Hello!
I’m new to Jetson space. I used Jetson Xavier NX for few weeks now and I put sudo apt-get upgrade command into terminal to see if some problems with CUDA library would be solved…
After that, I wanted to restart the device but it didn’t boot at all.
I tried putting new SDK to SD Card but it isn’t even flashing now.
I tried different displays (DP and HDMI) and 2 SD Cards, but no difference.
What to do?
Everything was working well until now. I was using JetPack 5.0.1.
hello strahija9999,
could you please setup the serial console and gather the logs for reference,
you may see-also Jetson Nano Style - Serial Console - JetsonHacks for UART connections.
