Hardware :Jetson Xavier NX ,Jetpack Version:4.6, run reboot command can not reboot system, push reset buttom can reboot sytem.Thanks! debug urat output :
[ 45.208427] watchdog: watchdog0: watchdog did not stop!
[ 45.212062] systemd-shutdow: 45 output lines suppressed due to ratelimiting
Please upgrade to jp4.6.2 and test again.
I use jetpack 4.6.2 ,the error is same :(
Is this NX devkit? or custom carrier board?
This is custom carrier board。carrier board sch base on developer kit。carrier board mcu firmware version is “P2822_P3509_Power_Button_Firmware_v011”。
Could you move your module back to devkit and test the sudo reboot function?
