Hi~
We used the same image on Xavier A02 & A03 module to measure PCIe power-up sequence, but we got a different result as blew:
Xavier A02 module(SD card sku) → PCIe RST & CLK de-assertion one time
Xavier A03 module(eMMC sku) → PCIe RST & CLK de-assertion two times
Could you explain what difference between A02 & A03 modules??
Hi, is it Xavier or Xavier NX? What’s the A02 and A03 module part number? Where is the “same image” from? What have you done with the custom image? Have you repro on devkit?
For A02 and A03 module, it is same on PCIe part on hardware.
Hi~ Trumany,
Yes, We can repro it on devkit when we use Xavier NX PN: 180-13668-DAAA-A03.
I think somewhere different between the two modules. Otherwise, I didn’t get different results when I measured PCIe RST & CLK signals.
Test HW configuration:
Xavier NX PN: 180-13668-DAAA-A02 + Xavier DevKit PN:180-13509-DAAF-A01 → PCIe RST & CLK de-assertion one time
Xavier NX PN: 180-13668-DAAA-A03 + Xavier DevKit PN:180-13509-DAAF-A01 → PCIe RST & CLK de-assertion two times
Hi~Wayne,
Actually, We have an issue related to Kingston SSD. Kingston SSD cannot be detected when it formats to NTFS, but EXT4 doesn’t have this problem. This issue only happens on Xavier A03 module(eMMC sku) and Xavier A02 module(SD card sku) doesn’t have this problem. So, I do some experiments related to PCIe RST & CLK. I think this issue is related to PCIe RST & CLK de-assertion two times.
