Hi ,
i am uisng jetson xavier NX som in our custom carrier board with jetpack 5.1.
I am got kernel panic two times.
1)when i try to down static ip
2) when i rebooted the system
xavier@tegra-ubuntu:~$
xavier@tegra-ubuntu:~$ [ 2160.146057] Trying to unregister non-registered hwtime
[ 2160.147666] Unable to handle kernel NULL pointer dereference at virtual addr0
[ 2160.147922] Mem abort info:
[ 2160.148001] ESR = 0x96000004
[ 2160.148091] EC = 0x25: DABT (current EL), IL = 32 bits
[ 2160.148225] SET = 0, FnV = 0
[ 2160.148325] EA = 0, S1PTW = 0
[ 2160.148399] Data abort info:
[ 2160.148470] ISV = 0, ISS = 0x00000004
[ 2160.148559] CM = 0, WnR = 0
[ 2160.148644] user pgtable: 4k pages, 48-bit VAs, pgdp=00000001234d6000
[ 2160.148787] [0000000000000040] pgd=0000000000000000, p4d=0000000000000000
[ 2160.148945] Internal error: Oops: 96000004 [#1] PREEMPT SMP
[ 2160.149077] Modules linked in: fuse(E) lzo_rle(E) lzo_compress(E) zram(E) ra)
[ 2160.149259] nvmap(E) ip_tables(E) x_tables(E) [last unloaded: mtd]
[ 2160.209371] CPU: 0 PID: 2420 Comm: kworker/u12:0 Tainted: G W OE 3
[ 2160.217811] Hardware name: Unknown NVIDIA Jetson Xavier NX Developer Kit/NVI3
[ 2160.230656] Workqueue: events_power_efficient phy_state_machine
[ 2160.236673] pstate: 60c00009 (nZCv daif +PAN +UAO -TCO BTYPE=--)
[ 2160.242714] pc : netif_carrier_off+0x1c/0x90
[ 2160.247174] lr : netif_carrier_off+0x1c/0x90
[ 2160.251633] sp : ffff800010083d00
[ 2160.255303] x29: ffff800010083d00 x28: ffffb3fb32226000
[ 2160.260816] x27: ffff8000116cbca8 x26: ffff088fa579b348
[ 2160.266330] x25: 0000000000000000 x24: 0000000000000000
[ 2160.271665] x23: ffff088f99d774f8 x22: ffff088f810b4880
[ 2160.277177] x21: 0000000000000000 x20: 0000000000000000
[ 2160.282689] x19: 0000000000000000 x18: 0000000000000013
[ 2160.287945] x17: 0000000000000007 x16: 000000000000000e
[ 2160.293715] x15: 0000000000000004 x14: 0000000000000019
[ 2160.298797] x13: 0000000000000000 x12: ffff088fa5adf0f0
[ 2160.304235] x11: ffff088fa5adefe8 x10: 0000000000000a80
[ 2160.309991] x9 : ffff088f9c5e0a7c x8 : fefefefefefefeff
[ 2160.315328] x7 : 0000000000000018 x6 : ffff088f9c5e0a6c
[ 2160.320665] x5 : 0000746e65696369 x4 : 000000000000002f
[ 2160.326090] x3 : 0000000000000000 x2 : ffffb3fb306be170
[ 2160.331426] x1 : 0000000000000000 x0 : ffffb3fb306be170
[ 2160.336765] Call trace:
[ 2160.339243] netif_carrier_off+0x1c/0x90
[ 2160.342723] phy_link_change+0x70/0x80
[ 2160.346937] phy_state_machine+0x184/0x220
[ 2160.350947] process_one_work+0x1c4/0x4a0
[ 2160.354984] worker_thread+0x54/0x430
[ 2160.358643] kthread+0x148/0x170
[ 2160.361624] ret_from_fork+0x10/0x24
[ 2160.365386] Code: aa0003f3 d50320ff aa1e03e0 97c1c7a5 (f9402260)
[ 2160.371512] ---[ end trace 49883a0266be2d20 ]---
[ 2160.388467] Kernel panic - not syncing: Oops: Fatal exception
[ 2160.388666] SMP: stopping secondary CPUs
[ 2160.388836] Kernel Offset: 0x33fb20500000 from 0xffff800010000000
[ 2160.391539] PHYS_OFFSET: 0xfffff77180000000
[ 2160.395485] CPU features: 0x8240002,03802a30
[ 2160.399770] Memory Limit: none
[ 2160.411583] ---[ end Kernel panic - not syncing: Oops: Fatal exception ]---
[0000.025] W> RATCHET: MB1 binary ratchet value 4 is larger than ratchet level 2 from HW fuses.
[0000.033] I> MB1 (prd-version: 2.6.0.0-t194-41334769-cab45716)
[0000.038] I> Boot-mode: Coldboot
[0000.041] I> Platform: Silicon
[0000.044] I> Chip revision : A02P
[0000.047] I> Bootrom patch version : 15 (correctly patched)
[0000.052] I> ATE fuse revision : 0x200
[0000.056] I> Ram repair fuse : 0x1
[0000.059] I> Ram Code : 0x2
[0000.061] I> rst_source: 0x0, rst_level: 0x0
[0000.066] I> Boot-device: QSPI (instance: 0)
[0000.070] I> Qspi flash params source = brbct
[0000.074] I> Qspi clock source : pllp
[0000.078] I> Qspi-0 initialized successfully
[0000.082] I> Boot chain mechanism: A/B
[0000.085] I> Current Boot-Chain Slot: 0
[0000.089] I> BR-BCT Boot-Chain: 0, status: 0. update flag: 0
[0000.094] I> Qspi flash params source = brbct
[0000.100] W> PROD_CONFIG: device prod data is empty in MB1 BCT.
[0000.107] I> Temperature = 30000
[0000.110] W> Skipping boost for clk: BPMP_CPU_NIC
[0000.115] W> Skipping boost for clk: BPMP_APB
[0000.119] W> Skipping boost for clk: AXI_CBB
[0000.123] W> Skipping boost for clk: AON_CPU_NIC
[0000.127] W> Skipping boost for clk: CAN1
[0000.130] W> Skipping boost for clk: CAN2
[0000.135] I> Boot-device: QSPI (instance: 0)
[0000.139] I> Qspi flash params source = mb1bct
[0000.143] I> Qspi clock source : pllc_out0
[0000.147] I> Qspi-0 reinitialized
[0000.150] I> Qspi flash params source = mb1bct
[0000.163] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.170] W> Thermal config not found in BCT
[0000.178] W> MEMIO rail config not found in BCT
[0000.190] I> Qspi flash params source = mb1bct
[0000.203] I> Qspi flash params source = mb1bct
[0000.237] I> Qspi flash params source = mb1bct
[0000.801] I> Qspi flash params source = mb1bct
[0000.818] I> Qspi flash params source = mb1bct
[0000.857] W> Platform config not found in BCT
[0000.884] I> Qspi flash params source = mb1bct
[0000.909] I> MB1 done
ᅵᅵᅵᅵmain enter
SPE VERSION #: R01.00.18 Created: Jan 29 2021 @ 14:18:27
HW Function test
Start Scheduler.
in late init
ᅵᅵ
[0000.919] I> Welcome to MB2(TBoot-BPMP) (version: default.t194-mobile-74494172)
[0000.919] I> DMA Heap @ [0x526fa000 - 0x52ffa000]
[0000.920] I> Default Heap @ [0xd486400 - 0xd48a400]
[0000.921] E> DEVICE_PROD: Invalid value data = 70020000, size = 0.
[0000.926] W> device prod register failed
[0000.930] I> gpio framework initialized
[0000.934] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0000.941] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0000.949] I> No valid sdcard_params in mb1_bct
[0000.953] I> Boot_device: QSPI_FLASH instance: 0
[0000.957] I> qspi flash-0 params source = boot args
[0000.963] I> QSPI-0l initialized successfully
[0000.966] I> sdmmc-3 params source = safe params
[0001.380] I> sdmmc DDR50 mode
[0001.398] I> Found 41 partitions in QSPI_FLASH (instance 0)
[0001.415] W> Cannot find any partition table for 00000003
[0001.416] > PARTITION_MANAGER: Failed to publish partition.
