Hi Team,
For Xavier NX Carrier board i want to use SD card Interface for Booting purpose.
As in the attached image that’s my plan. the connections are directly going to the Xavier NX.
In the image the SD detect i gived as 1.8V and we have 3.3V in the above load switch.
My question :-
- Please confirm if 3.3V from the Load switch can be used for SD_CARD_DET instead of 1.8V , is it ok or not.
- Does the Load switch Control require from the Xavier NX , if yes then which pin is required.
