Hi, I’m using jetpack5.1.1, the program will keep printing OC ALARM 0x00000001 when the program is running and the screen is shaking, and it will stop printing if the screen is still. Attached is the startup log.
1.log (70.7 KB)
What kind of usecase is running on your device? It is not an error. It means the application you run on your board has exceed the power budget.
Hi, I connected 3 cameras, ran the yolo model, did the image stitching algorithm, and did the license plate detection algorithm.