[0001.432] I> Found 22 partitions in SDMMC_USER (instance 3)
[0001.433] I> Active Boot chain : 0
[0002.115] I> Relocating BR-BCT
[0002.116] > DEVICE_PROD: device prod is not initialized.
[0002.141] E> I2C: slave not found in slaves.
[0002.142] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0002.143] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.144] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 0.
[0002.145] E> eeprom: Failed to read I2C slave device
[0002.148] I> Failed to read CVB eeprom data @ AE
[0002.153] I> Retrying CVB eeprom read @ AC ...
[0002.158] E> I2C: slave not found in slaves.
[0002.162] E> I2C: Could not write 0 bytes to slave: 0x00ac with repeat start true.
[0002.169] E> I2C_DEV: Failed to send register address 0x00000000.
[0002.175] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xac at 0x00000000 via instance 0.
[0002.184] E> eeprom: Failed to read I2C slave device
[0002.189] I> Failed to read CVB eeprom data @ AC
[0002.456] I> Relocating OP-TEE dtb from: 0x6bfff240 to 0x70050000, size: 1008
[0002.457] I> [0] START: 0x80000000, SIZE: 0x2f000000
[0002.457] I> [1] START: 0xaf010000, SIZE: 0x189f0000
[0002.458] I> [2] START: 0xc7b00000, SIZE: 0xc0000
[0002.458] I> [3] START: 0xca000000, SIZE: 0x800000
[0002.458] I> dram_block larger than 80000000
[0002.461] I> [4] START: 0x100000000, SIZE: 0x380000000
[0002.472] I> Setting NS memory ranges to OP-TEE dtb finished.
[0002.475] I> found decompressor handler: lz4
[0002.867] I> EKB detected (length: 0x410) @ VA:0x52709400
[0002.868] I> Setting EKB blob info to OPTEE dtb finished.
ᅵᅵNOTICE: BL31: v2.6(release):07eea4970
NOTICE: BL31: Built : 07:55:15, Mar 19 2023
I/TC:
ᅵᅵ
bpmp: init
bpmp: tag is 128431eec76692047e1ac1ebc0392266
sku_dt_init: not sku 0x00
ᅵᅵI/TC: Non-ᅵᅵclk_early initialized
ᅵᅵsecurᅵᅵmail_early initialized
ᅵᅵeᅵᅵfuse initialized
hwwdt initialized
ᅵᅵ exteᅵᅵt194_ec_get_ec_list: found 45 ecs
ᅵᅵrnal DT fouᅵᅵec initialized
vmon_setup_monitors: found 3 monitors
vmon initialized
ᅵᅵadc initialized
ᅵᅵ
ᅵᅵfmon_populate_monitors: found 73 monitors
ᅵᅵᅵᅵfmon initialized
mc initialized
reset initialized
nvhs initialized
uphy_early initialized
emc_early initialized
392 clocks registered
clk initialized
io_dpd initialized
thermal initialized
thermal_mrq initialized
i2c initialized
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
vrmon initialized
regulator initialized
avfs_clk_platform initialized
soctherm initialized
aotag initialized
powergate initialized
dvs initialized
pm initialized
suspend initialized
pg_late initialized
pg_mrq_init initialized
strap initialized
nvl initialized
emc initialized
emc_mrq initialized
clk_dt initialized
tj_init initialized
uphy_dt initialized
uphy_mrq initialized
uphy initialized
ec_swd_poll_start: 281 reg polling start w period 47 ms
ec_late initialized
hwwdt_late initialized
reset_mrq initialized
ec_mrq initialized
fmon_mrq initialized
clk_mrq initialized
avfs_mrq initialized
mail_mrq initialized
i2c_mrq initialized
tag_mrq initialized
console_mrq initialized
mrq initialized
clk_sync_fmon_post initialized
ᅵᅵI/TC: OP-TEE version: 3.19 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Sun Mar 19 15:ᅵᅵclk_dt_late initialized
ᅵᅵ0ᅵᅵnoc_late initialized
pm_post initialized
dbells initialized
ᅵᅵ2:42ᅵᅵdmce initialized
cvc initialized
ᅵᅵ UTC 2023 aaᅵᅵavfs_clk_mach_post initialized
ᅵᅵrch64ᅵᅵavfs_clk_platform_post initialized
ᅵᅵ
ᅵᅵcvc_late initialized
regulator_post initialized
ᅵᅵI/ᅵᅵrm initialized
console_late initialized
clk_dt_post initialized
mc_reg initialized
ᅵᅵTC: WARNING: This OP-TEE configurationᅵᅵpg_post initialized
profile initialized
fuse_late initialized
extras_post initialized
bpmp: init complete
entering main console loop
] ᅵᅵ might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Primary CPU switching to normal world boot
ᅵᅵ
[0003.497] I> Welcome to NVDisp-Init
[0003.497] I> NVDisp-Init version: t194-709c0123
[0003.497] I> CPU-BL Params @ 0xca020000
[0003.498] I> 0) Base:0x00000000 Size:0x00000000
[0003.498] I> 1) Base:0xc8100000 Size:0x00100000
[0003.498] I> 2) Base:0xc9800000 Size:0x00200000
[0003.499] I> 3) Base:0xc8600000 Size:0x00200000
[0003.501] I> 4) Base:0xc8000000 Size:0x00100000
[0003.506] I> 5) Base:0xc7f00000 Size:0x00100000
[0003.510] I> 6) Base:0xc9400000 Size:0x00400000
[0003.514] I> 7) Base:0xc9000000 Size:0x00400000
[0003.519] I> 8) Base:0xc7e00000 Size:0x00100000
[0003.523] I> 9) Base:0xc7d00000 Size:0x00100000
[0003.528] I> 10) Base:0xca800000 Size:0x00800000
[0003.532] I> 11) Base:0x40000000 Size:0x00040000
[0003.537] I> 12) Base:0xc7c00000 Size:0x00100000
[0003.541] I> 13) Base:0x40046000 Size:0x00002000
[0003.546] I> 14) Base:0x40048000 Size:0x00002000
[0003.550] I> 15) Base:0xaf000000 Size:0x00004000
[0003.555] I> 16) Base:0x4004a000 Size:0x00002000
[0003.559] I> 17) Base:0xc7a00000 Size:0x00100000
[0003.564] I> 18) Base:0x4004c000 Size:0x00002000
[0003.568] I> 19) Base:0xc9a00000 Size:0x00600000
[0003.573] I> 20) Base:0x4004e000 Size:0x00002000
[0003.577] I> 21) Base:0xc7bc0000 Size:0x0000c000
[0003.581] I> 22) Base:0x00000000 Size:0x00000000
[0003.586] I> 23) Base:0xc7be0000 Size:0x00020000
[0003.590] I> 24) Base:0xcc000000 Size:0x02000000
[0003.595] I> 25) Base:0x40050000 Size:0x00002000
[0003.599] I> 26) Base:0x40040000 Size:0x00006000
[0003.604] I> 27) Base:0xc8c00000 Size:0x00400000
[0003.608] I> 28) Base:0xc8400000 Size:0x00200000
[0003.613] I> 29) Base:0xc8800000 Size:0x00400000
[0003.617] I> 30) Base:0xc7bd0000 Size:0x00010000
[0003.622] I> 31) Base:0x00000000 Size:0x00000000
[0003.626] I> 32) Base:0xf8000000 Size:0x08000000
[0003.631] I> 33) Base:0xce000000 Size:0x2a000000
[0003.635] I> 34) Base:0xcb000000 Size:0x01000000
[0003.639] I> 35) Base:0xae000000 Size:0x01000000
[0003.644] I> 36) Base:0xa0000000 Size:0x0e000000
[0003.648] I> 37) Base:0xca000000 Size:0x00800000
[0003.653] I> 38) Base:0x80000000 Size:0x20000000
[0003.657] I> 39) Base:0xb0000000 Size:0x08000000
[0003.662] I> 40) Base:0x00000000 Size:0x00000000
[0003.666] I> 41) Base:0x00000000 Size:0x00000000
[0003.671] I> 42) Base:0xc8200000 Size:0x00200000
[0003.675] I> 43) Base:0x00000000 Size:0x00000000
[0003.680] I> 44) Base:0x00000000 Size:0x00000000
[0003.684] I> 45) Base:0x00000000 Size:0x00000000
[0003.689] GIC-SPI Target CPU: 0
[0003.692] Interrupts Init done
[0003.694] calling constructors
[0003.697] initializing heap
[0003.700] I> Heap: [0xa0960000 ... 0xadf00000]
[0003.704] initializing threads
[0003.707] initializing timers
[0003.710] creating bootstrap completion thread
[0003.714] top of bootstrap2()
[0003.717] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0003.722] initializing platform
[0003.725] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0003.730] W> device prod register failed
[0003.734] I> Bl_dtb @0xadf00000
[0003.737] I> gpio framework initialized
[0003.747] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0003.752] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0003.758] I> fixed regulator driver initialized
[0003.776] I> register 'maxim' power off handle
[0003.779] I> virtual i2c enabled
[0003.779] I> registered 'maxim,max20024' pmic
[0003.780] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0003.780] I> Boot-device: QSPI
[0003.781] I> Boot_device: QSPI_FLASH instance: 0
[0003.785] I> configure_qspi_clk: qparams clk_src = 5, clk_div = 0, clk_src_freq = 800000000, interface_freq = 50000000
[0003.796] I> configure_qspi_clk: FORCING INTERFACE_FREQ TO 133000000!!
