现在有个问题,我在使用sdio作为wifi模块接口的时候,需要在设备树中添加“nvidia,disable-rtpm",否则就会报错,如下
[ 297.169740] sdhci-tegra 3440000.sdhci: Reg 0x30\ being accessed without clock
[ 297.169783] ------------[ cut here ]------------
[ 297.169787] WARNING: CPU: 0 PID: 12 at ../drivers/mmc/host/sdhci-tegra.c:284 tegra_sdhci_is_clk_enabled.isra.1+0x48/0x60
[ 297.169822] Modules linked in: 8852bs(O) cfg80211 xt_conntrack ipt_MASQUERADE nf_nat_masquerade_ipv4 nf_conntrack_netlink nfnetlink xt_addrtype iptable_filter iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack br_netfilter zram overlay userspace_alert ip_tables x_tables
[ 297.169824]
[ 297.169827] CPU: 0 PID: 12 Comm: watchdog/0 Tainted: G W O L 4.9.253-tegra #2
[ 297.169829] Hardware name: NVIDIA Jetson Xavier NX Developer Kit (DT)
[ 297.169832] task: ffffffc1f6b71c00 task.stack: ffffffc1f6b80000
[ 297.169835] PC is at tegra_sdhci_is_clk_enabled.isra.1+0x48/0x60
[ 297.169837] LR is at tegra_sdhci_is_clk_enabled.isra.1+0x48/0x60
[ 297.169840] pc : [<ffffff8008bc51d0>] lr : [<ffffff8008bc51d0>] pstate: 204001c5
[ 297.169842] sp : ffffffc1ffd00dd0
[ 297.169847] x29: ffffffc1ffd00dd0 x28: ffffffc1f6b71c00
[ 297.169852] x27: ffffff800a0ea000 x26: ffffffc1e25247c0
[ 297.169857] x25: ffffffc1ffd00f3c x24: ffffff8009865018
[ 297.169862] x23: ffffff8009eb6e38 x22: 0000000000000034
[ 297.169868] x21: ffffffc1e2524a38 x20: 0000000000000030
[ 297.169873] x19: ffffffc1e2524000 x18: 0000000000000020
[ 297.169878] x17: 0000000000200000 x16: 000000000000000e
[ 297.169883] x15: ffffffffffffffff x14: ffffff800a19ddd8
[ 297.169888] x13: ffffff800a19da1b x12: ffffff8009ed4000
[ 297.169893] x11: 000000000003f018 x10: ffffff800a19d050
[ 297.169899] x9 : 0000000000000001 x8 : ffffffc1ffcfbe53
[ 297.169904] x7 : 0000000000000000 x6 : 0000000014c6bd23
[ 297.169908] x5 : 0000000000000000 x4 : 0000000000000000
[ 297.169917] x3 : ffffffffffffffff x2 : 00000041f6498000
[ 297.169922] x1 : ffffffc1f6b71c00 x0 : 0000000000000040
[ 297.169924]
[ 297.169925] ---[ end trace 037077a91a2acfd6 ]---
[ 297.169927] Call trace:
[ 297.169931] [<ffffff8008bc51d0>] tegra_sdhci_is_clk_enabled.isra.1+0x48/0x60
[ 297.169934] [<ffffff8008bc5480>] tegra_sdhci_readl+0x28/0x60
[ 297.169937] [<ffffff8008bc13a0>] sdhci_irq+0x7f0/0xd80
[ 297.169940] [<ffffff8008121918>] __handle_irq_event_percpu+0x68/0x288
[ 297.169943] [<ffffff8008121b60>] handle_irq_event_percpu+0x28/0x60
[ 297.169946] [<ffffff8008121be8>] handle_irq_event+0x50/0x80
[ 297.169950] [<ffffff8008125a7c>] handle_fasteoi_irq+0xd4/0x1c0
[ 297.169953] [<ffffff80081208cc>] generic_handle_irq+0x34/0x50
[ 297.169956] [<ffffff8008120fb8>] __handle_domain_irq+0x68/0xc0
[ 297.169959] [<ffffff8008080d44>] gic_handle_irq+0x5c/0xb0
[ 297.169961] [<ffffff8008082c28>] el1_irq+0xe8/0x194
[ 297.169965] [<ffffff8008f66c58>] _raw_spin_unlock_irq+0x28/0x58
[ 297.169968] [<ffffff80080e55bc>] finish_task_switch+0x7c/0x1a8
[ 297.169972] [<ffffff8008f621c4>] __schedule+0x23c/0x7d0
[ 297.169976] [<ffffff8008f62798>] schedule+0x40/0xa8
[ 297.169980] [<ffffff80080dfb18>] smpboot_thread_fn+0x238/0x248
[ 297.169983] [<ffffff80080db0a4>] kthread+0xec/0xf0
[ 297.169986] [<ffffff80080838a0>] ret_from_fork+0x10/0x30
[ 2.029927] sdhci: =========== REGISTER DUMP (mmc0)===========
[ 2.030058] sdhci: Sys addr: 0x00000000 | Version: 0x00000505
[ 2.030170] sdhci: Blk size: 0x00000200 | Blk cnt: 0x00000000
[ 2.030276] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 2.030382] sdhci: Present: 0x01fb00f0 | Host ctl: 0x00000020
[ 2.030488] sdhci: Power: 0x00000000 | Blk gap: 0x00000000
[ 2.030594] sdhci: Wake-up: 0x00000000 | Clock: 0x00000000
[ 2.030701] sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 2.030809] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 2.030918] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 2.031026] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f77
[ 2.031157] sdhci: Cmd: 0x00000000 | Max curr: 0x00000000
[ 2.031384] sdhci: Host ctl2: 0x00003000
[ 2.031702] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 2.032338] sdhci: ===========================================
[ 2.036073] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 2.036205] sdhci: Sys addr: 0x00000000 | Version: 0x00000505
[ 2.038018] sdhci: Blk size: 0x00000200 | Blk cnt: 0x00000000
[ 2.043621] sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 2.049465] sdhci: Present: 0x01fb00f0 | Host ctl: 0x00000002
[ 2.055383] sdhci: Power: 0x00000000 | Blk gap: 0x00000000
[ 2.061190] sdhci: Wake-up: 0x00000000 | Clock: 0x00000000
[ 2.067050] sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 2.073247] sdhci: Int enab: 0x00ff0003 | Sig enab: 0x00fc0003
[ 2.078776] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 2.084811] sdhci: Caps: 0x3f6cd08c | Caps_1: 0x18002f73
[ 2.090852] sdhci: Cmd: 0x00000000 | Max curr: 0x00000000
[ 2.096967] sdhci: Host ctl2: 0x00003000
[ 2.100740] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x0000000000000000
[ 2.107026] sdhci: ===========================================
还有nx在sdio的中断上是否做了什么限制?
谢谢。
