I’m trying to implement the joystick controller with the Flatsim simulation, so i added the Commander node (the one with Gamepad Virtual Bridge inside) into the Flatsim graph. Now, i’m able to see the backend widget using Sight, however when i click on ‘Connect to backend’, it doesn’t work (robot doesn’t move).
Could you tell us a bit more about the setup you have here? This is with Flatsim using which JSON file and which robot? You’re using the Virtual Gamepad or your own physical controller? Does the backend widget indicate that it is connected to the Virtual Gamepad Bridge by any chance?