[0003.803] I> QSPI source rate = 204000 Khz
[0003.806] I> Requested rate for QSPI clock = 34000 Khz
[0003.812] I> BPMP-set rate for QSPI clk = 34000 Khz
[0003.816] I> tx_clk_tap_delay : 0
[0003.819] I> rx_clk_tap_delay : 16
[0003.823] I> QSPI Flash Size = 32 MB
[0003.830] I> Qspi initialized successfully
[0003.831] I> qspi flash-0 params source = boot args
[0003.835] W> No board IDs available
[0003.838] E> Failed to get board id info!
[0003.844] I> sdmmc-3 params source = safe params
[0003.851] I> Found 41 partitions in QSPI_FLASH (instance 0)
[0003.852] W> Cannot find any partition table for 00000003
[0003.857] E> Failed to publish 00000003
[0003.862] I> Found 22 partitions in SDMMC_USER (instance 3)
[0003.881] I> regulator 'vdd-hdmi-5v0' already enabled
[0003.887] I> regulator 'vdd-hdmi-5v0' already enabled
[0003.887] I> hdmi cable connected
[0003.892] W> set volts not configured for 'vdd-1v0'
[0003.896] W> set volts not configured for 'vdd-1v8-hs'
[0003.897] I> retrieved tmds range from prod_list_hdmi_soc
[0003.898] E> cannot find any other nvdisp nodes
[0003.904] E> I2C: Timeout while polling for bus clear. Last value 0x00000000.
[0003.905] E> I2C: Failed to clear bus for instance 3.
[0003.911] E> I2C: Failed to clear bus for instance 3.
[0003.915] E> I2C_DEV: Failed to initialize instance 3.
[0003.920] E> read_edid, invalid i2c handle
[0003.929] I> hdmi_enable, starting HDMI initialisation
[0003.934] I> hdmi_enable, HDMI initialisation complete
[0003.943] initializing target
[0003.944] calling apps_init()
[0003.945] starting app kernel_boot_app
[0003.946] I> Kernel type = Normal
Jetson UEFI firmware (version 3.1-32827747 built on 2023-03-19T14:56:32+00:00)
** WARNING: Test Key is used. **
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
ᅵᅵI/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
ᅵᅵ[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x4e0f0040]
[ 0.000000] Linux version 5.10.104-tegra (root@3921--VISN--KOCHI) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU 3
[ 0.000000] Machine model: NVIDIA Jetson Xavier NX Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x459d6dc98 SMBIOS=0xc7bb0000 SMBIOS 3.0=0x458930000 MEMATTR=0x459150018 ESRT=0x459182418 RNG=0x459d4ff98 MEMRESER
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x0000000459182418 to 0x0000000459182450.
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb2_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node 'fb3_carveout': base 0x0000000000000000, size 0 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000047fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000a0973fff]
[ 0.000000] node 0: [mem 0x00000000a0974000-0x00000000a0975fff]
[ 0.000000] node 0: [mem 0x00000000a0977000-0x00000000aeffffff]
[ 0.000000] node 0: [mem 0x00000000af010000-0x00000000c79fffff]
[ 0.000000] node 0: [mem 0x00000000c7b00000-0x00000000c7b9ffff]
[ 0.000000] node 0: [mem 0x00000000c7ba0000-0x00000000c7bbffff]
[ 0.000000] node 0: [mem 0x00000000ca000000-0x00000000ca7fffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x0000000457c67fff]
[ 0.000000] node 0: [mem 0x0000000457c68000-0x000000045868ffff]
[ 0.000000] node 0: [mem 0x0000000458690000-0x000000045891ffff]
[ 0.000000] node 0: [mem 0x0000000458920000-0x000000045893ffff]
[ 0.000000] node 0: [mem 0x0000000458940000-0x000000045908ffff]
[ 0.000000] node 0: [mem 0x0000000459090000-0x00000004590dffff]
[ 0.000000] node 0: [mem 0x00000004590e0000-0x00000004590effff]
[ 0.000000] node 0: [mem 0x00000004590f0000-0x000000045911ffff]
[ 0.000000] node 0: [mem 0x0000000459120000-0x000000045915ffff]
[ 0.000000] node 0: [mem 0x0000000459160000-0x000000045917ffff]
[ 0.000000] node 0: [mem 0x0000000459180000-0x000000045925ffff]
[ 0.000000] node 0: [mem 0x0000000459260000-0x00000004592fffff]
[ 0.000000] node 0: [mem 0x0000000459300000-0x000000045931ffff]
[ 0.000000] node 0: [mem 0x0000000459320000-0x000000045936ffff]
[ 0.000000] node 0: [mem 0x0000000459370000-0x00000004593bffff]
[ 0.000000] node 0: [mem 0x00000004593c0000-0x00000004597cffff]
[ 0.000000] node 0: [mem 0x00000004597d0000-0x000000045981ffff]
[ 0.000000] node 0: [mem 0x0000000459820000-0x000000045986ffff]
[ 0.000000] node 0: [mem 0x0000000459870000-0x0000000459d3ffff]
[ 0.000000] node 0: [mem 0x0000000459d40000-0x0000000459d4ffff]
[ 0.000000] node 0: [mem 0x0000000459d50000-0x0000000459ecffff]
[ 0.000000] node 0: [mem 0x0000000459ed0000-0x0000000459f6ffff]
[ 0.000000] node 0: [mem 0x0000000459f70000-0x000000045a06ffff]
[ 0.000000] node 0: [mem 0x000000045a070000-0x000000045a10ffff]
[ 0.000000] node 0: [mem 0x000000045a110000-0x000000045a1bffff]
[ 0.000000] node 0: [mem 0x000000045a1c0000-0x000000045a25ffff]
[ 0.000000] node 0: [mem 0x000000045a260000-0x000000045ab6ffff]
[ 0.000000] node 0: [mem 0x000000045ab70000-0x000000045ad4ffff]
[ 0.000000] node 0: [mem 0x000000045ad50000-0x000000047c4fffff]
[ 0.000000] node 0: [mem 0x000000047c500000-0x000000047c54ffff]
[ 0.000000] node 0: [mem 0x000000047c550000-0x000000047fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000047fffffff]
[ 0.000000] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.000000] cma: Reserved 64 MiB at 0x00000000c3800000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90200 r8192 d32680 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v2
[ 0.000000] CPU features: detected: NVIDIA Carmel CNP erratum
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 3903652
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifn
[ 0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000b3800000-0x00000000c3800000] (256MB)
[ 0.000000] Memory: 15179292K/15862460K available (18496K kernel code, 3170K rwdata, 7192K rodata, 4032K init, 1416K bss, 617632K reserved)
[ 0.000000] random: get_random_u64 called from __kmem_cache_create+0x38/0x420 with crng_init=0
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000005] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000708] Console: colour dummy device 80x25
[ 0.002174] printk: console [tty0] enabled
[ 0.002236] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.002270] pid_max: default: 32768 minimum: 301
[ 0.002451] LSM: Security Framework initializing
[ 0.002513] Yama: becoming mindful.
