Joint torque readings are wrong
I’m comparing IsaacSim 4.2 joint torques from 3 different sources:
  • The dynamic_control module with get_dof_effort()
  • The ROS2 topic, ros2 topic echo /isaac_joint_states
  • The Articulation Inspector
dynamic_control agrees with the ROS2 topic, unfortunately they’re both wrong. The Articulation Inspector seems to be correct. The difference becomes worse if I change the mass of one of the robot links; it updates properly in the Articulation Inspector but the other 2 ways don’t get updated, it seems.
Here’s an image to verify. It shows the Articulation Inspector on the left, ros2 topic on the right. They’re different.
Fix your software, Nvidia.
Hi @andyzelenak! Sorry for my late reply. Thanks for pointing out this issue. Our engineer has already worked on a fix for it and this issue will be resolved in Isaac Sim 4.5.0.
