Jetson Xavier NX - POE
i would like to know if there is any solution to power the dev kit with POE, if not, then will a splitter like this work : https://www.planet.com.tw/storage/products/48432/C-POE-171S_s.pdf
any help will be appreciated, thank you!
Should work when running in “Ultra PoE (50W)” configuration with 12V or 19V.
Thank you so much for the reply. any hope for an actual POE hat directly on the xavier nx?
