Hi everyone,
I’m pretty new to Jetson boards. I’m trying to reflash my Jetson using the NVIDIA SDK Manager, but I can’t get the board into recovery mode properly.
Here’s what I’ve tried:
- I connected the FC REC pin (located near the camera connector) to GND in order to force recovery mode.
- Then I connected the Jetson to the host PC via USB.
- After powering on the Jetson, I removed the connection between the REC and GND pins (to avoid keeping it grounded).
- However, the SDK Manager still doesn’t detect the device, and the manual setup “Flash” button remains disabled.
If I don’t connect the FC REC pin to GND, the SDK Manager detects the Jetson, but the manual setup “Flash” button is not enabled — probably because it’s not in recovery mode.
I’ve tried many combinations, but nothing worked so far.
Any advice would be appreciated!
(I used on Virtual box Ubuntu 20.04 for installing Jetson to Ubuntu 20.04 sdk 5.1.3)
Connection:
(I’m using Ubuntu 20.04 in a VirtualBox VM as the host system to flash Jetson using SDK Manager 5.1.3.)
