JETSON XAVIER NX tegra_multimedia_api backend meet a Error
JETSON XAVIER NX
I meet a problem, here is the situation:
step1: cd /usr/src/nvidia/tegra_multimedia_api/samples/backend
step2: ./backend 1 …/…/data/Video/sample_outdoor_car_1080p_10fps.h264 H264 --trt-deployfile …/…/data/Model/GoogleNet_one_class/GoogleNet_modified_oneClass_halfHD.prototxt --trt-modelfile …/…/data/Model/GoogleNet_one_class/GoogleNet_modified_oneClass_halfHD.caffemodel --trt-mode fo32 --trt-proc-interval 1 -fps 10
then
Layer(Reformat): upsample-bbox output reformatter 0, Tactic: 0, upsample-bbox output to be reformatted 0[Half(4,132,240)] → bboxes[Float(4,132,240)]
Layer(h884cudnn): cvg/classifier, Tactic: 7158029511300006471, pool5/drop_s1[Half(1024,33,60)] → cvg/classifier[Half(16,33,60)]
Layer(Reformat): upsample-cvg input reformatter 0, Tactic: 0, cvg/classifier[Half(16,33,60)] → upsample-cvg reformatted input 0[Float(16,33,60)]
Layer(gemmDeconvolution): upsample-cvg, Tactic: 0, upsample-cvg reformatted input 0[Float(16,33,60)] → cvg/tile[Float(1,132,240)]
Layer(Activation): coverage/sig, Tactic: 0, cvg/tile[Float(1,132,240)] → coverage[Float(1,132,240)]
Create TRT model cache
Deserialize required 102348 microseconds.
outputDim c 1 w 240 h 132
outputDimsBBOX.c() 4 w 240 h 132
get resolution failed, program will exit
The program did not display the results visually and was terminated. It seems that this problem appears in line 1645 of the cpp file get_disp_resolution(&disp_info); Didn’t get the length and width of the video?
In addition, when I run
./backend -h, the output is
nvbuf_utils: Could not get EGL display connection
backend … [options]
Channel-num:
1-4, Number of file arguments should exactly match the number of channels specified
Supported formats:
H264
H265
OPTIONS:
-h,–help Prints this text
-fps Display rate in frames per second [Default = 30]
–input-nalu Input to the decoder will be nal units[Default]
–input-chunks Input to the decoder will be a chunk of bytes
–trt-deployfile set deploy file name
–trt-modelfile set model file name
–trt-proc-interval set process interval, 1 frame will be process every trt-proc-interval
–trt-mode 0 fp16 (if supported), 1 fp32, 2 int8
–trt-dumpresult 1 to dump result, 0[default] otherwise
–trt-enable-perf 1[default] to enable perf measurement, 0 otherwise
It has not been solved yet, does anyone know how to solve it? Thank you!
Which JetPack SW version you’re using?
4.5.1
cat /etc/nv_tegra_release
R32 (release), REVISION: 5.1,
sudo apt-cache show nvidia-jetpack
Package: nvidia-jetpack
Version: 4.5.1-b17
API Version: L4T Jetson TX2 R28.4 Multimedia API
Please install jetson_multiemdia_api samples through SDKManager or apt install command. Looks like you use r28.4 samples on r32.5.1. The versions are mismatched and triggers the failure.
Besides, latest Jetpack 4 release is 4.6.4. You may consider use latest version.
