Jetson Xavier NX
I forgot the password of jetson xavier nx, is there any way to reset the password?
Thank you.
Not anything convenient. You can clone, mount the raw clone image (the “sparse” image is not very useful other than for flashing), and edit this, followed by flashing the edited clone. The steps for doing this with an SD card model are probably faster and easier than with an eMMC model, and so knowing which model it is matters. If there isn’t much on there you need, then it might be worth simply flashing it again.
OK Thank you
If you need to know what to edit in a clone just ask. There are a number of ways to go about this, none of which are straightforward (editing the clone before flash is fairly simple, it is being able to create a hash for the password and knowing where to edit this which is tricky).
