Hello
Do you have MTBF info for Ground Mobile at 60°C?
In the datasheet only has 35°C.
Thanks,
John
Hello
Thanks,
John
No such info is available. Maybe you can estimate that with temperature stress curve in temperature factors table in standard Telcordia SR-332, ISSUE 3
Hi Trumany,
Refer to the Telcordia SR-332, ISSUE 3, the temp. stress curve has 1 - 10 items which are different temp. factor.
May i know which one should be used for estimation.
Thanks,
John
There is description in the standard about how to select curve for different type of devices. Please refer to that per your request, we have no more suggestion on this.
Okay, thank you.