[ 0.002573] SELinux: Initializing.
[ 0.002734] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.002784] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.005869] rcu: Hierarchical SRCU implementation.
[ 0.006156] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.006896] DTS File Name: /home/vkchlt0370/SILI_CARB/sili_carb/Linux_for_Tegra/source/public/kernel/kernel-5.10/arch/arm64/boot/dts/../..s
[ 0.006972] DTB Build time: Nov 15 2023 14:48:27
[ 0.009699] Tegra Revision: A02 SKU: 0xde CPU Process: 0 SoC Process: 0
[ 0.009947] Remapping and enabling EFI services.
[ 0.011845] smp: Bringing up secondary CPUs ...
[ 0.050152] Detected PIPT I-cache on CPU1
[ 0.050288] CPU1: Booted secondary processor 0x0000000001 [0x4e0f0040]
[ 0.079601] Detected PIPT I-cache on CPU2
[ 0.079788] CPU2: Booted secondary processor 0x0000000100 [0x4e0f0040]
[ 0.109202] Detected PIPT I-cache on CPU3
[ 0.109381] CPU3: Booted secondary processor 0x0000000101 [0x4e0f0040]
[ 0.138788] Detected PIPT I-cache on CPU4
[ 0.138996] CPU4: Booted secondary processor 0x0000000200 [0x4e0f0040]
[ 0.168351] Detected PIPT I-cache on CPU5
[ 0.168542] CPU5: Booted secondary processor 0x0000000201 [0x4e0f0040]
[ 0.168966] smp: Brought up 1 node, 6 CPUs
[ 0.169191] SMP: Total of 6 processors activated.
[ 0.169284] CPU features: detected: Privileged Access Never
[ 0.169306] CPU features: detected: LSE atomic instructions
[ 0.169334] CPU features: detected: User Access Override
[ 0.169349] CPU features: detected: 32-bit EL0 Support
[ 0.169362] CPU features: detected: RAS Extension Support
[ 0.169374] CPU features: detected: CRC32 instructions
[ 0.169387] CPU features: detected: 32-bit EL1 Support
[ 0.238208] CPU: All CPU(s) started at EL2
[ 0.246553] devtmpfs: initialized
[ 0.296500] Registered cp15_barrier emulation handler
[ 0.296650] Registered setend emulation handler
[ 0.296674] KASLR enabled
[ 0.296939] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.296966] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.298298] pinctrl core: initialized pinctrl subsystem
[ 0.299211] SMBIOS 3.0.0 present.
[ 0.299251] DMI: Unknown NVIDIA Jetson Xavier NX Developer Kit/NVIDIA Jetson Xavier NX Developer Kit, BIOS 3.1-32827747 03/19/2023
[ 0.299938] NET: Registered protocol family 16
[ 0.302133] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.303093] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.304740] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.304800] audit: initializing netlink subsys (disabled)
[ 0.305081] audit: type=2000 audit(0.300:1): state=initialized audit_enabled=0 res=1
[ 0.305600] thermal_sys: Registered thermal governor 'step_wise'
[ 0.305606] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.305621] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.307909] cpuidle: using governor menu
[ 0.308188] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.308642] ASID allocator initialised with 32768 entries
[ 0.308878] Serial: AMBA PL011 UART driver
[ 0.312436] Tegra reboot handler registered.
[ 0.383228] mc: mapped MMIO address: 0xffff800010880000 -> 0x2c10000
[ 0.383276] mc: mapped MMIO address: 0xffff8000108a0000 -> 0x2c20000
[ 0.383302] mc: mapped MMIO address: 0xffff8000108c0000 -> 0x2c30000
[ 0.383330] mc: mapped MMIO address: 0xffff8000108e0000 -> 0x2c40000
[ 0.383357] mc: mapped MMIO address: 0xffff800010900000 -> 0x2c50000
[ 0.383381] mc: mapped MMIO address: 0xffff800010920000 -> 0x2b80000
[ 0.383405] mc: mapped MMIO address: 0xffff800010940000 -> 0x2b90000
[ 0.383429] mc: mapped MMIO address: 0xffff800010960000 -> 0x2ba0000
[ 0.383453] mc: mapped MMIO address: 0xffff800010980000 -> 0x2bb0000
[ 0.383477] mc: mapped MMIO address: 0xffff8000109a0000 -> 0x1700000
[ 0.383500] mc: mapped MMIO address: 0xffff8000109c0000 -> 0x1710000
[ 0.383523] mc: mapped MMIO address: 0xffff8000109e0000 -> 0x1720000
[ 0.383562] mc: mapped MMIO address: 0xffff800010a00000 -> 0x1730000
[ 0.383602] mc: mapped MMIO address: 0xffff800010a20000 -> 0x1740000
[ 0.383627] mc: mapped MMIO address: 0xffff800010a40000 -> 0x1750000
[ 0.383669] mc: mapped MMIO address: 0xffff800010a60000 -> 0x1760000
[ 0.383694] mc: mapped MMIO address: 0xffff800010a80000 -> 0x1770000
[ 0.383797] mc-err: mcerr ops are set to t19x
[ 0.396072] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.396099] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.396111] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.396146] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.403572] ACPI: Interpreter disabled.
[ 0.404647] vdd-epb-1v0: supplied by vdd-3v3-cvb
[ 0.405822] iommu: Default domain type: Translated
[ 0.405880] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.406247] SCSI subsystem initialized
[ 0.406427] usbcore: registered new interface driver usbfs
[ 0.406464] usbcore: registered new interface driver hub
[ 0.406500] usbcore: registered new device driver usb
[ 0.406868] mc: Linux media interface: v0.10
[ 0.406900] videodev: Linux video capture interface: v2.00
[ 0.407167] pps_core: LinuxPPS API ver. 1 registered
[ 0.407178] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.407203] PTP clock support registered
[ 0.407387] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[ 0.407757] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.407873] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.408396] Registered efivars operations
[ 0.414409] FPGA manager framework
[ 0.414507] Advanced Linux Sound Architecture Driver Initialized.
[ 0.415092] Bluetooth: Core ver 2.22
[ 0.415136] NET: Registered protocol family 31
[ 0.415150] Bluetooth: HCI device and connection manager initialized
[ 0.415167] Bluetooth: HCI socket layer initialized
[ 0.415186] Bluetooth: L2CAP socket layer initialized
[ 0.415210] Bluetooth: SCO socket layer initialized
[ 0.417045] camchar: rtcpu character device driver loaded
[ 0.417736] clocksource: Switched to clocksource arch_sys_counter
[ 0.720652] VFS: Disk quotas dquot_6.6.0
[ 0.720741] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.721097] pnp: PnP ACPI: disabled
[ 0.733101] la/ptsa driver initialized.
[ 0.733260] NET: Registered protocol family 2
[ 0.733540] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.743554] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.743724] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.744204] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.744645] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.744789] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.744960] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.745239] NET: Registered protocol family 1
[ 0.746207] RPC: Registered named UNIX socket transport module.
[ 0.746252] RPC: Registered udp transport module.
[ 0.746276] RPC: Registered tcp transport module.
[ 0.746300] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.746349] PCI: CLS 0 bytes, default 64
[ 0.746780] Trying to unpack rootfs image as initramfs...
