Running into an issue with a Xavier not booting. It display the error in the attached image on the screen. It does not allow you to proceed to any UI.
You can access it through a console just fine. Does anyone know what could be causing this issue?
Please try to dump the syslog and xorg.0.log from /var/log/
Also, please try to tell what was your last step on this board before this error happened.
