I have been using jetson xavier nx devkit for quite some time. But all of sudden i feel the speed of device has become slow. Like every small action takes time either it may be opening a simple terminal or any other application. My main worry is i am running the realtime STT (speech to Text) on jetson xnx and rpi5 paralelly. When i run the simple speech to text (whisper) model, the rpi5 started to listening within 2 seconds, but jetson took 30 sec start listening after running the code. So i am doubtful if anything is mismatched here .
I am using:
Jetpack 5.1.4
python3.8
Boot : SD card (128 GB)
swap memory: 11GB
i checked the number of cpu cores running its 6.
Anyone has any idea like what could have gone wrong
I have installed the torch 2.1.0… wheel supported for our current jetpack mentioned from nvidia site and torch with cuda is also enabled( torch.cuda.is_available() is True)