[ 1.044507] Freeing initrd memory: 9120K
[ 1.049868] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.050278] kvm [1]: IPA Size Limit: 40 bits
[ 1.050834] kvm [1]: vgic interrupt IRQ9
[ 1.051358] kvm [1]: VHE mode initialized successfully
[ 1.053143] Initialise system trusted keyrings
[ 1.053500] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[ 1.059767] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.060686] NFS: Registering the id_resolver key type
[ 1.060730] Key type id_resolver registered
[ 1.060752] Key type id_legacy registered
[ 1.060849] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.060911] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.060958] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.070557] NET: Registered protocol family 38
[ 1.070604] Key type asymmetric registered
[ 1.070633] Asymmetric key parser 'x509' registered
[ 1.070684] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 1.070971] io scheduler mq-deadline registered
[ 1.070992] io scheduler kyber registered
[ 1.076554] tegra186-dpaux-pinctrl 155f0000.dpaux: can not get clock
[ 1.079476] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 1.079601] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 1.079674] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 1.079772] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 1.079882] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 1.085383] scrncapt: init (heads:4 wins:6 planes:4)
[ 1.085619] tegradccommon 15200000.display-hub: Nvhost Channel map failed
[ 1.086509] EINJ: ACPI disabled.
[ 1.089525] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 1.089552] tegra-pmc: ### PMC reset source: SYS_RESET_N
[ 1.089566] tegra-pmc: ### PMC reset level: L0
[ 1.089580] tegra-pmc: ### PMC reset status reg: 0x0
[ 1.089632] tegra-pmc: PMC Prod config success
[ 1.095235] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.100115] random: fast init done
[ 1.100178] printk: console [ttyTCU0] enabled
[ 2.581469] arm-smmu 10000000.iommu: probing hardware configuration...
[ 2.585990] arm-smmu 10000000.iommu: SMMUv2 with:
[ 2.590586] arm-smmu 10000000.iommu: stage 1 translation
[ 2.595974] arm-smmu 10000000.iommu: stage 2 translation
[ 2.601744] arm-smmu 10000000.iommu: nested translation
[ 2.606818] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 2.614001] arm-smmu 10000000.iommu: 64 context banks (0 stage-2 only)
[ 2.624597] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 2.627206] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.634019] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.641728] arm-smmu 12000000.iommu: probing hardware configuration...
[ 2.646809] arm-smmu 12000000.iommu: SMMUv2 with:
[ 2.651529] arm-smmu 12000000.iommu: stage 1 translation
[ 2.657293] arm-smmu 12000000.iommu: stage 2 translation
[ 2.662464] arm-smmu 12000000.iommu: nested translation
[ 2.667889] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 2.675068] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 2.685758] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 2.688167] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.695007] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.702438] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 2.712113] tegra_profiler: version: 1.151, samples/io: 51/30
[ 2.715422] tegra_profiler: auth: init
[ 2.719639] THERMAL EST: found 3 subdevs
[ 2.723104] THERMAL EST num_resources: 0
[ 2.726942] [THERMAL EST subdev 0]
[ 2.730265] [THERMAL EST subdev 1]
[ 2.733408] [THERMAL EST subdev 2]
[ 2.736925] THERMAL EST: Found 2 profiles, default profile is quiet
[ 2.743069] THERMAL EST: thz register success.
[ 2.747357] THERMAL EST: end of probe, return err: 0
[ 2.752602] nvsciipc: loaded module
[ 2.759282] tun: Universal TUN/TAP device driver, 1.6
[ 2.761999] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 2.768427] hns3: Copyright (c) 2017 Huawei Corporation.
[ 2.774268] e1000e: Intel(R) PRO/1000 Network Driver
[ 2.778924] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.785246] igb: Intel(R) Gigabit Ethernet Network Driver
[ 2.790554] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.796378] PPP generic driver version 2.4.2
[ 2.801006] PPP BSD Compression module registered
[ 2.805272] PPP Deflate Compression module registered
[ 2.810778] PPP MPPE Compression module registered
[ 2.815535] usbcore: registered new interface driver r8152
[ 2.821038] usbcore: registered new interface driver asix
[ 2.826372] usbcore: registered new interface driver ax88179_178a
[ 2.832488] usbcore: registered new interface driver cdc_ether
[ 2.838710] usbcore: registered new interface driver net1080
[ 2.844043] usbcore: registered new interface driver cdc_subset
[ 2.850339] usbcore: registered new interface driver zaurus
[ 2.856028] usbcore: registered new interface driver cdc_ncm
[ 2.861464] usbcore: registered new interface driver aqc111
[ 2.867328] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.873447] ohci-pci: OHCI PCI platform driver
[ 2.877478] ohci-platform: OHCI generic platform driver
[ 2.883319] tegra-xusb 3610000.xhci: Adding to iommu group 0
[ 2.889284] usbcore: registered new interface driver uas
[ 2.893775] usbcore: registered new interface driver usb-storage
[ 2.900101] tegra-xudc 3550000.xudc: Adding to iommu group 1
[ 2.905810] mousedev: PS/2 mouse device common for all mice
[ 2.910916] usbcore: registered new interface driver xpad
[ 2.918859] tegra_rtc c2a0000.rtc: registered as rtc1
[ 2.921908] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:21 UTC (21)
[ 2.929454] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.935944] i2c /dev entries driver
[ 2.939552] tegra-i2c 3160000.i2c: Adding to iommu group 2
[ 2.945008] tegra-i2c c240000.i2c: Adding to iommu group 2
[ 2.950644] tegra-i2c 3180000.i2c: Adding to iommu group 2
[ 2.956096] tegra-i2c 3190000.i2c: Adding to iommu group 2
[ 2.961098] tegra-i2c 31b0000.i2c: Adding to iommu group 2
[ 2.966614] tegra-i2c 31c0000.i2c: Adding to iommu group 2
[ 2.972323] tegra-i2c c250000.i2c: Adding to iommu group 2
[ 2.984873] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[ 2.985470] device-mapper: uevent: version 1.0.3
[ 2.989241] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 2.997594] usbcore: registered new interface driver bfusb
[ 3.002978] usbcore: registered new interface driver btusb
[ 3.009512] cpuidle: Initializing cpuidle driver
[ 3.013875] sdhci: Secure Digital Host Controller Interface driver
[ 3.019027] sdhci: Copyright(c) Pierre Ossman
[ 3.023754] Synopsys Designware Multimedia Card Interface Driver
[ 3.029637] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.035494] sdhci-tegra 3460000.sdhci: Adding to iommu group 3
[ 3.035566] sdhci-tegra 3440000.sdhci: Adding to iommu group 4
[ 3.043311] SMCCC: SOC_ID: ID = jep106:036b:0019 Revision = 0x00000102
[ 3.055046] tegra-bpmp bpmp: firmware: 128431eec76692047e1ac1ebc0392266
[ 3.077103] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x2
[ 3.086920] vdd-1v0: supplied by regulator-dummy
[ 3.092375] vdd-1v8-hs: supplied by regulator-dummy
[ 3.097176] vdd-1v8-ls: supplied by regulator-dummy
[ 3.102018] vdd-1v8-ao: supplied by regulator-dummy
[ 3.105949] vddio-ddr-1v1: supplied by regulator-dummy
[ 3.110702] vdd-rtc: supplied by regulator-dummy
[ 3.112685] spmic-ldo1: supplied by regulator-dummy
[ 3.114255] vdd-ao-3v3: supplied by regulator-dummy
[ 3.120615] vddio-emmc-3v3: supplied by regulator-dummy
[ 3.127263] spmic-ldo4: supplied by regulator-dummy
[ 3.128748] vdd-usb-3v3: supplied by regulator-dummy
[ 3.135203] vddio-sdmmc1-3v3: supplied by regulator-dummy
[ 3.141617] vdd-csi-1v2: supplied by vdd-1v8-ls
[ 3.147741] spmic-ldo8: supplied by vdd-1v8-ls
[ 3.149750] gpio-510 (gpio_default): hogged as output/high
[ 3.151692] gpio-511 (gpio_default): hogged as output/high
[ 3.154594] gpiochip0: registered GPIOs 504 to 511 on max77620-gpio
[ 3.290104] max77686-rtc max77620-rtc: registered as rtc0
[ 3.291161] max77620-power max20024-power: Event recorder REG_NVERC : 0x54
[ 3.291499] max77620 4-003c: max77620 probe successful
ᅵᅵrm_rail_debugfs_init: /rm/vdd_cpu: failed
debugfs initialized
ᅵᅵ[ 4.102993] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 4.104160] hid: raw HID events driver (C) Jiri Kosina
[ 4.105024] usbcore: registered new interface driver usbhid
[ 4.105228] usbhid: USB HID core driver
[ 4.107515] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 5
[ 4.108641] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
ᅵᅵ[ 22.242161] Camera-FW on t194-rce-safe started
TCU early console enabled.
