Jetson Powers off after 5 minutes in headless mode. but when the same Jetson is connected to a display and the GUI is loaded it runs until switched off. I don’t think this is a power module issue because I’m using the original adapter that came with it. and if that indeed was the case the same should be reproduced while connecting the display. This is a time-out issue I suppose. Any help would be appreciated
If you use default rootfs, it will enter power saving mode after 5-minute noaction. But you shall still be able to login the device through ssh command.
