JetsonNano HDMI "No signal"
It happens on a custom board with display from https://www.waveshare.com/5inch-HDMI-LCD-H.htm, but there is other monitor that works fine.
dmesg_log.txt (58.6 KB)
Is this monitor working fine on devkit?
works(5inch-HDMI-LCD) but has problems with resolution
  1. What is the problem on devkit?
  2. In your log, it has multiple “unplugged” Do you see the same behavior on devkit?
[ 5.332053] Extcon HDMI: HPD disabled
[ 5.332069] tegradc tegradc.0: hdmi: unplugged
[ 5.937915] tegradc tegradc.0: blank - powerdown
[ 5.939021] tegradc tegradc.0: unblank
[ 5.943069] tegradc tegradc.0: nominal-pclk:33900000 parent:33900000 div:1.0 pclk:33900000 33561000~36951000
[ 5.943170] tegradc tegradc.0: hdmi: tmds rate:33900K prod-setting:prod_c_hdmi_0m_54m
[ 5.944177] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 5.978847] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 16.464708] tegradc tegradc.0: hdmi: unplugged
[ 17.058101] tegradc tegradc.0: blank - powerdown
[ 17.059197] tegradc tegradc.0: unblank
[ 17.063160] tegradc tegradc.0: nominal-pclk:33900000 parent:33900000 div:1.0 pclk:33900000 33561000~36951000
[ 17.063225] tegradc tegradc.0: hdmi: tmds rate:33900K prod-setting:prod_c_hdmi_0m_54m
Booted on devkit, display works
Are those unplugged triggered by you or it just printed by itself?
Itself, cyclically trying to connect
Does this unplugged/plugged also happened on other HDMI monitors? This sounds like this 5inch-HDMI-LCD has something wrong…
3 monitors were tested, one is fully and stably working, two are not(no signal)
You mean on devkit or on your board? Such unplugged event should not keep happening.
my board
Are those two “no signal” monitor also sharing the same behavior which has many “unplugged” in dmesg?
there is no cycling, but the screen is dark
dmesg_log_mon.txt (53.8 KB)
Don’t see error message. Please try to check hotplug case.
Do not connect any monitor when boot up. Hotplug the monitor until the boot is done.
after hotplug, screen is dark
[ 123.260760] edid invalid
[ 123.263303] edid invalid
[ 123.516159] edid invalid
[ 123.653169] tegradc tegradc.0: blank - powerdown
[ 123.671824] tegradc tegradc.0: unblank
[ 123.701194] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 123.701268] tegradc tegradc.0: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_75m_150m
[ 123.702303] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 123.737020] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 123.737022] Extcon AUX1(HDMI) enable
[ 123.752456] tegradc tegradc.0: sync windows ret = 992
[ 123.775311] extcon-disp-state extcon:disp-state: cable 51 state 1
[ 123.775313] Extcon HDMI: HPD enabled
[ 123.775337] tegradc tegradc.0: hdmi: plugged
No error from kernel side.
  1. Is this monitor working fine on devkit?
  2. Could you check /var/log/Xorg.0.log and attach it?
  1. yes (tested without Xserver)
2
Xorg.0.log (11.1 KB)
Also don’t see error in your xorg log.
Please try to check this from hardware aspect.
For example, do the tuning. Jetson Download Center | NVIDIA Developer