[ 22.316767] Camera-FW on t194-rce-safe ready SHA1=26f9e5f7 (crt 0.777 ms, total boot 75.412 ms)
ᅵᅵ[ 4.192874] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 4.193383] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 4.194379] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 4.195063] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 4.196706] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 4.197208] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 4.197848] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 4.198907] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (49)
[ 4.199218] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 4.201041] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=26f9e5f7dc48f7914a7654904022cf8ae53e1e9f
[ 4.209268] tegra_aon c1a0000.aon: Adding to iommu group 6
[ 4.215486] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 4.220359] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 4.227064] denver_knobs_init:MTS_VERSION:55637613
[ 4.239475] t19x_cache tegra-cache: probed
[ 4.243500] optee: probing for conduit method.
[ 4.244396] optee: revision 3.19 (3f29c61f)
[ 4.245330] optee: dynamic shared memory is enabled
[ 4.249003] optee: initialized driver
[ 4.254751] nvpmodel: initialized successfully
[ 4.255716] tegra_hv: get_hvd: not initialized yet
[ 4.260448] user_ivc_mempool: hypervisor not present
[ 4.266039] usbcore: registered new interface driver snd-usb-audio
[ 4.272519] u32 classifier
[ 4.273950] input device check on
[ 4.277593] Actions configured
[ 4.281589] Initializing XFRM netlink socket
[ 4.286490] NET: Registered protocol family 10
[ 4.293212] Segment Routing with IPv6
[ 4.293537] NET: Registered protocol family 17
[ 4.298165] NET: Registered protocol family 15
[ 4.302288] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need.
[ 4.315817] Bluetooth: RFCOMM socket layer initialized
[ 4.320481] Bluetooth: RFCOMM ver 1.11
[ 4.324657] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.330219] Bluetooth: HIDP socket layer initialized
[ 4.336349] 9pnet: Installing 9P2000 support
[ 4.339963] Key type dns_resolver registered
[ 4.345065] registered taskstats version 1
[ 4.348097] Loading compiled-in X.509 certificates
[ 4.386685] Loaded X.509 cert 'Build time autogenerated kernel key: 2af5c325164f8702d902f7eef7a882d29bf7d2fd'
[ 4.388813] tegra194-pcie 14160000.pcie: Adding to iommu group 7
[ 4.394957] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 4.395490] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 4.395941] tegra194-pcie 14160000.pcie: MEM 0x1400000000..0x173fffffff -> 0x1400000000
[ 4.396336] tegra194-pcie 14160000.pcie: MEM 0x1740000000..0x17ffffffff -> 0x0040000000
[ 5.510572] tegra194-pcie 14160000.pcie: Phy link never came up
[ 5.511441] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 5.511695] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 5.511870] pci_bus 0004:00: root bus resource [io 0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[ 5.512209] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[ 5.512591] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[ 5.513091] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[ 5.513756] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[ 5.535609] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 5.535961] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 5.538132] pcieport 0004:00:00.0: Adding to iommu group 7
[ 5.539466] pcieport 0004:00:00.0: PME: Signaling with IRQ 24
[ 5.541184] pcieport 0004:00:00.0: AER: enabled with IRQ 24
[ 5.542923] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[ 5.544076] pci 0004:00:00.0: Removing from iommu group 7
[ 5.544613] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[ 5.548797] tegra194-pcie 141a0000.pcie: Adding to iommu group 8
[ 5.555286] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 5.555906] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff -> 0x003a100000
[ 5.556288] tegra194-pcie 141a0000.pcie: MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[ 5.556661] tegra194-pcie 141a0000.pcie: MEM 0x1f40000000..0x1fffffffff -> 0x0040000000
[ 6.653880] tegra194-pcie 141a0000.pcie: Phy link never came up
[ 6.654679] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 6.654920] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 6.655102] pci_bus 0005:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[ 6.655338] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 6.655508] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 6.655834] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 6.656340] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 6.672901] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 6.673621] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 6.675590] pcieport 0005:00:00.0: Adding to iommu group 8
[ 6.676971] pcieport 0005:00:00.0: PME: Signaling with IRQ 26
[ 6.678594] pcieport 0005:00:00.0: AER: enabled with IRQ 26
[ 6.680150] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 6.680997] pci 0005:00:00.0: Removing from iommu group 8
[ 6.681240] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 6.711856] host1x 13e10000.host1x: Adding to iommu group 9
[ 6.732879] host1x 13e10000.host1x: initialized
[ 6.734289] iommu_context_dev 13e10000.host1x:ctx0: Adding to iommu group 10
[ 6.735075] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 6.736131] iommu_context_dev 13e10000.host1x:ctx1: Adding to iommu group 11
[ 6.736708] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 6.737883] iommu_context_dev 13e10000.host1x:ctx2: Adding to iommu group 12
[ 6.738495] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 6.739456] iommu_context_dev 13e10000.host1x:ctx3: Adding to iommu group 13
[ 6.740043] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 6.747000] iommu_context_dev 13e10000.host1x:ctx4: Adding to iommu group 14
[ 6.754253] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 6.763984] iommu_context_dev 13e10000.host1x:ctx5: Adding to iommu group 15
[ 6.771131] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61, iommu=smmu.0x0000000012000000)
[ 6.781056] iommu_context_dev 13e10000.host1x:ctx6: Adding to iommu group 16
[ 6.788129] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62, iommu=smmu.0x0000000012000000)
[ 6.798309] iommu_context_dev 13e10000.host1x:ctx7: Adding to iommu group 17
[ 6.805156] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63, iommu=smmu.0x0000000012000000)
[ 6.814765] falcon 15340000.vic: Adding to iommu group 18
[ 6.828559] falcon 15340000.vic: initialized
[ 6.829359] falcon 15380000.nvjpg: Adding to iommu group 18
[ 6.834771] falcon 15380000.nvjpg: initialized
[ 6.835260] falcon 154c0000.nvenc: Adding to iommu group 18
[ 6.848096] falcon 154c0000.nvenc: initialized
[ 6.848683] falcon 15a80000.nvenc1: Adding to iommu group 18
[ 6.858064] falcon 15a80000.nvenc1: initialized
[ 6.858566] nvdec 15480000.nvdec: Adding to iommu group 18
[ 6.869560] nvdec 15480000.nvdec: initialized
[ 6.870121] nvdec 15140000.nvdec1: Adding to iommu group 18
[ 6.879122] nvdec 15140000.nvdec1: initialized
[ 6.879610] tsec 15500000.tsec: Adding to iommu group 19
[ 6.885600] tsec 15500000.tsec: initialized
