Jetson Xavier NX Memory map
Hello
i’m using xavier nx on my own product.
and i’m going to get a certificate called IoT Security Certification in Korea now.
The certification has following requirements.
Memory map image(or text) for Xavier NX CPU (Kernel)
I tried to find it in various documents, but couldn’t find it.
Where can i find it?
I will attach an example of a memory map as an image.
Thank you .
KakaoTalk_20221023_165309824
If you use Jetpack 4 release, we use NvBuffer APIs for accessing frame data. The data can be captured into NvBuffer and call NvBufferMemMap() to get CPU pointer.
Thank you for your reply.
Unfortunately, I used Jetpack 5 release.
In Jetpack 5, Can i NvBufferMemMap() too?
We have switched to NvBufSurface APIs on Jetpack 5. Please check the header files:
/usr/src/jetson_multimedia_api/include/nvbufsurface.h
/usr/src/jetson_multimedia_api/include/nvbufsurftransform.h
You can call NvBufSurfaceMap()
