Jetson Xavier NX SDK Manager
What a way to spend a week-end. Have Xavier NX that has been running run a few months.
Downloaded SDK Manager. No errors reported.
Host components all show no errors and installed.
Target components - Cuda installs.
Remaining components Vision, Container, Developer Tools all fail.
They all produce basically the following error:
22:01:01 INFO: TensorRT on Target - target: libnvinfer8 is already the newest version (8.2.1-1+cuda10.2).
22:01:01 INFO: TensorRT on Target - target: The following packages were automatically installed and are no longer required:
22:01:01 INFO: TensorRT on Target - target: Use ‘sudo apt autoremove’ to remove them.
22:01:02 INFO: TensorRT on Target - target: 3 not fully installed or removed.
22:01:02 INFO: TensorRT on Target - target: After this operation, 0 B of additional disk space will be used.
22:01:03 INFO: TensorRT on Target - target: Setting up python2.7-minimal (2.7.17-1~18.04ubuntu1.7) …
22:01:03 INFO: TensorRT on Target - target: # Empty sitecustomize.py to avoid a dangling symlink
22:01:03 INFO: TensorRT on Target - target: Consider setting $PYTHONHOME to [:]
22:01:03 INFO: TensorRT on Target - target: dependency problems - leaving unconfigured
22:01:03 INFO: TensorRT on Target - target: python-minimal
22:01:07 ERROR: TensorRT on Target - target: E: Sub-process /usr/bin/dpkg returned an error code (1)
22:01:07 INFO: TensorRT on Target - target: will sleep 10 seconds before next attempt
22:01:17 INFO: TensorRT on Target - target: Reading package lists… 0% Reading package lists… 0% Reading package lists
Host is Ubuntu 18.
Host runs very large Torch applications on GPU with no issue.
Any suggestions as to what I am doing wrong?
I am going to move your topic to the Jetson Xavier NX category for so the support team has visibility.
Best,
Tom
Hello
I found a script, that when executed, solved my issue.
Thanks again