[ 6.886085] tsec 15100000.tsecb: Adding to iommu group 20
[ 6.894979] tsec 15100000.tsecb: initialized
[ 6.900282] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 6.925863] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 6.937999] gpio-374 (wifi-enable): hogged as output/high
[ 6.938268] gpio-431 (camera-control-output-low): hogged as output/low
[ 6.938483] gpio-432 (camera-control-output-low): hogged as output/low
[ 6.940062] gpiochip1: registered GPIOs 335 to 503 on tegra194-gpio
[ 6.941496] gpiochip2: registered GPIOs 305 to 334 on tegra194-gpio-aon
[ 6.942015] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 6.946097] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 6.951757] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 6.957472] tegra-pwm 32d0000.pwm: PWM clk can sleep in ops
[ 6.962653] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 6.971140] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[ 6.978384] tegra194-isp5 13e10000.host1x:isp@14800000: Adding to iommu group 21
[ 6.989281] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 6.995172] t194-nvcsi 13e10000.host1x:nvcsi@15a00000: initialized
[ 7.001004] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[ 7.010143] tegra-camrtc-capture-vi tegra-capture-vi: subdev 13e10000.host1x:nvcsi@15a00000- bound
[ 7.019085] tegra194-vi5 15c10000.vi: Adding to iommu group 22
[ 7.026025] scare-pigeon 13e10000.host1x:vi-thi@15f00000: context isolation disabled due to no IOMMU
[ 7.034148] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[ 7.040141] scare-pigeon 13e10000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 7.049899] scare-pigeon 13e10000.host1x:isp-thi@14b00000: initialized
[ 7.056049] pva 16000000.pva0: Adding to iommu group 23
[ 7.081598] pva 16000000.pva0: initialized
[ 7.086699] pva 16800000.pva1: Adding to iommu group 24
[ 7.097371] pva 16800000.pva1: initialized
[ 7.101991] nvdla 15880000.nvdla0: Adding to iommu group 25
[ 7.114604] nvdla 15880000.nvdla0: initialized
[ 7.115955] nvdla 158c0000.nvdla1: Adding to iommu group 26
[ 7.132012] nvdla 158c0000.nvdla1: initialized
[ 7.134263] tegradccommon 15200000.display-hub: host1x channel mapped
[ 7.134546] tegradccommon 15200000.display-hub: dc_common syncpt # 1 allocated
[ 7.134797] tegradccommon 15200000.display-hub: dma mapping done
[ 7.136382] tegradc 15200000.display: Adding to iommu group 27
[ 7.143567] tegradc 15200000.display: disp0 connected to head0->sor1
[ 7.143946] generic_infoframe_type: 0x87
[ 7.144181] tegradc 15200000.display: DT parsed successfully
[ 7.144411] tegradc 15200000.display: Display dc.(____ptrval____) registered with id=0
[ 7.146727] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=63
[ 7.147742] tegradc 15210000.display: Adding to iommu group 27
[ 7.152601] tegra_cec 3960000.tegra_cec: Unpowergated DISP
[ 7.167710] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 7.170244] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 7.175904] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 7.176145] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 7.184022] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[ 7.189534] tegra_cec 3960000.tegra_cec: probed
[ 7.197727] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[ 7.210929] tegradc 15200000.display: vblank syncpt # 8 for dc 0
[ 7.211468] tegra-gpcdma 2600000.dma: Adding to iommu group 2
[ 7.216639] tegradc 15200000.display: vpulse3 syncpt # 9 for dc 0
[ 7.228603] tegradc 15200000.display: Bootloader disp_param detected. Detected mode: 8x4 (on 0x0mm) pclk=148350937
[ 7.230453] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[ 7.246043] kfuse 3830000.kfuse: initialized
[ 7.251037] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 7.251167] tegradc 15200000.display: hdmi: can't get adpater for ddc bus 3
[ 7.256470] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 7.256998] serial-tegra 3100000.serial: Adding to iommu group 2
[ 7.276566] tegradc 15200000.display: out->type:1 out_ops->init err = -517
[ 7.277041] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 31, base_baud = 0) is a TEGRA_UART
[ 7.285113] tegradc 15210000.display: disp0 connected to head1->sor
[ 7.298237] tegradc 15210000.display: parse_dp_settings: No dp-lt-settings node
[ 7.298874] serial-tegra 3110000.serial: Adding to iommu group 2
[ 7.305556] tegradc 15210000.display: DT parsed successfully
[ 7.312204] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 32, base_baud = 0) is a TEGRA_UART
[ 7.316974] tegradc 15210000.display: dc.1 probe not in device tree order, deferring
[ 7.334770] serial-tegra 3140000.serial: Adding to iommu group 2
[ 7.340075] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 33, base_baud = 0) is a TEGRA_UART
[ 7.357807] tegra-xusb 3610000.xhci: Firmware timestamp: 2022-03-16 11:07:43 UTC, Version: 60.13 release
[ 7.358133] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 7.363333] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 7.371440] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x0000000000050810
[ 7.380407] tegra-xusb 3610000.xhci: irq 188, io mem 0x03610000
[ 7.386858] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 7.394516] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.401508] usb usb1: Product: xHCI Host Controller
[ 7.406754] usb usb1: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 7.412781] usb usb1: SerialNumber: 3610000.xhci
[ 7.418495] hub 1-0:1.0: USB hub found
[ 7.421598] hub 1-0:1.0: 4 ports detected
[ 7.426144] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 7.430765] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 7.438614] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 7.446284] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 7.454018] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 7.461176] usb usb2: Product: xHCI Host Controller
[ 7.466413] usb usb2: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 7.472369] usb usb2: SerialNumber: 3610000.xhci
[ 7.477848] hub 2-0:1.0: USB hub found
[ 7.480835] hub 2-0:1.0: 4 ports detected
[ 7.519863] tegra-i2c 31e0000.i2c: Adding to iommu group 2
[ 7.526165] i2c i2c-2: Added multiplexed i2c bus 9
[ 7.527900] i2c i2c-2: Added multiplexed i2c bus 10
[ 7.528114] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 7.542612] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1907000 KHz, changing to: 1907200 KHz
[ 7.543647] tegra194-cpufreq ccplex: probed with BWMGR
[ 7.544661] sdhci-tegra 3460000.sdhci: BWMGR client registration for eMC Successful
[ 7.546015] irq: IRQ262: trimming hierarchy from :pmc@c360000
[ 7.546709] sdhci-tegra 3440000.sdhci: Got CD GPIO
[ 7.546950] sdhci-tegra 3440000.sdhci: BWMGR client registration for eMC Successful
[ 7.548375] tegra194-isp5 13e10000.host1x:isp@14800000: initialized
[ 7.559669] mmc0: CQHCI version 5.10
[ 7.560732] tegra194-vi5 15c10000.vi: initialized
[ 7.563730] irq: IRQ263: trimming hierarchy from :pmc@c360000
[ 7.565518] nvethernet 2490000.ethernet: Adding to iommu group 28
[ 7.568598] tegradc 15200000.display: disp0 connected to head0->sor1
[ 7.568652] sdhci-tegra 3440000.sdhci: wakeup init done, cdirq 263
[ 7.575432] nvethernet 2490000.ethernet: failed to read skip mac reset flag, default 0
