN_TACH or SD card detect to GPIO
There is no limitation. You could change the cd_gpio (sdcard) to other gpios that are not in use.
Hi 295839633,
To enable sdcard slot on sdmmc3, please make sure similar properties from sdmmc1 are present.
mmc-ocr-mask = <0x0>;
cd-inverted;
cd-gpios = <&tegra_main_gpio TEGRA194_MAIN_GPIO(G, 7) 0>;
nvidia,cd-wakeup-capable;
mmc-ocr-mask = <0>;
cd-inverted;
vmmc-supply = <&p3668_vdd_sdmmc1_sw>; //you need to use the correct regulator from your carrier board
status = "okay";
Hi Wayne
Thank you. I’ve detect sd-card successfully.
hi,could you share some steps to change the io?
I think the DT patches here should be sufficient. What steps do you need?
I have enabled the SDMMC3 too,thank you
Hi suen, how do you enable the sdmmc3
Yes.
Where exactly do we need to make these changes?
Download the kernel source from website.
https://developer.nvidia.com/embedded/linux-tegra
Build the kernel from your host.
https://docs.nvidia.com/jetson/l4t/index.html
Refer to more documents from the DLC.
There is no special function pin called “SDMMC3_CD”. It is just a GPIO.
Hi @WayneWWW ,
How do i specify the enable pin for the SDMMC3 interface? I have it connected to GPIO3 in my carrier board.
