I cannot connect my Jetson Xavier NX to a display using either tty or HDMI. If I connect with the Micro USB I can see it listed in system_profiler (OSX) or with lsusb but I can’t actually connect to the device. I have a flashed SD card.
Actually I think the issue is that it won’t boot. If I check on lsusb it looks like It is in recovery mode as I get an ID 0955:7e19 NVIDIA Corp. APX. Is there any way to force it into setup mode?
If the system is fully booted, then the micro-USB can emulate certain devices, e.g., a virtual network adapter or a virtual mass storage device. The presence of the 0955:7e19 could indicate recovery mode, but it can also indicate a fully booted system due to the custom emulated devices.
If you monitor your PC via command “dmesg --follow”, and then connect the powered up NX’s micro-USB, what do you see in the dmesg log? Once connected, from the host PC side, does “ping 192.168.55.1” succeed?
FYI, forcing recovery mode is done by shorting the recovery mode pins (one is the actual pin, the other is just ground) while either powering up or resetting power.
thanks for getting back
'dmesg -follow` returns with
[ 6405.407336] usb 3-2: new high-speed USB device number 7 using xhci_hcd
[ 6405.781761] usb 3-2: New USB device found, idVendor=0955, idProduct=7e19, bcdDevice= 1.02
[ 6405.781767] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6405.781838] usb 3-2: Product: APX
[ 6405.781842] usb 3-2: Manufacturer: NVIDIA Corp.
`ping 192.168.55.1’ does not succeed.
This might be in recovery mode. When connected what do you see from “lsblk -f”? I am curious if a new block device shows up.
lsblk -f
NAME FSTYPE LABEL UUID FSAVAIL FSUSE% MOUNTPOINT
loop0 squashfs 0 100% /snap/core18/1880
loop1 squashfs 0 100% /snap/gnome-3-34-1804/36
loop2 squashfs 0 100% /snap/gtk-common-themes/1506
loop3 squashfs 0 100% /snap/snap-store/467
loop4 squashfs 0 100% /snap/snapd/8542
loop5 squashfs 0 100% /snap/core18/1885
loop6 squashfs 0 100% /snap/snapd/8790
sda
├─sda1 vfat 9D2E-F55E 511M 0% /boot/efi
├─sda2
└─sda5 ext4 69eff245-072d-4fb7-8b5e-a1ae116690ff 11.2G 36% /
sr0
i have a 500GB samsung SSD attached and a 128GB SD Card. I don’t think the SD card is being read.
Assuming the lsblk -f is from the host PC with the Jetson’s micro-B USB cable connected, then indeed the Jetson’s normal sample mass storage device emulation is not showing up. This would be consistent with either being in recovery mode, or optionally a failed boot.
…for this above, are you saying these also do not show up on the host PC with lsblk -f? I too did not see these on your lsblk -f, and if the PC cannot see these devices, then any copy to the devices would also fail even if the devices are otherwise functional. Can you give more details about what you see from the host PC for those devices?