[ 7.581762] generic_infoframe_type: 0x87
[ 7.587820] nvethernet 2490000.ethernet: failed to read MDIO address
[ 7.595604] tegradc 15200000.display: DT parsed successfully
[ 7.596474] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 7.599583] nvethernet 2490000.ethernet: setting to default DMA bit mask
[ 7.599590] nvethernet 2490000.ethernet: set default TXQ to TC mapping
[ 7.599595] nvethernet 2490000.ethernet: Setting default PTP RX queue
[ 7.599608] nvethernet 2490000.ethernet: Failed to read DMA Tx ring size, using default [1024]
[ 7.603861] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit
[ 7.606210] tegradc 15200000.display: Display dc.(____ptrval____) registered with id=0
[ 7.611495] nvethernet 2490000.ethernet: Failed to read DMA Rx ring size, using default [1024]
[ 7.619884] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
[ 7.625956] nvethernet 2490000.ethernet: missing nvidia,pad_auto_cal_pu_offset, setting default 0
[ 7.632486] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 933000000 Hz
[ 7.632495] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 300000000 Hz
[ 7.639053] nvethernet 2490000.ethernet: missing nvidia,pad_auto_cal_pd_offset, setting default 0
[ 7.648064] tegradc 15200000.display: vblank syncpt # 11 for dc 0
[ 7.661758] nvethernet 2490000.ethernet: failed to get eqos_rx_m clk
[ 7.663391] tegradc 15200000.display: vpulse3 syncpt # 12 for dc 0
[ 7.671863] nvethernet 2490000.ethernet: failed to get eqos_rx_input clk
[ 7.680408] tegradc 15200000.display: Bootloader disp_param detected. Detected mode: 8x4 (on 0x0mm) pclk=148350937
[ 7.682616] mmc0: Command Queue Engine enabled
[ 7.682621] mmc0: periodic cache flush enabled
[ 7.682637] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 7.683137] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 7.683301] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB, chardev (510:0)
[ 7.687033] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22
[ 7.689096] nvethernet 2490000.ethernet: failed to get eqos_tx_divider clk
[ 7.689740] usb 1-3: new high-speed USB device number 2 using tegra-xusb
[ 7.690354] nvethernet 2490000.ethernet: Ethernet MAC address: 48:b0:2d:67:95:59
[ 7.690814] nvethernet 2490000.ethernet: Macsec not supported/Not enabled in DT
[ 7.691674] nvethernet 2490000.ethernet: eth0 (HW ver: 50) created with 1 DMA channels
[ 7.692845] irq: IRQ265: trimming hierarchy from :pmc@c360000
[ 7.692958] irq: IRQ266: trimming hierarchy from :interrupt-controller@3881000
[ 7.693096] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 7.694235] tegra-se-nvhost 15810000.se: Adding to iommu group 29
[ 7.695950] tegra-se-nvhost 15810000.se: initialized
[ 7.702514] tegradc 15200000.display: hdmi: invalid prod list prod_list_hdmi_board
[ 7.702853] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 7.703333] tegra-se-nvhost 15820000.se: Adding to iommu group 30
[ 7.704005] tegra-se-nvhost 15820000.se: initialized
[ 7.706105] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 7.714153] tegradc 15200000.display: hdmi: tegra_hdmi_tmds_range_read(bd) failed
[ 7.720835] tegra-se-nvhost 15830000.se: Adding to iommu group 31
[ 7.737408] CPU:0, Error: cbb-noc@2300000, irq=15
[ 7.903721] **************************************
[ 7.908961] CPU:0, Error:cbb-noc
[ 7.912303] Error Logger : 0
[ 7.915186] ErrLog0 : 0x80030000
[ 7.918935] Transaction Type : RD - Read, Incrementing
[ 7.924448] Error Code : SLV
[ 7.927603] Error Source : Target
[ 7.931279] Error Description : Target error detected by CBB slave
[ 7.937930] AXI2APB_5 bridge error: RDFIFOF - Read Response FIFO Full interrupt
[ 7.945112] Packet header Lock : 0
[ 7.949035] Packet header Len1 : 3
[ 7.952537] NOC protocol version : version >= 2.7
[ 7.957525] ErrLog1 : 0x352428
[ 7.960849] ErrLog2 : 0x0
[ 7.963735] RouteId : 0x352428
[ 7.966973] InitFlow : ccroc_p2ps/I/ccroc_p2ps
[ 7.971961] Targflow : host1x_p2pm/T/host1x_p2pm
[ 7.976773] TargSubRange : 18
[ 7.980011] SeqId : 0
[ 7.982555] ErrLog3 : 0x4045c
[ 7.986048] ErrLog4 : 0x0
[ 7.988695] Address accessed : 0x15b4045c
[ 7.993222] ErrLog5 : 0xa09f851
[ 7.996635] Non-Modify : 0x1
[ 7.999791] AXI ID : 0x14
[ 8.003197] Master ID : CCPLEX
[ 8.006266] Security Group(GRPSEC): 0x7e
[ 8.010723] Cache : 0x1 -- Bufferable
[ 8.014668] Protection : 0x2 -- Unprivileged, Non-Secure, Data Access
[ 8.021493] FALCONSEC : 0x0
[ 8.024898] Virtual Queuing Channel(VQC): 0x0
[ 8.029279] **************************************
[ 8.034577] ------------[ cut here ]------------
[ 8.039073] kernel BUG at drivers/soc/tegra/cbb/tegra194-cbb.c:2057!
[ 8.045381] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
[ 8.050636] Modules linked in:
[ 8.053863] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.10.104-tegra #3
[ 8.060255] Hardware name: Unknown NVIDIA Jetson Xavier NX Developer Kit/NVIDIA Jetson Xavier NX Developer Kit, BIOS 3.1-32827747 03/19/203
[ 8.072769] pstate: 60400089 (nZCv daIf +PAN -UAO -TCO BTYPE=--)
[ 8.079068] pc : tegra194_cbb_err_isr+0x19c/0x1b0
[ 8.083532] lr : tegra194_cbb_err_isr+0x11c/0x1b0
[ 8.088252] sp : ffff800010003df0
[ 8.091924] x29: ffff800010003df0 x28: 0000000000000001
[ 8.097092] x27: 0000000000000080 x26: ffffbb3e72f5e040
[ 8.102772] x25: ffffbb3e738bbe38 x24: 0000000000000001
[ 8.108198] x23: ffffbb3e73247000 x22: ffffbb3e736decb0
[ 8.113536] x21: 000000000000000f x20: 0000000000000005
[ 8.118792] x19: ffffbb3e736deca0 x18: 0000000000000010
[ 8.124476] x17: ffffbb3e7300a408 x16: 000000008fef7426
[ 8.129811] x15: ffffbb3e73552bf0 x14: 0720072007200720
[ 8.135066] x13: 0720072007200720 x12: 0720072007200720
[ 8.140403] x11: 0720072007200720 x10: 0720072007200720
[ 8.145917] x9 : 0720072007200720 x8 : 07200720072a072a
[ 8.151701] x7 : 072a072a072a072a x6 : c0000000ffffefff
[ 8.157198] x5 : 0000000000057fa8 x4 : ffffbb3e73567968
[ 8.162366] x3 : 00000000ffffffff x2 : ffffbb3e719de170
[ 8.167962] x1 : ffffbb3e73552680 x0 : 0000000100010001
[ 8.173313] Call trace:
[ 8.175752] tegra194_cbb_err_isr+0x19c/0x1b0
[ 8.179799] __handle_irq_event_percpu+0x68/0x2a0
[ 8.184588] handle_irq_event_percpu+0x40/0xa0
[ 8.189052] handle_irq_event+0x50/0xf0
[ 8.192575] handle_fasteoi_irq+0xc0/0x170
[ 8.196581] generic_handle_irq+0x40/0x60
[ 8.200606] __handle_domain_irq+0x70/0xd0
[ 8.204807] efi_header_end+0xb0/0xf0
[ 8.208305] el1_irq+0xd0/0x180
[ 8.211286] cpuidle_enter_state+0xb8/0x410
[ 8.215483] cpuidle_enter+0x40/0x60
[ 8.218983] call_cpuidle+0x44/0x80
[ 8.222753] do_idle+0x208/0x270
[ 8.225894] cpu_startup_entry+0x30/0x70
[ 8.229931] rest_init+0xdc/0xe8
[ 8.233153] arch_call_rest_init+0x18/0x20
[ 8.237111] start_kernel+0x514/0x54c
[ 8.240682] Code: a9446bf9 a94573fb a8c67bfd d65f03c0 (d4210000)
[ 8.246912] ---[ end trace e9f04d27af51b5c4 ]---
[ 8.251612] Kernel panic - not syncing: Oops - BUG: Fatal exception in interrupt
[ 8.259136] SMP: stopping secondary CPUs
[ 8.262745] Kernel Offset: 0x3b3e61820000 from 0xffff800010000000
[ 8.269110] PHYS_OFFSET: 0xffff9807c0000000
[ 8.272982] CPU features: 0x8240002,03802a30
[ 8.277427] Memory Limit: none
[ 8.280855] ---[ end Kernel panic - not syncing: Oops - BUG: Fatal exception in interrupt ]---
What may be the reason behind it?
