[Jetson Xavier Nx] GPU (gv11b) ideal behavior for real-time robotics-perception
I was working on system-vitals (gpu, cpu, temperature) monitoring on Jetson Xavier NX system for a real-time drone application.
What is the expected behavior of the GPU usage value (accessed from /sys/devices/17000000.gv11b/load)?
I am observing the gv11b load hitting 99% every few seconds. Most of the ‘density’ of the load lies under 70% though.
Would appreciate some more info/guidance regarding this.
Please run sudo tegrastats to check GPU status. The value is interpreted into percentage in tegrastats.
Hi DaneLLL
Using tegrastats through bash scripts real-time is causing latency issues in our system.
Even if I use tegrastats, how can I decide on a threshold?
For example is 97% or 99% a reasonable threshold (system health wise)? What does it mean if the GPU load reaches 99% in our system?
Is it a common occurence?
If it does not trigger over current or over heating, it looks fine the GPU loading is at ~100%. When other engines(such as CPU cores) are also in high loading and triggers over-current or over heating, performance may drop due to protection mechanism.
