Jetson Xavier NX not able to run segmentation using GPU
Description
I am trying to run matterports segmentation as shown in this repo. Segmentation I have ajetson xavier NX. I am not able to run a basic program on it.
I get the following error towards the end
Stats:
Limit:                   195117056
InUse:                   195117056
MaxInUse:                195117056
NumAllocs:                     426
MaxAllocSize:             70344448
2021-06-17 15:09:45.539596: W tensorflow/core/common_runtime/bfc_allocator.cc:424] *******************************************************************************************xxxxxxxxx
2021-06-17 15:09:45.539742: W tensorflow/core/framework/op_kernel.cc:1651] OP_REQUIRES failed at assign_op.h:117 : Resource exhausted: OOM when allocating tensor with shape[256] and type float on /job:localhost/replica:0/task:0/device:GPU:0 by allocator GPU_0_bfc
These are the specs of my Jetson
Python - 3.6.9
Tensorflow - 1.15.4
CUDA - 10.2.89
Cudnn - 8.0.0
Jetpack 45
Environment
I feel the GPU isnt bein gused adn hence its taking forever. There were few times when it used to execute but it took close to 5 minutes to process one image. Thats highly inefficient. And the jetson used to hang. I want to know if theres some issue with the tensorflow version for this particular application of segmentation. Also, how to check if the GPU is bein gused or not?
Relevant Files
I haave attached the code of my py script for reference.
segmentation.py (3.5 KB)
Hi @akshay9,
We recommend you to post your concern on Jetson forum forum to get better help.
Thank you.
Thank you. WIll do that.
